Old 07-23-2007, 07:30 AM   #1
red-jdm
red-jdm's Avatar
Drives: Yaris type E M/T
forged rims Vs. alloys
guys, please tell us your opinion, forged rims OR alloy???
red-jdm is offline   Reply With Quote
Old 07-23-2007, 08:38 AM   #2
kimona
kimona's Avatar
Drives: 2014 White VITZ
Check this website: tirerack.com
Click on wheel tech, then wheel construction.
Unless you're racing your Vitz/Yaris, I think any quality wheel construction will be quite satisfactory.
Old 07-23-2007, 09:50 AM   #3
ChinoCharles
Drives: LB
If you can afford forged, buy forged. If you can't, don't. That simple.
Old 07-23-2007, 01:33 PM   #4
Biggie™
Biggie™'s Avatar
Drives: '07 3 Door Yaris of Doom!
BTW, you're looking for the difference in between forged and cast wheels. Both wheels are going to be an aluminum alloy.
I have some cast Magnesium wheels.
Biggie™ is offline   Reply With Quote
Old 07-23-2007, 02:01 PM   #5
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
X2
they have different manufacturing processes and the cast wheel finished product ends up being heavier. i think it has to do with the tighter grain structure on the forged wheel. someone correct me if i'm wrong... it's been a long time since school.
reznunt is offline   Reply With Quote
Old 07-23-2007, 03:38 PM   #6
Biggie™
Biggie™'s Avatar
Originally Posted by reznunt View Post
X2
Since no one wants to visit that Tirerack url, I'll post it.
Originally Posted by Tirerack
Though not enforced, there are quality standards to govern the production of wheels. Some countries though, like Germany and Japan, have government regulations requiring aftermarket wheels to meet certain criteria and ensure proper fit. The United States has taken steps to establish guidelines but it will be some time before they can enact regulation of any kind.
Consequently, all wheels are not made the same. The performance of an alloy wheel is a direct result of the manufacturing technique employed.
The Tire Rack offers a wide range of wheel choices from manufacture's that have adopted the manufacturing processes that meet the strict O.E.M. (Original Equipment manufacturers) requirements. Wheel companies that supply to the O.E.M. market must follow certain procedures during the manufacturing process to maintain the quality and integrity of their product.
There are many factors to consider when purchasing an alloy wheel.
One-Piece Cast Wheels
This is the most common type of aluminum wheel. The casting of wheels is the process of getting molten aluminum inside a mold to form a wheel. There are different ways this can be accomplished and although it sounds simple, this is truly an art when done properly.
GRAVITY CASTING
Gravity casting is the most basic process of pouring molten aluminum into a mold utilizing the earth's gravity to fill the mold. Gravity casting offers a very reasonable production cost and is a good method for casting designs that are more visually oriented or when reducing weight is not a primary concern. Since the process relies on gravity to fill the mold, the aluminum is not as densely packed in the mold as some other casting processes. Often gravity cast wheels will have a higher weight to achieve the required strength.
LOW PRESSURE CASTING
Low pressure casting uses positive pressure to move the molten aluminum into the mold quicker and achieve a finished product that has improved mechanical properties (more dense) over a gravity cast wheel. Low-pressure casting has a slightly higher production cost over gravity casting. Low pressure is the most common process approved for aluminum wheels sold to the O.E.M. market. Low-pressure cast wheels offer a good value for the aftermarket as well. Some companies offer wheels that are produced under a higher pressure in special casting equipment to create a wheel that is lighter and stronger than a wheel produced in low pressure. Once again in the quest for lighter weight, there is a higher cost associated with the process.
SPUN-RIM, FLOW-FORMING OR RIM ROLLING TECHNOLOGY
This specialized process begins with a low pressure type of casting and uses a special machine that spins the initial casting, heats the outer portion of the casting and then uses steel rollers pressed against the rim area to pull the rim to its final width and shape. The combination of the heat, pressure and spinning create a rim area with the strength similar to a forged wheel without the high cost of the forging. Some of the special wheels produced for the O.E.M. high performance or limited production vehicles utilize this type of technology resulting in a light and strong wheel at a reasonable cost. BBS has used this technology for several years in their production of racing wheels for Formula One and Indy cars. BBS's RC wheel for the aftermarket is an example of a wheel produced using spun rim technology.
FORGED OR SEMI-SOLID FORGED
In forged wheels, computer numerically controlled
(CNC) mills add the cosmetics and the bolt circle to exacting tolerances.
The ultimate in one-piece wheels. Forging is the process of forcing a solid billet of aluminum between the forging dies under an extreme amount of pressure. This creates a finished product that is very dense, very strong and therefore can be very light. The costs of tooling, development, equipment, etc., make this type of wheel very exclusive and usually demand a high price in the aftermarket. Semi-solid forging (SSF) is a process that heats a billet of special alloy to an almost liquid state and then the aluminum is forced into a mold at a very high rate. The finished product offers mechanical properties very similar to a forged wheel without the high production and tooling costs of a forged wheel. When low weight and performance are on your priority list, the SSF technology offers an excellent value. Currently only SSR (Speed Star Racing) from Japan is licensed to use this process for the production of wheels. Read more about semi-solid forging technology.
Multi-Piece Wheels
This type of wheel utilizes two or three components assembled together to produce a finished wheel. Multi-piece wheels can use many different methods of manufacturing. Centers can be cast in various methods or forged. The rim sections for 3-piece wheels are normally spun from disks of aluminum. Generally, spun rim sections offer the ability to custom-tailor wheels for special applications that would not be available otherwise. The rim sections are bolted to the center and normally a sealant is applied in or on the assembly area to seal the wheel. This type of 3-piece construction was originally developed for racing in the early 1970s and has been used on cars ever since. The 3-piece wheels are most popular in the 17" and larger diameters.
There are now many options for 2-piece wheels in the market. The 2-piece wheel design does not offer as wide a range of application that a 3-piece wheel allows, however they are more common in the market and the prices start well below the average 3-piece wheel. Some 2-piece wheels have the center bolted into a cast or cast/spun rim section and other manufacturers press centers into spun rim sections and weld the unit together. When BBS developed a new 2-piece wheel to replace the previous 3-piece street wheel, they used the special rim-rolling technology (originally developed for racing wheels) to give the rim section the weight and strength advantages similar to a forged rim. On the high-end of the 2-piece wheel market you can find wheels using forged rims and forged centers. Since these are only sold in small volume and due to the high development and production costs associated with the forging process, they tend to be on the high end of the price scale.
Old 07-23-2007, 04:24 PM   #7
tca4
tca4's Avatar
Drives: Yaris RS (white)
I like the shorter version
tca4 is offline   Reply With Quote
Old 07-23-2007, 04:39 PM   #8
reznunt
Hi!
reznunt's Avatar
Drives: EF Sedan
so i'm right. thanks for verifying.
Old 07-23-2007, 05:15 PM   #9
Meteorite Man
Passin' The Gas...Station
Meteorite Man's Avatar
Drives: Same As You But Different
Send a message via Yahoo to Meteorite Man
Wow, How long have I been asleep? That was some read. One thing to remember with the Magnesium Rims. If you ever have a brake fire and those rims start to burn...DO NOT USE WATER!!! flame.gif
KAAAYEFFINBOOM!!! Makes some great sparklers too. Ever see a car with a magnesium motor burn and the fire dept gives it a good dose of water? Nasty!!!
Basically I had nothing to add but wanted chime in. All in the name of safety.
Chuck
MY Gas Station Attendant Misses Me...
Chuck
Meteorite Man is offline   Reply With Quote
Old 07-23-2007, 07:13 PM   #10
Biggie™
Biggie™'s Avatar
If seen tires catch on fire, but never brakes.
Old 07-23-2007, 07:32 PM   #11
Meteorite Man
Well then ya need to open them peepers just a bit more. Not an everyday thing but it does happen. When you drive 2200 miles a week on the highway you DO see things.
Just a comment to get things started? Poke.gif Just like the guy in the exhaust forum that sees "thousands" of Mustangs with loud exhaust getting way with it but "he" gets singled out and ticketed in his Yaris. Hmmmm....Thousands?
Chuck
Chuck
Old 07-23-2007, 08:30 PM   #12
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Forged but like Chino said it can cost ya some jingle.
Need help when ordering my tires and rims thomasward00 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-26-2007 09:40 PM
WTB Factory 15'' Alloys or 15'' Steelies W/ tires tealio Items for Sale by private party 5 04-25-2007 06:34 PM
FS: 07 yaris RS stock rims n tires thegame11 Items for Sale by private party 5 04-15-2007 01:25 PM
hufeisen rims JustYYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-17-2007 03:16 PM
Will S Sedan Alloys Fit on A Liftback? MrMondayNite Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 11-05-2006 01:39 PM
