#19 |
I think stock bolts would be just fine with 5mm spacer. More than 5mm's will need longer bolts.
BTW, I wouldn't touch those spacers! Do yourself a favour and get quality hubcentric spacers... it's worth the extra bucks. With cheap spacers, you run the risk of vibration at speed... which is all too common. |
#20 |
Yup 5zigen div 3 16x7 they're 205/50/16 tires....i wanna get 205/45/16
#21 | |
Lonesome Cowboy
Drives: 2007 WHITE HATCHBACK Join Date: Feb 2007
SPONSORED BY
#22 | |
Yup, I think 5mm in the rear with your 40mm wheels should look good! |
#23 |
Lonesome Cowboy
coolness I'll check them for 5mm stock
SPONSORED BY
#24 |
I believe my friends bro-in-law put 15mm spacers on his rear for his xb with 16x7 shaumauchers (spelling?) but they really flush with his fenders now
#25 | |
Lonesome Cowboy
what was his original offset?
SPONSORED BY
#26 | |
#27 |
Yah, you can run really low offsets on the xbox!
#28 |
Lonesome Cowboy
I don't mid a little poke but I don't want any on my yaris just flush or a little closer to flush. I'm pretty sure 5mm would do the trick.
SPONSORED BY
#29 |
#30 |
haha my rear looks like thirty-nine's first rear shot =P according to my friends bro-in-law it has a 37 offset. the same has his on his xb
#31 | |
If you're running ET40mm (and 205/50/15's), you should be flush up front... is that right? Take a level and a mm ruler and see how many mm's will bring the rears out to where you'd like them (to match the fronts). Then look for the size spacers you want... they're available in a wide range of mm widths. |
| Torquing those Lug Nuts... | Doc Zaius | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 07-13-2007 01:19 PM |
| Cheap Lug Nuts? | KwonSau | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 06-06-2007 01:51 AM |
| How to remove the Nut on the top of the shock tower | hystria | DIY / Maintenance / Service | 29 | 12-08-2006 10:30 PM |
| 5 lug adapter? | funkstrong | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 8 | 10-21-2006 05:49 PM |
| Lug Nuts for Konig Helium Wheels? | OK Yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 09-19-2006 06:58 PM |
