Old 10-23-2008, 10:20 PM   #1
cookfreeordie
cookfreeordie's Avatar
Drives: 08 Yaris LB
My little idea.............
......for an "cooler air" intake option.
Please share your opinions on whether you like the idea or whether you hate it. Hell, let me know if its even worth the trouble.............
Im thinking of running a flexible tube(wrapped in heat res. material) from the intake port on the stock air box to a particular point on the front end close to the radiator.
Ill answer any questions I can.
Here's some crappy PS to help explain(look for the green):
Here's the place i plan on coming out of:
the butcher
Former 08 Black LB
Current 07 Graphite Spec-V
cookfreeordie is offline   Reply With Quote
Old 10-23-2008, 10:33 PM   #2
BrazdonW
What kind of car is that?
Drives: Yaris 3d liftback
a few people have been doing it from the foglight housing. you may avoid heat with that type of application as well :)
Old 10-23-2008, 10:38 PM   #3
bubaa
bubaa's Avatar
Drives: yaris rs
mhhh maybe i can do a proto but someone in here can do this cai in a decent material
bubaa is offline   Reply With Quote
Old 10-23-2008, 10:43 PM   #4
Morgan
Morgan's Avatar
Drives: 07 MM LB
From my stock air box I have a flexible tube from where the "snorkel" comes out straight down to the fog light with a spectre cone filter on the end, $25 from pep boys and it sounds cool!
Old 10-23-2008, 10:50 PM   #5
cookfreeordie
Drives: 08 Yaris LB
i have foglights
the butcher
Former 08 Black LB
Old 10-23-2008, 10:57 PM   #6
i did that w/ the sri on my old xrs....worked well, but was 100% ghetto
Old 10-23-2008, 10:58 PM   #7
battleversiontc
battleversiontc's Avatar
Drives: 08 vip yaris
i wouldnt run it a cross the radiator like that all that hot air = no good i would take the advice of just running it straight down to the fog light hole like everybody else seems to be doing
08 junction produce belta almost done and ready for paint
06 junction produce tc 604 bhp 445tq ddriven still trying for 700+hp
90 crx sir ls vtec turbo 755 hp
mecp masters certified
battleversiontc is offline   Reply With Quote
Old 10-23-2008, 11:53 PM   #8
cookfreeordie
Drives: 08 Yaris LB
I HAVE foglights and I plan on wrapping the tube in heat resistant material.
Would it make ANY difference to do any of this?
the butcher
Former 08 Black LB
Old 10-24-2008, 12:10 AM   #9
dacourier
dacourier's Avatar
Drives: Black Sand Lift Back
Originally Posted by cookfreeordie View Post
i have foglights
I have fog lights to. I know what your trying to accomplish. Do you have an sri, cai or just a stock box?
Clinging to my guns and religion down here in the south. Come and take them!
dacourier is offline   Reply With Quote
Old 10-24-2008, 12:27 AM   #10
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
contrary to popular opinion air does not do well with 90degree + bends lol
Old 10-24-2008, 05:19 PM   #11
cookfreeordie
Drives: 08 Yaris LB
Seriously?
Regardless, the stock "snorkel" has to tight bends so it would be better than that lol
the butcher
Former 08 Black LB
Old 10-24-2008, 05:41 PM   #12
why run it to the other side? is there something in the way of using the near side?
Old 10-24-2008, 05:52 PM   #13
Nexus1155
Drives: Audi
oh youre talking about doing this from the snorkel? screw that thing i took it out the week we got the car...
if you were to do anything i would recommend a dremel and dremel out the bottom of the airbox(but not extremely you will be able to see the lines to cut at). It is done on every single one of my play cars and it has the same results tested as an AEM in most situations, just a different deeper growl...drop in a stock K&N filter and viola top of the line intake without the flashiness!!
Old 10-24-2008, 06:07 PM   #14
ddongbap
Can you prove the same output as a AEM?
Old 10-24-2008, 06:13 PM   #15
kou
Drives: 08 lb
^^^no^^^
Old 10-24-2008, 07:16 PM   #16
cookfreeordie
Drives: 08 Yaris LB
I would remove the stock snorkel and attach my hose to there. Just making the point that the stock has bends in it. I would only have one bend in my set up.
The radiator is in the way.
the butcher
Former 08 Black LB
Old 10-24-2008, 08:09 PM   #17
Nexus1155
Drives: Audi
If I get my car running soon, since i have to swap to an open element anyways, ill get you some logs if you are truly interested. But if HondaLog can log it, i can just buy one of those and then slap a cone on there... but im trying to find the test results done on my car because they tried it before.
I've even done it on my snow mobile. and it is reported that if you open the holes too much then it will decrease horse power from the increased air flow. Same principle applies. I think i would rather have a steady stream of air going directly into the intake from one hole instead of something being completely open and sucking in from all directions...
or i am just me and i have absolutely no idea what i am talking about and talking out of my ass or something...
^^^no^^^
^^^yes^^^
YRX Body Kit - How To Get It ... any idea??? ASHRAF Australia 36 09-29-2007 10:33 AM
Crazy DFCO Idea nsmitchell General Yaris / Vitz Discussion 3 05-26-2007 01:53 AM
Is this a dumb idea...... mgthompson General Yaris / Vitz Discussion 7 03-31-2007 09:17 PM
Tachy Idea HTM Yaris Cosmetic Modifications (Exterior/Interior) 6 01-20-2007 06:09 AM
Muffler Tip ~ Good Idea? jaspie Cosmetic Modifications (Exterior/Interior) 14 01-17-2007 08:34 PM
