Old 11-13-2008, 07:41 PM   #91
cookfreeordie
cookfreeordie's Avatar
Drives: 08 Yaris LB
My dealership disabled it in about 15 min.
It was the first one they'd ever done
Show them the manual and they can't deny it
the butcher
Former 08 Black LB
Current 07 Graphite Spec-V
cookfreeordie is offline   Reply With Quote
Old 11-13-2008, 11:20 PM   #92
the slot next to the handbrake is perfect for holding a computer hard drive
Old 11-17-2008, 11:40 PM   #93
Tiddlygoose
Tiddlygoose's Avatar
Drives: 2009 Honda Civic Sedan SI
Originally Posted by cookfreeordie View Post
You can have the dealership turn off that annoying beep when you dont buckle your seat belt.
Which dealership? Mine won't as "it deactivates a safety device" I guess they feel that in the event of an accident that we could sue them for turning it off even though we asked for it to be turned off.
Tiddlygoose is offline   Reply With Quote
Old 11-18-2008, 02:06 AM   #94
Latka
Drives: 0x Yaris Hatchback
Or you could do the smart thing and buckle up your seatbelt. :)
Latka is offline   Reply With Quote
Old 11-18-2008, 08:46 AM   #95
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
Unless he's referring to the annoying-ness of the passenger beep... which I find is always going off when i put something heavy in the front seat. Ugh. Or even when i sometimes lean on (put pressure on it) when driving (if im adjusting myself or something, etc)
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic
Jem_hadar is offline   Reply With Quote
Old 11-18-2008, 12:40 PM   #96
eric81
eric81's Avatar
Drives: Toyota Salesman
The rear bumper snaps into place. The car weighs 2200 lbs. The stock muffler comes in and goes out on the same side. The max RPM is 6500. The car stops at 117 MPH. The stock air box has a 1" inlet for air, 2 air filters that are super restraining, and weighs far too much. The engine gets hot after it's been running for awhile. USA Yarii seem to have a cross threaded A/F sensor in the exhaust manifold. The stock header is only 1" in diameter at the smallest point. The rear wiper has a clip-on it that can be broken off or cut off to allow you to change and clean it easier. Some cars do not have a cabin air filter. The stock oil is Synthetic, but the extended warranty only covers regular oil, so you have to pay $8 to get the right oil put in your car. The low jack system really does work. The correct place to plug in a Tach is at the OBD port (where the dealership plugs their thing in to read what your car is doing). The engine travels over 5" when you rev it up. The catalytic convertor acts as a resonator as well as a catalytic convertor. You can change the look of your car simply by scratching it with rocks (I have great kids, and luckily they are still alive... barely). The stock auto can go from 0-60 in 11.6 seconds. The highest recommended speed for the Yaris is 68 MPH. I will post more stuff later. Drive On!
eric81 is offline   Reply With Quote
Old 11-18-2008, 04:26 PM   #97
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Are you sure? I believe there are two bolts.
Old 11-18-2008, 04:26 PM   #98
Sodium Duck
╚══════════RN
Hmm, mine gets cold...
Old 11-18-2008, 08:22 PM   #99
CpKi1g3
High speeds are fun...
CpKi1g3's Avatar
Drives: 07' Polar White sedan Base
Send a message via MSN to CpKi1g3 Send a message via Yahoo to CpKi1g3
yeah same here i can go 115 mph and get off the highway and park the car and it will be a cool inside the engine bay
CpKi1g3 is offline   Reply With Quote
Old 11-18-2008, 09:33 PM   #100
eric81
eric81's Avatar
I guess mine is special. I will have to put that in myt car description. 1.5L LB Special.
Old 11-19-2008, 02:34 PM   #101
erickwen
Yaris Driver
erickwen's Avatar
Drives: Yaris
Yeah, that drives me crazy. The passenger seat used to be my space of choice for carrying milk home from the grocery store; now, not so much.
erickwen is offline   Reply With Quote
Old 11-19-2008, 04:36 PM   #102
Latka
I thought there was a switch in the seat - I know there is for airbags in some cars where it won't set the airbag off unless there's something like 40 pounds on the seat.
Old 11-19-2008, 04:44 PM   #103
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
I just want to know where the crank is for the jack. Its not in the place shown in the manual unless i am blind.
Old 11-22-2010, 03:06 PM   #104
2007yariz
Drives: Yaris sedan
Really? the yaris was filled with synthetic oil in the factory, any links?
Ok if you have power windows and power seat, you can lower your driver seat to flat just like a bed lol.
2007yariz is offline   Reply With Quote
Old 11-22-2010, 07:09 PM   #105
swidd
Drives: Yaris HB
Wait, there's two filters in the air filter box? I've only seen one filter, and replace it regularly. Should I be looking for a 2nd filter as well? 80,000 adventurous miles...
Old 11-22-2010, 08:07 PM   #106
gabriel2012
Drives: 2011 Base Sedan
the second filter is behind the glovebox, look at page 165 of your manual, this is a cabin air filter which just makes sure clean air comes out from the a/c instead of dust and other stuff.
gabriel2012 is offline   Reply With Quote
Old 11-22-2010, 09:45 PM   #107
DebbyM46227
DebbyM46227's Avatar
Drives: 2017 Yaris IA, Pulse Red, Auto
I don't have a link about the oil, but my car was purchased new in June this year and the oil is / was clear...I could hardly see it on the dipstick. After being driven 3000 miles, the color is now light tan.
I'm wondering about the other statement.....where is the link that the maximum top speed should be only 68 MPH?
DebbyM46227 is offline   Reply With Quote
Old 11-23-2010, 12:20 AM   #108
djct_watt
Drives: 2010 NCP91 5spd
Originally Posted by Bella View Post
Sorry guys, I'll post some directions with pics to make it a bit clearer, I'm awful at describing things! This is for the hatchback/Liftback with the digital speedo only, as far as I am aware!
1- Turn your car on to either 'on' or 'start'.
2- Turn on your headlights.
3- Press the same little button that you press to flick through your trip meter.
4- Flick through 'Trip A' and 'Trip B' til it shows up lines like this.
5- Hold down the button and it will flick through the different levels of brightness.
I hope this helps, excuse the blurry photos!
Someone with a sedan or a hatchback with an analogue speedo could confirm whether this is the same in their cars?
Cheers!
I have the same indicator (weird bars graph thingy) on my trip meter as well, but I have a Thai model hatch with an analog optitron (white) with tach. Gonna try this as soon as I get off work! I always wondered what those stupid bars are. . . and the (English translated) manual states nothing of it.
The best modification you can make is between the steering wheel and driver's seat.
Interesting Info on the Yaris from AU mikeukrainetz General Yaris / Vitz Discussion 3 11-24-2006 10:18 PM
