#19 |
Only Happy When it Rains
Detonation is also reffered to as knock, pinging, etc.
What it means is the fuel is igniting before the engine is ready for it to explode. If it happens in a big enough quantity it can cause the pistons to be pushed clear out the other side of the engine. This is why modern cars are created to adjust for a bad tank of fuel. The reason to use the octane the manufacturer recommends is because the engine is designed to run on that octane with no detonation. Switching to a lower detonation could cause detonation. Switching to a higher octane should not effect detonation, as there should be none on a stock car using the manufacturers recomended octane fuel. However on modified cars, especially forced induction vehicles, they use the highest octane they can get their hands on because it helps to prevent detonation, not to mention it means they do not have to tune the vehicle quite as much. The biggest reason for modified vehicles having detonation is laziness of the tuners. |
#20 |
Speed Wrenchin'
Drives: 2006 Yaris 3 door, Bayou Blue Join Date: Jan 2006
Hey ToTo, Simply, todays engines are designed within certain parameters to run best on a certain fuel for best performance and low emissions. The engines computor receives signals from various sensors such as how much air is being drawn in and at what temperature. timing, crankshaft position, engine speed sensors, vehicle speed sensor, EGR sensor, air-conditioning sensor, knock sensor which senses if the engine is knocking so the computor can retard timing. Oxygen sensor and on and on. The computor takes all the inputs from these sensors and adjusts whatever is needed to run at "stoichiometric" air-fuel ratio which is the air-fuel ratio which produces the most complete combustion with the fewest harmful byproducts. This gives the best compromise of power, economy and emission control. Now once again if you want to get better performance , you have to change those computor parameters. However, low emission output will be lost.
Quench my thirst with gasoline |
#21 | |
![]() ![]() Drives: None yet Join Date: Feb 2006
Octane is choosen to resist detonation. Here is a link that explains more of what I was trying get at as well as why?: http://www.geocities.com/runyardj/OctaneExplanation.htm
#22 | |
#23 | |
I believe this because all manufacturers use 93 octane in the USA for all the testing. |
#24 |
Acetone used in very small amounts adds gas mileage. Acetone used in too big amounts destroys hoses and anything else in an engine that is not metal.
Note that is around .78 cc per liter or one ounce per 10 gallons. Not more than three oz. per 10 gallons. http://pesn.com/2005/03/17/6900069_Acetone/ "Incidentally, in almost all cases, the lowest octane is best for mileage. Most modern vehicles do not have high enough compression to justify using high octane fuels. The testing indicates best mileage is usually obtained with 85 or 87 octane gasoline. Too much octane causes a loss of power and economy. BUT too little octane causes the same things plus knocking. Listen carefully to your engine for tell-tale knocks or clicks when you start out from a light. The best mileage points to the correct octane when the engine is properly tuned. See your owners manual." |
#25 |
![]() ![]() ![]() ![]() ![]() Drives: 06 3-dr auto RS Join Date: Jan 2006
I would check it out with the dealership first to see if adding this kind of additive to the gas will void the warranty
#26 |
Speed Wrenchin'
You would be wise to stay away from acetone. C'mon gang we are not mixing fuels for funny cars, stick in what ever octane makes you feel better. If saving some money feels good then pour in 87 octane, it's all you need in Uncle Yaris.
#27 |
If it works to increase gas mileage then why not use it?
#28 |
Speed Wrenchin'
Once again it is controversial whether it even helps get better milage, but it is known to destroy certain rubbers. So with the already decent mileage that the Yaris gets, why look for trouble?
#29 |
This dude supposedly doubled his gas mileage in his neon. 40 mpg is good, but if you could get 60, or even 80, wouldn't it be worth a try?
Plus, at the tiny levels used to get the suppsed outcomes, acetone will do nothing to any engine internals. Add to that that acetone costs very little, and I think it is at least worth a try. |
#30 | |
![]() ![]() ![]() Drives: 2011 Rogue Join Date: Jan 2006
http://www.pureenergysystems.com/new...00069_Acetone/ Here's another link.... Sounds like it would be worth a try. |
#31 |
If any members have tried acetone, please post the results. By making this request, I am not recommending or encouraging anyone to go ahead with trying. I just want to know if anyone has tried it and what's the result. I personally would wait until some gasoline additives manufacturers market products that contain acetone so that if anything goes wrong after I have used their products, I can hold them responsible.
#32 |
Speed Wrenchin'
A while ago during a deisel electronics course we got into fuels and additives etc. That's were I heard that some people thought there were milage gains and some not. Acetone does destroy some plastics and rubbers. Possibly this could take some time being so diluted in gas, if it even ends up happening at all. Be very careful of a warranty issue. If you have an engine warranty issue what do you think the dealers going to say if they happen to find acetone in your fuel? Yes you would challenge them about the fact that the acetone actually caused your problem but what a pain in the ass. Another fact mentioned in my class was that if acetone really improved milage so much how come one of the gas companies isn't adding some to their fuel and stating that their fuel actaully increases milage and cornering all gas sales? Just my opinion from what I have heard.
#33 |
Definately a good point.
#34 | |
#35 | |
#36 | |
