Old 05-20-2007, 09:23 PM   #37
Carvin'07
Selling all mods
Carvin'07's Avatar
Drives: '07 Bayou Blue - totally stock
Pin that against the current claim of 30 million Corollas ever produced. That's strict economics my friend! [ok, end Off Topic]
Carvin'
Carvin'07 is offline   Reply With Quote
Old 05-21-2007, 06:22 AM   #38
sdmf
Down With the Sickness
sdmf's Avatar
Drives: 2007 yaris liftback
Send a message via AIM to sdmf
yea my thread has been hijacked. wtf, all i wanna know is if can be done, and if yes how much will it cost. if you wanna talk engines make your own damn thread. thank you
Strength - Determination - Merciless - Forever
sdmf is offline   Reply With Quote
Old 05-21-2007, 08:06 AM   #39
Carvin'07
Selling all mods
Carvin'07's Avatar
Cool sorry sdmf
Originally Posted by sdmf View Post
ok i was surfing the net and i stumbled upon this beauty. http://www.rotrex.com/ i saw some of the numbers this s/c and wow, its more efficient than a turbo, (maintainance, cooling, lifespan, etc.) the only problem is you have to make your own piping, the numbers are waay better than the blitz sc. anyone know how to do some mandrel bending?
Hey there,
Sorry for continuing the OT.
To directly answer your questions, yes it can be done with some money and determination. In Chicago, there should be loads of shops that can do mandrel bending. Look in your yellow pages at exhaust shops. Usually there are only a few around (mandrel anding machines are expensive), but they should be there. If not, you can always buy universal bends and silicone couplers off of ebay. Just make sure you get good T-bolt clamps to hold back that newly found pressure you will be making!
As others have indicated, the S/C route is a good option if you want moderate, low end torque increases, but limits ultimate the ease of future power upgrades.
You could have a pulled milled from stock aluminum, but that will cost you big bucks. You might want to try out an xA or xB (??) pulley, I can't remember which was mentioned earlier to see if it will fit our needs.
Cheers and good luck with your project.
Carvin'
Old 05-21-2007, 10:35 AM   #40
cdydjded
Drives: Yaris LB Turbo
Carvin: Bending pipes is the least of you worries. Read my previous post, our engines pulley system is not enough to support the Rotrex pully requierments. Why are you speculating or guesing if the Rotrex will work?
cdydjded is offline   Reply With Quote
Old 05-21-2007, 12:51 PM   #41
Basically, our Yarii use a single pulley system while the xA/xB use a double pulley, hence it may be possible to use the extra pulley groove to run the supercharger. But the best bet would still be a custom-made one.
Old 05-21-2007, 02:45 PM   #42
sdmf
sdmf's Avatar
so i guess its just a pipe dream for now. i will just play the w8n game til companies make some serious products for our car. like i said just wanted to hit close to the 200 mark, with a better low end reponse. so the rotrex was the way i wanted to go.
Old 05-21-2007, 03:11 PM   #43
cdydjded
The single pulley is not the problem, its the amount of grooves our pulleys have. A minimal of 5 is needed but 6 is what Rotrex suggest
Old 05-21-2007, 03:17 PM   #44
cdydjded
200HP to the wheels or flywheel? Do you realize that the turbo kit that ZPI has available did 175hp to the wheels? That is over 200hp @ the flywheel. Plus 170LB of torque. As for low end response, turbos have advanced 10 folds in the last 5 years. Lag is almost a thing of the past. If you pick the proper turbo built specifically for the size of the engine.
Old 05-21-2007, 06:20 PM   #45
sdmf
sdmf's Avatar
well how about the heat dissapation?
Old 05-21-2007, 06:29 PM   #46
cdydjded
I think you are trying to reinvent the wheel. Run a intercooled 5-7lb of boost kit & you get 175hp to the wheels. What more do you want? More power? Install a set of lower compression pistons & a set of rods. Now you will be over 200hp. In a 2300lb car that is 11.5hp per pound. That is better than a new Z06 Vette.
Old 05-23-2007, 08:19 PM   #47
DoriKnights
Drives: Rps13
s/c cool, but its more stress on that tourqe struglin 1.5. Would rather boost off the exhaust rather than put more stress on the crank
DoriKnights is offline   Reply With Quote
Old 05-27-2007, 06:50 PM   #48
Dear Underdog Racing,
+1 interest
Old 05-27-2007, 09:42 PM   #49
RShatchback
Drives: 07 yaris liftback
+2 - I've got the money, I'm just waiting on someone to release a supercharger or maybe even two different companies, so i can make a comparison before buying it. But I'm waiting...
RShatchback is offline   Reply With Quote
Old 05-28-2007, 02:15 AM   #50
sdmf
sdmf's Avatar
so ur saying there's a chance couldnt someone just modify the rotrex pulley to 3 groove?
Old 05-28-2007, 02:26 AM   #51
Anything's possible... If you don't believe it, go grab a DVD of that TV show Monster Garage...
anyone with Blitz supercharger? yrsdrgn Performance Modifications 52 08-24-2010 08:57 AM
Gauge for Interest in JR Supercharger redglare45 Performance Modifications 36 09-17-2009 09:04 AM
Looking for a Supercharger! (Yaris 1.8 TS) ItalianYaris Forced Induction Forum 14 04-27-2007 05:42 PM
Greddy xB Supercharger Papamoon Performance Modifications 2 02-09-2007 04:08 PM
Supercharger? iampachino Performance Modifications 15 08-24-2006 05:51 AM
