Old 07-06-2007, 04:29 PM   #1
sdmf
Down With the Sickness
sdmf's Avatar
Drives: 2007 yaris liftback
Send a message via AIM to sdmf
oops is too much power bad
hey guys, i accidentally bought the wrong amp, i was looking for a 1000w mono amp and accidentally got a 1000w, 2 channel amp, its a ppi a1000. its rated at the following
# 1000 Watts max
# 175 Watts x 2 @ 4 ohms
# 250 Watts x 2 @ 2 ohms
# 500 Watts x 1 @ 4 ohm
# bridged (mono) load indepence in stereo:2-8 ohms
# load indepence in bridged:4-8 ohms
# Amplifier efficiency is 50% into 2 ohm load at max power.
i was considering using it to power up a set of component speakers rated at 100w rms max 200w. so can i use this amp to power up the speakers at 4ohms and will it be fine or its too much power for the speakers to handle. or should i just look for 2 subs and use the amp to power it up.
Strength - Determination - Merciless - Forever
sdmf is offline   Reply With Quote
Old 07-06-2007, 05:20 PM   #2
staticorex
staticorex's Avatar
Drives: Sc'd Yaris Sedan.
You can't give speakers too much power. They just won't use what they don't need. You can run the speakers off it if you want. It would be a huge waste though. I say run the subs. My 4 JL's are set to two 500/1's and I've never had a problem. So 1000/2 should be huge.
Old 07-06-2007, 06:01 PM   #3
seriousfun
Drives: 2007 Yaris Liftback Black
More power = more headroom. The ability to play with less distortion.
It's more likely to blow a speaker with a small amp run to distortion than with a large amp run clean. You can, on loud transients, have so much power that you push a voicecoil out of the magnet gap, but that is rare.
Enjoy the headroom!
seriousfun is offline   Reply With Quote
Old 07-07-2007, 03:24 AM   #4
sdmf
sdmf's Avatar
sweet, i got it a low price so it should be a good, basically gonna run a 3 speaker setup, a pair of components and a sub, that should be good with optimum angles
Old 07-08-2007, 02:01 PM   #5
nauc
nauc's Avatar
Drives: NA
sell it and buy a couple of these, hurry tho, while supplies last
http://www.cadencestore.com/ProductC...idCategory=125
some of the amps are going for $129.. reg $489
heres the regular prices.. http://www.cadencestore.com/ProductC...?idCategory=99
Red Top, 9833, 180CS, 12" HC in 3.6@29, a1200
nauc is offline   Reply With Quote
Old 07-08-2007, 05:08 PM   #6
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Never can have too much power.
slvryaris is offline   Reply With Quote
Questions and advice required about power upgrading(windows & locks) W.A.S.P DIY / Maintenance / Service 10 07-22-2009 03:59 AM
Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) gaffo General Yaris / Vitz Discussion 28 07-15-2007 08:55 PM
convenience vs. power package jeff_o General Yaris / Vitz Discussion 25 10-17-2006 11:04 AM
Need Help - Electrical (finding Power) Ayka DIY / Maintenance / Service 7 10-12-2006 12:51 PM
