Old 06-05-2007, 09:16 AM   #1
Papamoon
07 Black LB
Papamoon's Avatar
Drives: 2007 Yaris LB
ZPI crank pully is squeaking....
I've been driving with my ZPI pully for about 6k miles now. It has worked great, and I haven't had any problems until it started getting warmer. My belt has started squeaking ever since the temperature went up. I'm not sure if that has anything to do with it. I got out the torque wrench and cranked it, but it was already at 135. I made sure that the alternater was in the right spot, no slipping. Everything is the same as when I installed it. The thing that bugs me is when I look down at the pully, it looks like it has a slight wobble to it. Any suggestions?
Papamoon is offline   Reply With Quote
Old 06-05-2007, 09:35 AM   #2
mine squeaks a bit too when I first turn on the engine, for like half a second... I think the mechanics didn't tighten the belt enough, but there's also some silicone spray you can apparently use to reduce the squeaking...
Old 06-05-2007, 09:41 AM   #3
hasher22
Look mum no stars!!
hasher22's Avatar
Drives: Toyota Yaris 06
yea mine does the exact same thing.....!!!
well not everytime i start the engine...prob once every week it does that. But im fine with it.....hope it doesnt lead to any big hassles in the long run.
"belt dressing" can be used to long life your belt and make it grip to the pulley. It will also reduce the squeaks. Though use the belt dressing at ur own risk since theres a 50/50 chance that using the belt dressing can cause major damage to the belt.
Old 06-05-2007, 11:55 AM   #4
Papamoon
07 Black LB
Papamoon's Avatar
Yeah, mine throws a squeak right when i start it up, then it goes away, but after I've been driving for about 30 mins, when I'm at idle, it squeaks then as well....
Old 06-05-2007, 11:58 AM   #5
Toyotech
Your Toyota Technician
Drives: 06 Cobalt SS/SC, 06 Rolla S
Send a message via AIM to Toyotech
then adjust the belt some... these are the same issues with all nz's with udp's or not. at about 10-15 during a svc i would normally adjust the bolt a few turns. the belts stretch...
Toyotech is offline   Reply With Quote
Old 06-08-2007, 03:33 PM   #6
365Motorwerks
Drives: Small and Black
Good Call!
I had the same thing when I swapped belts the new one worked great for a bit then started squealing a month or so later, loosened the nut pulled the alternator tight with help of a pry bar tightened the nut back up...good to go 5mins max! Go for it you can do it!
365Motorwerks is offline   Reply With Quote
Old 06-08-2007, 03:52 PM   #7
Astroman
Modded Moderator
Astroman's Avatar
Swap it for a NST pulley
Old 06-08-2007, 03:58 PM   #8
365Motorwerks
The pulley doesn't matter is what we were getting at, it is not adjusted that's where the squealing is comming from it is the same on stock pulleys any car...
Old 06-08-2007, 05:20 PM   #9
carlosh
carlosh's Avatar
Drives: Yaris Sedan 2005 Motor 1NZFE
Send a message via MSN to carlosh Send a message via Yahoo to carlosh
Hi, check the two nut (bolt) they hold the alternator, in the inside it must be well tight. it happened to me that I did not tighten the nut under the alternator well, but I tightened the one of the tension well. The belt vibrations if this nut is not correct tighten...
regards...
Yaris/echo 1NZFE NCP12
-> TEIN High-TECH spring, Tower bar Generic, HOTCHKIS Sway bar
-> TRD Performance air filter, Stage 1 Gripforce F1 clutch
carlosh is offline   Reply With Quote
Old 06-08-2007, 05:26 PM   #10
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
im surprised toyotech didn't say this but DON'T spray anything on the belts. it just screws them up and then your out 60 bones for a new one.....
Old 06-18-2007, 08:38 AM   #11
Katana
Katana's Avatar
Drives: Yaris LB 1.3lt 06
This might be the solution.
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 02:24 AM
ZPI soon to release their turbo kit turboyaris Forced Induction Forum 10 04-26-2007 03:52 PM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 03:10 PM
ZPI or NST crank pully? PetersRedYaris Performance Modifications 35 03-04-2007 04:34 PM
ZPI Crank Pulley Installed! Papamoon Performance Modifications 3 03-02-2007 12:35 PM
