Old 11-12-2008, 08:41 PM   #37
Appalachian Trail 2007
Appalachian Trail 2007's Avatar
Drives: 2008 Yaris LB
hey loren, 500snakz says its not possible to even get 48mpg so I'd give up on the 55 dream...
http://www.yarisworld.com/forums/showthread.php?t=10642
3,441,567,453 posts BH (Before Hack)
Appalachian Trail 2007 is offline   Reply With Quote
Old 11-12-2008, 08:58 PM   #38
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Uhhhhhh maybe Bailout will post a link to his gas log...... I think you will be surprised. 55 is high but 50 has been seen by many.
Old 11-12-2008, 08:59 PM   #39
drummerboy2004
drummerboy2004's Avatar
Drives: 2008 Yaris LB Auto
55 is easy in the MT... I have an AT, and have pulled over 50 for a trip longer than 200 miles. Oh, and 48... that should be about city mileage in the MT if you drive it well enough. You can do it!
Matt
drummerboy2004 is offline   Reply With Quote
Old 11-12-2008, 09:00 PM   #40
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
here is Bailout's gas log.....
http://www.gassavers.org/garage/viewgaslog/2128
Old 11-12-2008, 09:01 PM   #41
oh I know, it's 500snakz that doesn't believe
Old 11-12-2008, 09:03 PM   #42
drummerboy2004
You're right...
If you "FAS it up", you can easily exceed that as well...
Matt
Old 11-12-2008, 09:07 PM   #43
drummerboy2004
Wink
Well then... I think we need to put Snakz on a plane! jk
Matt
Old 11-12-2008, 09:11 PM   #44
Matt
(Snakes on a plane...)
hahahaha yeah I got it the first time
Old 11-12-2008, 10:20 PM   #45
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I'm tired of these mother uckin' snakes on this mother uckin' plane!
too many mother uckers
Alright, let's not drag Mr. 500snakes through the mud here. He'll either learn or he won't, but he has nothing to do with this thread... let's be nice to the newbs.
Quick question for those who use FAS and have a Scangauge:
I gather that I need to set my mode to "Hybrid" to get the Scangauge to work properly. If I do that, will the Scangauge then give me accurate readings even through multiple FAS sessions? (no time to really test the theory before Sunday) Or will the ScanGauge ignore some or all of the FAS session and only report the MPG that occurred while the ignition is on?
Old 11-12-2008, 10:30 PM   #46
drummerboy2004
I know I shouldn't, but I have FASed in my car...
It typically stays on while you are turning off the car, and records all but whatever happens while the car is off...
This being said, it fails to record for usually <1sec...
If you have it set to hybrid, you will have no problem... My numbers usually stay accurate with FAS usage.
ADDED: Oh, and during the FAS your MPG will read over 1000, but you are actually using 0 gas, so this may lead to inaccuracies over the course of a long trip. I only use it going to long red lights.
Matt
Old 11-13-2008, 08:00 AM   #47
Woody_Woodchuck
Drives: 2008 Yaris LB 5M
My SG2 appears to record accurately while FASing, I set it to hybrid mode. Turn the key off, until the dome light starts to turn on (about a second or so). I do lose that second of SG recording while the key is actually in the off position but not the entire trip. The SG will continue updating from the numbers you had before keying off then back on. I use it as an estimation tool, not taking the numbers as gospel anyway so that second or so does not matter to me. A quick, light clutch while in 5th (or 4th if speed is low) starts the engine.
I only just started using this technique, so not an old pro at it, but found this works for me.
EDIT: the iMPG readings while in FAS do vary for me not do the 99999 thing. Depending on speed they will vary from 1,000 to 3,000 iMPG.
Woody_Woodchuck is offline   Reply With Quote
Old 11-13-2008, 08:22 AM   #48
drummerboy2004
Originally Posted by voodoo22 View Post
The manual states it's safe to flat tow the Yaris auto for short trips at low speeds on flat surfaces, so you should be ok FASing to red lights.
I've read logs where people who are really good at FASing manuals and P&G increase their mpgs by 20%.
Thanks... (I didn't stop doing it)... I just remembered not to do it for a very long time. I noticed I was trying to go further and further on the FAS (still under 30 though). I like it as well because your car is then off for the light, and as long as you know the lights, you can put it back on, and be ready to roll. Thanks again...
Matt
Old 11-14-2008, 10:32 PM   #49
enkid
Drives: 07 Yaris Sedan
You're going to find it difficult - hypermiling and keeping your overall average speed up to 45 are conflicting goals. You'll probably have to drive above the speed limit for some segments to make up for lost time and stops.
enkid is offline   Reply With Quote
Old 11-14-2008, 11:58 PM   #50
Loren
What?
Loren's Avatar
Yep, it will be a challenge. That's why I set it up the way I did. Where's the fun in doing something that's easy?
The plan is to P&G up to about 5 over and 10 under the speed limit in most places. (traffic permitting) The highest speed limit is 60, about half of the route is 55. The rest is slower, but will balance out. I've already segmented out the route and calculated times based on expected speeds for each segment. It works... now, if I can just stick to the plan!
Old 11-15-2008, 01:28 AM   #51
drummerboy2004
I will try and make it to a future one of these...
I have school-related things the rest of the semester
Oh, and word of advice, if you didn't think to... bring your speed average up by hauling ass (hypermiler haul 60) when you hit the downgrades, that way you do not find yourself having to do this on a lot of the flats. Then you could ride your speed down in a great-length FAS.
Hope this wasn't common sense...
Matt
Old 11-15-2008, 10:07 AM   #52
Loren
What?
Loren's Avatar
Well, it's common sense to an experienced hypermiler. ;)
Tomorrow's the big day. Bought a roll of self-adhesive aerodynamic improver (clear packing tape) yesterday. I'll stick some of that on the car today and air up the tires. Should be good to go.
Old 11-15-2008, 11:40 AM   #53
JnC
Drives: 00 VW Golf TDI
Bought a roll of self-adhesive aerodynamic improver (clear packing tape) yesterday. I'll stick some of that on the car today ...
I'd be scared of packing tape adhesive pulling off the paint when you remove it. Would suggest masking tape instead.
Best of luck!
JnC is offline   Reply With Quote
Old 11-16-2008, 01:53 AM   #54
metalshark
MetalShark
First go get-ya some of them Imperial gallons. The canucks have an edge there....but seriously my last trip with Amsoil 5w-20 got 39.3 MPG with cruise control set at 50% 65 MPH and 50% 75 MPH. In town before the switch to light oil my best commuting was 43 MPG for three tanks straight. I still have to "have discipline" to test for mileage after the change.
Absolutely red, Drawtite hitch, CAI, Insulated Header, Amsoil 5w-30, Mag-drain plug, Red-Line MT-90 tranny oil, Scotch-Guard, Window Tint, Dash rug, Custom short throw shifter, Lowered OEM arm rest, Super-Turbo muffler/w chrome slash cut tip., TRD rear sway bar, sticky pads, front shock tower bar, RS grill badge, VVT-i emblems, Second tire set from Tirerack.com, DISABLED DAY TIME RUNNING LIGHTS, platform- style locking custom bike rack. 86K miles so far. 5 years use now on ceramic wrapped insulated stainless-steel header.
metalshark is offline   Reply With Quote
My progression into hypermiling BailOut General Yaris / Vitz Discussion 8 10-13-2009 06:31 PM
Yaris Color and MPG Statistics/Summary jmharn General Yaris / Vitz Discussion 21 11-19-2008 04:52 PM
Toyota Yaris MPG Review at www.mpgomatic.com aca72 Fuel Economy Forum 23 10-31-2008 03:59 PM
Am I calculating MPG correctly? YarisBlazer General Yaris / Vitz Discussion 24 08-18-2007 11:57 AM
Wow, I Got 48.57 mpg Kaotic Lazagna General Yaris / Vitz Discussion 52 05-10-2007 10:09 PM
