Old 05-22-2007, 05:20 AM   #1
nurburgring
ringmeister
nurburgring's Avatar
Drives: YARIS 1.5
Dont forget the camber bolt.
PErhaps one of the best things you can do to your handling, if you push really hard in corners, is to replace your stock camber bolt to a adjustable one. I have set mine to -1.5 degrees, vs the stock angle of -0.5 deg.
Immediately noticeable would be higher sustained cornering speed. Previously, the tyre would just roll on its sidewalls when pushed too hard into a corner. Now it just bites hard into the tarmac. But watch it, the front will bite so hard that the rear starts to lose it before the front.
nurburgring is offline   Reply With Quote
Old 05-22-2007, 05:25 AM   #2
i don't really push my Yaris too hard, but i have notice some understeer while going onto on ramps. how is your tread-wear with that camber setting?
Old 05-23-2007, 03:13 AM   #3
mojoyaris
Ecurie Snoopy Lives
mojoyaris's Avatar
Drives: Jojo
Do you find them hard to change up on the fly? I was thinking about this for the autocross, but want something that is easy to change between street and track.
Sponsors and Organizations:
Toyota Rally Canada
Yokohama Tire Canada
Western Canada Rally Association
Ecurie (Team) Snoopy Canada, racing since 1966
mojoyaris is offline   Reply With Quote
Old 05-23-2007, 03:20 AM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
anyone have the alignment stock alignment specs for our car? I want to do some suspension tweeks, but no alignment shop has specs for 07's yet except the dealership, and they want am arm and a leg to align a car...
Old 05-23-2007, 05:19 AM   #5
first post says camber is -0.5 deg.
Old 05-23-2007, 05:27 AM   #6
Black Yaris
der Zeck
do you realy think that is the only angle adjustable?
there is toe, camber, caster-front and rear...gotta make sure the thrust angle is right... I was asking for the specs for the car so I can throw it on a rack, other than a dealer, so I can set the front and rear camber slightly negative, but keep the toe and caster dead on
Old 05-23-2007, 05:39 AM   #7
thought you were only talking about camber. and no, i'm sure everything is adjustable with some mods.
DIY: Nonstop Tuning CR-Lite Pulley ChinoCharles DIY / Maintenance / Service 121 02-03-2010 06:41 AM
Do any other Toyota front seats have same bolt pattern as Yaris? ScottFern DIY / Maintenance / Service 18 07-02-2007 12:44 PM
Camber Kit? LoudYar Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 04-12-2007 10:58 AM
Bolt pattern: Yaris Sedan littletegls Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 12-03-2006 06:29 PM
