Old 07-25-2007, 07:51 PM   #1
punch
punch's Avatar
alternator same in scion xb, and yaris???
can someone in the know, look up the part numbers for the scion xb, the yaris, and the echo, to see if the alternators are the same part number...
I have been looking for a HO alternator, and they make them for the scion's including the xb, which shares the same engine...
thanks again
punch is offline   Reply With Quote
Old 07-26-2007, 08:36 AM   #2
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
Drives: 2008 Mazda3 S Sport
Call the Parts dept of your local Toyota Dealer & ask them for the part numbers for each. That will tell you.
BTW, are you looking at the Iraggi one??
Code:
DiabolicJourney_SpaRky
DJ_SpaRky is offline   Reply With Quote
Old 07-26-2007, 05:08 PM   #3
punch
punch's Avatar
I've searched many car audio sites and they recommend staying away from Iraggi...
I have found 1 place but they want $600 for a 180amp alternator...its a rewind...
Old 07-27-2007, 08:46 AM   #4
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
Ouch. What are you installing?? a wall with 12 12"s??
Code:
Old 07-27-2007, 12:50 PM   #5
Duckywitbigfeetz
Drives: 07 Polar White Yaris Hatch-3DR
im looking for something like this too im only running 2 1000 watt 12's (type r's)with a 1000 w rms rockford fosgate amp and my lights dim what else is involved in doing this kind of upgrade i dont want to have electrical problems thanks for the help..
Duckywitbigfeetz is offline   Reply With Quote
Old 07-27-2007, 12:55 PM   #6
DJ_SpaRky
Resident Scion Guy
DJ_SpaRky's Avatar
Get a 2nd battery & a battery Isolator, you'll be fine.
Code:
Old 07-27-2007, 08:13 PM   #7
punch
punch's Avatar
ok, iraggi just emailed me back, if its the same as the echos', and XB then the price is :
180 $399
200 $419
http://www.highoutputalternator.com/ gave me a price of :$649
Old 07-27-2007, 08:13 PM   #8
punch
punch's Avatar
1400watts RMS...
Old 07-27-2007, 08:16 PM   #9
punch
punch's Avatar
Well, I'm new to this also, but have been reading, all site recommend you do the "big 3" which consists of upgrading the alternator to battery cable, engine block to car body, and the batteries ground cable to car body, larger the wire the better...
the route i am taking so far, is a 0 guage wire from the battery to the trunk, splitting to 2 4 gauge wires to my amps...
For now, i will probably use a 1 farad cap, but will upgrade to a high outpout alternator, and dual battery set up.
Old 07-27-2007, 09:40 PM   #10
NonStopTuning
The problem you guys have at idle with dimming lights and weak batteries is because your OEM alternator does nothing at/near idle. Your alternator does not start charging until around 1200 rpm.
Your best bet might be to look for a reputable pulley builder. Such a company would be able to build you an Overdrive Alternator Pulley for your stock alternator. A properly built Overdrive Alternator Pulley would cause your OEM alternator to charge at a lower rpm (maybe 900rpm) and would save you time, hassle, and customization required to fit a different alternator.
Good luck gang!
MIKE @ NST
www.NonStopTuning.com
Old 07-28-2007, 07:30 AM   #11
jdium
Mr Attitude
jdium's Avatar
Drives: Blazing Blue 5 Spd
till your alternator burns up...
It's scary to think that half the people surrounding you are below average...
jdium is offline   Reply With Quote
Old 07-28-2007, 03:40 PM   #12
Duckywitbigfeetz
thanks nonstoptuning i like that idea. has anyone found out what the rateing of the stock is yet and how much would it be safe to jump up with out having to rewire engine power. thats what i was originaly asking if i swap out my alternator what else do i have to change. im going to get a grounding kit and a 1 farad cap and try it but if an alternator swap is necessary i would like to know whats involved.
Old 07-30-2007, 08:26 AM   #13
punch
punch's Avatar
nothing else is needed, just bolt it up....
Old 08-02-2007, 06:25 PM   #14
Duckywitbigfeetz
so the higher amperage alternator wont burn up stock wiring??
Old 08-02-2007, 06:26 PM   #15
Duckywitbigfeetz
sorry i can do all the other stuff and im good with wiring but never upgraded alternator just wanna make sure
Old 02-06-2010, 07:25 AM   #16
papadakis_crete
caraudio freak
papadakis_crete's Avatar
Drives: yaris 2sz
hello everyone!i can see this threat is very old but i want your opinion.I need to change my alternator(i have 14,1 volts without music but in high levels i can fall on12,3volts).what type of alternator should i look for?my yaris is 05/2004..
papadakis_crete is offline   Reply With Quote
Old 02-06-2010, 11:26 AM   #17
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
you can try calling iraggi, I got mine from him but I have an 07.
PG TLD22 8V Line Driver
Old 02-06-2010, 01:59 PM   #18
papadakis_crete
caraudio freak
Drives: yaris 2sz
the problem is at the connectivity because the stock alternator goes through the cpu i think..
