Drives: Yaris 2 1.33 MMT 2009 europe Join Date: Oct 2026
Convert MMT 6 speeds to manual
Hello everyone,
I’m writing to ask for your help. My car: 2009 Toyota Yaris, model code NSP90L-CHLGKW, VIN : VNKKH96360A143592 Engine: 1NR-FE, 1.33 VVT-i, 100 hp Grade: SOL Transmission: MMT (MultiMode Transmission, automated manual) Background: After replacing the clutch, I was unable to complete the calibration/initialization/learning procedure for the MMT. I get error code P0810 and the “N” indicator keeps flashing. I’ve tried several times without success. I’ve now decided to give up on the MMT and convert the car to a standard manual gearbox. My questions: 1. Is this conversion feasible? Has anyone here done it, or does anyone know of a build log? 2. Shift lever and retainer So far I have found the clutch pedal and the clutch master cylinder. However, I can’t find the correct shift lever and retainer assembly. I found this Amayama catalog page: https://www.amayama.com/en/genuine-c...1/chassis/3312 I’m not sure it is the right assembly for my car. Could someone check it for me and confirm the part numbers? And if they are correct, do you know where I can buy the complete assembly (lever, retainer, cables, etc.)? I’m based in France, so a supplier in Europe would be ideal. 3. Replacing the MMT actuator unit with a cable shift mechanism I’m not sure how to replace the MMT gear-shift motor/actuator unit with a conventional cable-operated shifter. What is the correct procedure, and which parts do I need to buy for it? 4. ECU and wiring I assume the ECU needs a different configuration, or some pins need to be bridged or rewired, once the MMT’s TCM is removed. I don’t know how to do this. Does anyone know how to convert the ECU from the MMT setup to a manual gearbox? Do I need a manual-specific ECU, or can the existing one be reconfigured or coded? Any advice, part numbers or experience would be greatly appreciated. Thank you very much! |
| Manual are a dying breed. | junorico24 | Off-topic / Other Cars / Everything else Discussions | 17 | 01-09-2020 10:47 AM |
| Where to buy service & repair manual? (and Parts manual?) 2010 Yaris Sedan | TYaris2010 | DIY / Maintenance / Service | 1 | 07-08-2018 09:38 AM |
| 2YR/25K Retrospective/Review (French-Built 2015 Yaris SE, Manual 5-spd) | Kalispel | Third Gen Yaris General Discussion | 12 | 08-24-2017 11:26 AM |
| Grimmspeed Manual Boost Controller For Sale | fnkngrv | Items for Sale by private party | 1 | 05-05-2014 01:25 PM |
| Want to trade my manual 07 sedan for a 09 5dr to convert to 5sp | anonymous user | New YARIS Purchase Forum | 5 | 11-11-2008 01:44 PM |
