Old 12-02-2008, 09:57 PM   #1
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
A/F Question
I've noticed on my blitz rvit that when i am driving the a/f normally stays around 14 but when i come up to a stop sign or stop light and i pull the car out of gear and into nuetral to coast the a/f jumps up to 17 and stays there till i hit the brake or go back into gear. is this normal?
Old 12-02-2008, 10:12 PM   #2
hitting the brake changes your air/fuel ratio while in neutral? hmmm.
Old 12-02-2008, 11:02 PM   #3
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
It could be some kind of fuel economy feature...
Old 12-02-2008, 11:23 PM   #4
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
Yes the car is just saving fuel at idle conditions. I wouldn't worry about it.
Old 12-02-2008, 11:25 PM   #5
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
17:1 should throw a CEL though.. well at least it does in my car :(
Old 12-02-2008, 11:36 PM   #6
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
DFCO leans AFR on coastdown/stop for economy i suppose that is happening? Might want to read more on it, it activates different in different cars..
Old 12-03-2008, 12:40 AM   #7
whooppee777
just reporting the facts and not just in neutral but also when i take my foot off the throttle completely while still in gear too. my guess is it has something to do with vacuum.
thats what i thought too but y does it change when i hit the brake? if it were something bad it should set a CEL. so until it does i'm not worried.
does the scan gauge 2 give a/f readings? if so can someone with a near stock yaris or near stock yaris let me know what it reads under these same conditions?
Old 12-03-2008, 02:50 AM   #8
I don't think the scangauge does a/f. I know the blitz r-vit does -- whoopee didn't you have one of those installed at one point?
Old 12-03-2008, 03:32 AM   #9
turboyaris
Drives: 2007 Yaris Sedan
Send a message via AIM to turboyaris
its not uncommon for an AF to read 17:1 when the engine isn't under any loads. if there is no real load on the engine, the likelyhood of detonation is less, not too mention, that detonation would happen around the same time as ignition spark anyways, as the timing as adjusted too... at least this is what I have been told. It more has to do with the throttle being closed and all then hitting the brakes I presume. Is your car manual?
I know on my tune, when I accelerated it was tuned to 12:1, then if i was just cruising at speed it was around 14:1 and as you said it went above that for idle and no load situations. The reason I was told is also to clean the plugs and engine out as I guess it burns any reminant fuel that hasn't already been burned off.... if that makes sense
turboyaris is offline   Reply With Quote
Old 12-03-2008, 10:40 AM   #10
whooppee777
i have the r-vit. i know not too many others do. i know more people have scangauge 2 but not that it matters considering it doesnt read a/f
Old 12-03-2008, 06:47 PM   #11
richardholdener
Drives: 2008 Yaris hatch
The reason the A/F ratio changes under decel is that the injectors are switched off completely under this condition. They are switched back on to keep motor from stalling and keep idle stable. The idle air/fuel should be 14.7:1. Toyota does not run leaner mixture at idle (emissions reasons).
richardholdener is offline   Reply With Quote
Old 12-03-2008, 07:05 PM   #12
whooppee777
excellent. i am completely worry free now. thanks richard
Old 12-04-2008, 02:47 AM   #13
it's the hitting the brake part that I still don't get. I understand DFCO conditions.
Old 12-04-2008, 02:44 PM   #14
whooppee777
what the hell is DFCO?
Old 12-05-2008, 01:17 AM   #15
whooppee777
Originally Posted by camelll View Post
Deceleration Fuel Cut Off. It is a fuel economy feature.
http://www.yarisworld.com/forums/showthread.php?t=4248
then in that cae...
I am assuming when he is applying the brake he is below 1000 rpm, so DFCO is gonna is gonna quit and he will see normal conditions on his a/f readings. When he puts his car back in gear again I am assuming he is hitting the gas which also will stop dfco.
Gotta love assumptions. Maybe whooppee can shed some light.
yes rpms below 1000 when braking and yes hitting the gas when putting into gear.
good to know my dfco is working properly
Old 12-08-2008, 05:36 PM   #16
whooppee777
i dont know how to get the r-vit show mpg. i see fuel economy in the menu somewhere but it needs to be configured some how i guess buuuuut the manual was in japanese. so shit
Transmission Question CMR General Yaris / Vitz Discussion 42 04-14-2010 01:38 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 04:59 PM
dealer trade-in payoff question.. kapo New YARIS Purchase Forum 1 07-16-2007 11:27 PM
Question about 2 kinds of TRD springs & rear strut bar Astroman Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-18-2007 06:44 PM
catalytic converter question SamDaYarisMan Performance Modifications 14 09-08-2006 11:18 AM
