Old 05-22-2025, 09:37 AM   #1
Adam Davis
Drives: Yaris 2007 1.4 Diesel
Intermittent ABS Light
Hi all,
I have a 2007 Toyota Yaris 1.4 Diesel that is turning on its ABS light on every other drive. I checked the ABS codes today and the three it came back with are:
  • C1333
  • C0210
  • B2283
Both rear hubs have been changed in the past which contain the ABS sensor but I thought it strange that both codes have been triggered for both sides at the same time?
Has anyone dealt with this problem before and can offer some advice? I am hesitant about replacing both rear hubs with the ABS sensor built in, to find it does not solve my problem!
Thanks in advance.
Adam Davis is offline   Reply With Quote
Old 05-23-2025, 06:46 AM   #2
komichal
Had this. Authorized shop told me that this is unfortunately common problem for Yarises 2006 and newer. The connector of the ABS wires is not well protected against water, salt etc. so it eventually corrodes so heavily that the metallic contacts basically disappear... A piece of ABS harness needs to be changed completely.
Had this like 10 years ago. The shop changed the wiring (it was not expensive) and problem solved.
ABS light Reklaw-79 General Yaris / Vitz Discussion 6 11-03-2021 12:01 PM
ABS light on. Help. lax2229 General Yaris / Vitz Discussion 7 02-03-2016 09:35 PM
Resetting abs light on 58 plate yards jackg205 DIY / Maintenance / Service 1 06-24-2013 06:43 AM
Yaris 2007 ABS & Brake light issue after wheel bearing change DevilzMafia DIY / Maintenance / Service 4 01-17-2013 09:24 PM
anyway of taking out the abs light bulb? SweetRS DIY / Maintenance / Service 2 03-13-2009 08:24 PM
