Old 07-13-2007, 12:20 PM   #19
kimona
kimona's Avatar
Drives: 2014 White VITZ
I think stock bolts would be just fine with 5mm spacer. More than 5mm's will need longer bolts.
BTW, I wouldn't touch those spacers!
Do yourself a favour and get quality hubcentric spacers... it's worth the extra bucks.
With cheap spacers, you run the risk of vibration at speed... which is all too common.
Old 07-13-2007, 12:23 PM   #20
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
Yup 5zigen div 3 16x7 they're 205/50/16 tires....i wanna get 205/45/16
Old 07-13-2007, 12:24 PM   #21
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
I'll check around. I figured the same with 5mm stock would be fine. If you see some 5mm good quality let me know. I did a little looking a around and didn't find however I did see some 10mm. That is a bit much I think.
SPONSORED BY
Old 07-13-2007, 12:27 PM   #22
kimona
kimona's Avatar
The Yaris center bore is 54.1.
If you really want to use spacers, don't go cheap!
You can buy Ichiba aluminum/magnesium alloy hubcentric spacers on ebay for about $60 a pair (plus shipping) including longer studs.
Previous post this thread.
Yup, I think 5mm in the rear with your 40mm wheels should look good!
Old 07-13-2007, 12:27 PM   #23
Thirty-Nine
Small cars are a big deal
Thirty-Nine's Avatar
Just FYI, I have 15mm rear spacers on my xB. They are the H&R TRAK spacers, and they are very high quality. They came with longer wheel studs, too (where were a PITA to install).
For a smaller spacer, check here:
http://onetongarage.com/products/whe...cer/index.html
So is it the front that has the problem with rubbing? Not so much the backs?
With a 205/50/16 and a +35 offset wheel, I keep getting told I'll rub in the front when lowered ...
Old 07-13-2007, 12:28 PM   #24
brickhardmeat
Lonesome Cowboy
coolness I'll check them for 5mm stock
SPONSORED BY
Old 07-13-2007, 12:29 PM   #25
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
I believe my friends bro-in-law put 15mm spacers on his rear for his xb with 16x7 shaumauchers (spelling?) but they really flush with his fenders now
Old 07-13-2007, 12:31 PM   #26
brickhardmeat
Lonesome Cowboy
what was his original offset?
SPONSORED BY
Old 07-13-2007, 12:32 PM   #27
Thirty-Nine
Here's my 16x7 +35 A-Tech Finalspeeds on my xB w/15mm rear spacers and 205/50/16 tires:
Old 07-13-2007, 12:33 PM   #28
kimona
kimona's Avatar
Yup, you'll get major rubbing if lowered!
Old 07-13-2007, 12:34 PM   #29
Thirty-Nine
Front and back or just front?
Old 07-13-2007, 12:34 PM   #30
kimona
kimona's Avatar
Yah, you can run really low offsets on the xbox!
Old 07-13-2007, 12:39 PM   #31
brickhardmeat
Lonesome Cowboy
I don't mid a little poke but I don't want any on my yaris just flush or a little closer to flush. I'm pretty sure 5mm would do the trick.
SPONSORED BY
Old 07-13-2007, 12:40 PM   #32
kimona
kimona's Avatar
Okay, we're talking about the Yaris/Vitz now... right?
Front: With a 35mm and 205/50's and lowered, you'll have major rubbing problems.
Rear: With 35mm, 205/50's and lowered, you'll have rubbing under load.
Old 07-13-2007, 12:41 PM   #33
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
haha my rear looks like thirty-nine's first rear shot =P according to my friends bro-in-law it has a 37 offset. the same has his on his xb
Old 07-13-2007, 12:42 PM   #34
Thirty-Nine
Yes, Yaris. Thanks for clarifying that.
Old 07-13-2007, 12:45 PM   #35
kimona
kimona's Avatar
Hey brickhardmeat,
If you're running ET40mm (and 205/50/15's), you should be flush up front... is that right?
Take a level and a mm ruler and see how many mm's will bring the rears out to where you'd like them (to match the fronts).
Then look for the size spacers you want... they're available in a wide range of mm widths.
Torquing those Lug Nuts... Doc Zaius Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 07-13-2007 12:19 PM
Cheap Lug Nuts? KwonSau Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-06-2007 12:51 AM
How to remove the Nut on the top of the shock tower hystria DIY / Maintenance / Service 29 12-08-2006 09:30 PM
5 lug adapter? funkstrong Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 10-21-2006 04:49 PM
Lug Nuts for Konig Helium Wheels? OK Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 09-19-2006 05:58 PM
