![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
How did you run the wideband A/F cable into the car?
I just got a wideband A/F gauge and the sensor unit needs about a 1 inch hole to feed through. The other end is a rectangular plug and needs a 1 1/4" square hole.
I figured the 1" hole would be easer. I'll be getting a bung welded to my midpipe right after the Megan header. The exterior cable with the two ends mentioned above is only about a foot long. Is there a large enough feedthrough that exists or did you guys drill new holes into the car? TIA
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
Who said Yaris was slow?
should move this to the FI section
It applies to anyone who wants to install gauges but is looking for a DYI on running wiring into the interior.
BTW. I've already used the hole in the firewall that is next to the ECU.
Is there a rubber floor plug? Sorry, I no longer own my Yaris. Also, You could buy a correctly sized rubber gromet and get a 1inch hole saw drill bit...
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
passenger side, where the floorboard meets up with the firewall there is a hole and grommet that you can use.... I seem to remember, but I am not sure, as I no longer have my yaris anymore and the wife will not let me lay a hand on hers
Thanks, Red and Black Yaris. I'll look under the car.
what did you end up doing for this?
I haven't. It took me too long to change the plugs and the intake, plus clean up the S/C cable that I did not get a chance to get to it. I can't have anything loose in the car for AutoX and having a gauge laying on the floor won't cut it. I think I'll get a chance next Saturday and will take it to the muffler shop. It should be easier to see my options when the car is up on the lift.
i cut the stock o2 sensor grommet open (secondary) and slipped the wideband in with stock wiring, then glued it back shut
| big older car vs little newer car | xed | General Yaris / Vitz Discussion | 9 | 09-16-2007 05:35 AM |
| New Siphon Mag: Yaris vs. xA vs. Versa vs. Fit @ Streets of Willow | Ran Kizama | General Yaris / Vitz Discussion | 9 | 06-18-2007 01:42 AM |
| where to run amp positive cable??? | punch | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 12-21-2006 08:50 PM |
| Harman Kardon Drive + Play for IPOD | sroberts | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 07-01-2006 02:05 PM |
| Buying a first car..lol | Blenjar | Off-topic / Other Cars / Everything else Discussions | 11 | 06-14-2006 12:58 AM |
