Old 12-04-2008, 10:00 AM   #1
Mikeb Yaris
Drives: 08 Sedan Base Auto/PWR BLK
5K maintenance
Okay, I just hit 5K miles and my little maintenance light came on. I presume it's tied directly to the odometer? Anyway, I've misplaced my manual. What is called for at 5K miles and can it be done somewhere other than the dealer and still get the light shut off / reset?
Mikeb Yaris is offline   Reply With Quote
Old 12-04-2008, 10:11 AM   #2
lita_g
lita_g's Avatar
Drives: 2008 Yaris HB
I'm not sure about how to reset the light, but these links might be useful if you lost your manual:
http://smg.toyotapartsandservice.com/index.php
http://www.toyotaownersonline.com/
lita_g is offline   Reply With Quote
Old 12-04-2008, 10:39 AM   #3
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
Yes, you can have it done anywhere and the light is easy to reset.
Just as a suggestion. You should have some of your oil changes done at the dealer to allow a set of currently trained "Toyota eyes" to look at your car.
My local dealer actually charges less for the lube, oil & filter than the local jiffy lube/speedi lube....... and my dealer washes my car too.
Old 12-04-2008, 11:08 AM   #4
Chupacabra
Drives: 2009 Yaris liftback
I don't let the dealer wash my car....that is a scary prospect. when they washed/prepped my wife's Scion they scratched the hell out of it. So much so...I had to go back and have the body shop buff them out.
5K miles should need no inpsection other than stuff that you could easily do visually. Don't forget...this is a Toyota. It'll go forever and unless you abuse it.....you are way early for any window of failure or play in semi-critical to critical parts. Clear the light and keep on motoring!
Chupacabra is offline   Reply With Quote
Old 12-04-2008, 11:53 AM   #5
Mikeb Yaris
Anyone know if I can clear the light myself?
Old 12-04-2008, 12:40 PM   #6
Mikeb Yaris
Awesome! Thanks!
Old 12-04-2008, 12:58 PM   #7
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I dont seem to have this maintenance light on my Cdn 08 Yaris,could it be you are referring to the Check engine light?if so you could be getting a warning of more than just an oil change..It would also be a good idea to find that owners manual and read it as there is a ton of informative reading to be had,at 5k its probably still in the glove box.
Old 12-04-2008, 05:04 PM   #8
bigjohn2ca
Fire Dancer
bigjohn2ca's Avatar
Drives: 2008 Yaris S HB
My light came on at 4500 miles...anyone else's come on early? And I have a friend of mine that works in the service department at a dealership...so my services only cost me a couple pitchers after he's done....BOMBDIGGITY!!
Eat, Drink, and Be Merry
bigjohn2ca is offline   Reply With Quote
Old 12-04-2008, 05:18 PM   #9
lita_g
lita_g's Avatar
I did the 5K scheduled maintenance at a little after 3K, to get rid of the original oil sooner. I was able to do it all at home, my husband helped me out and taught me how to do it, it was much easier than I thought. Just changed oil, rotated tires, inspected the breaks and made sure all fluids looked ok, that's pretty much all you need to do at 5K according to the manual.
Old 12-05-2008, 12:11 AM   #10
b_hickman11
Drives: 08 Sedan
It starts to flash at start up for about 10 seconds every 4500 miles. After 5000 miles, it will come on and stay on.
Old 12-05-2008, 12:12 AM   #11
b_hickman11
Drives: 08 Sedan
This is light is only on the USA Yaris.
Old 12-05-2008, 09:10 AM   #12
Forrest
Drives: 08 LB BLACK
Our light flashed around 4500 miles then stayed on. Ususally do own oil changes but since dealer does it for free, took it back to them for this. Of course, they rotate tires and charged 21$ for that. They top off all fluid levels and do general inspection. So no hassel of doing it myself and did not mind the 21$ fees.
Forrest is offline   Reply With Quote
Old 12-05-2008, 10:11 AM   #13
1stToyota
1stToyota's Avatar
The Toyota dealer here was honest enough to tell me that they use bulk oil, even though my 5K oil change was going to be on the house I told them no thanks. Besides changing the oil and rotating the tires at 5K I cleaned my battery cables. Already had a good acid buildup on them, brushed some silicone grease on the cable ends and posts, no more problems now with the corrosion.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 12-05-2008, 12:13 PM   #14
samfig
reduced to mediocracy
Drives: black 2008 Liftback
What oil should the dealer be using in the cars?
samfig is offline   Reply With Quote
Old 12-05-2008, 12:29 PM   #15
jambo101
jambo101's Avatar
He will probably be using a known brand of non synthetic oil that is pumped out of 50 gallon drum,probably a Castrol product.
You could ask him to put in Synthetic,in which case he will use a known brand from quart containers probably Mobil1
He will probably be using a 5w-20 or 30 weight oil.
Old 12-05-2008, 12:36 PM   #16
1stToyota
1stToyota's Avatar
...uh, how 'bout Toyota oil, at the Toyota dealership?
Salesman said it sure wouldn't be that, probably figure on it being Pennzoil.
No thanks and no wonder it's free.
2008 Scion xD
Old 12-05-2008, 12:41 PM   #17
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
Free? They're trying to charge us 70-80 bucks a pop for their 5k maintenance "special." I feel sorry for the folks who depend on dealerships for maintenance needs.
Old 12-05-2008, 01:54 PM   #18
TheSilkySmooth
TheSilkySmooth's Avatar
The bulk oil should be ok as long as its not the pennsoil/qs/kendall recycled stuff. I have actually had BETTER luck with bulk valvoline and M5000 than stuff I got in the bottle at AZ. It must be batch sensitive. You dont know unless you try. A sniff is a good start - the bulk pennziol SMELLS like waste oil. Yecchh.
The Bro
Toyota Maintenance at Dealership? fmicle DIY / Maintenance / Service 18 03-17-2012 12:27 PM
Results from 100,000 maintenance Nigal DIY / Maintenance / Service 22 11-26-2008 01:41 AM
Question about required maintenance gm830 DIY / Maintenance / Service 9 11-04-2008 04:14 PM
how much does the first maintenance service cost hans_fh DIY / Maintenance / Service 25 07-05-2007 11:01 AM
Do I need to hava a 1000-mile maintenance service?? hans_fh DIY / Maintenance / Service 3 11-24-2006 07:13 AM
