Drives: Toyota yaris Join Date: Feb 2024
Water leak in the boot,Yaris/Vitz II
Attachment 62809There appears to be a leak in the trunk of my Toyota Yaris II, specifically in the right rear corner. I suspect it might be coming from the area around the right rear light, where moisture also accumulates. Could this be due to an improperly installed seal picture no.1, or do I need to replace the entire rear light seal picture no. 2 ?
![]() ![]() Drives: Yaris T sport TRD turbo Join Date: Aug 2017
Taillight gaskets are prone to fail, remove the taillight and clean everything.
Check the condition of the gasket, ideally replace. If you are cheap you can also use bathroom sealant
2004 Yaris T-Sport 1NZ-FE with TRD Turbo |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
Use powder to determine where leak is coming from.and spray with a hose
| 2008 toyota yaris 2 door hatchback water leak | knobby bobby | DIY / Maintenance / Service | 8 | 07-03-2024 07:42 AM |
| Water Leak in Boot | zoidberg444 | DIY / Maintenance / Service | 8 | 11-02-2023 01:34 PM |
| Advice about leak, water in spare tire well | RMcG | DIY / Maintenance / Service | 20 | 01-29-2021 04:47 PM |
| 09 Yaris Rear Water (rain) Leak | Loki452 | DIY / Maintenance / Service | 14 | 03-02-2019 08:35 PM |
| 08 Yaris water leak troubleshooting help requested | 2bz | DIY / Maintenance / Service | 5 | 12-22-2018 06:37 PM |
