Chip Hack!
Yo Guys,
I found something and I want you guys to have a look at this, maybe this can help with turbo charging or adding a blower... http://www.powerenterpriseusa.net/pr...con/camcon.htm Let me know, I want to do the turbo kit preferably as I can install this my self! I just need some info... and I am not doing anything if the ca can not be tuned, I need full capacity..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() :e vil:![]() ![]()
--------------------------------------------------- “Do or do not... there is no try.”
toyota
wow that was an interesting read for me...hmmmm
better to get this than the blitz controller.. |
SIPNDEW
http://www.yarisworld.com/forums/showthread.php?t=11471
blitz unit and camcon are NOT the same thing |
#4 | |
toyota
SIPNDEW
the camcon you have to tap into your wires that go into the ecu. the blitz unit attaches to the tps on the accelerator pedal. you can have both if you choose, the blitz unit will override any throttle changes made by the camcon though if any at all. the camcon controlls the valve timing it appears.
toyota
oh i see...
SIPNDEW
the instructions seem pretty straight forward and i was curious about this unit myself, so if you go that route keep us updated. i would love to know someone who has it on a yaris. :)
I wil try and get hold of it and let you guys know, I just thought that
it was quite interesting.... Since it controlls A\F, VVT-I and Throtle.... It could be perfect! because it was tested on the Scion and Yaris and worked! THat is a top A if it works! I am in SA so it might be hard getting this... But I have some connections.
SIPNDEW
the camcon will not do anything with your throttle input. it only controls a/f and vvti
Break'em off some.
You still can't adjust timing advance, which is critical.
yep, that's what it says. and that it's designed to work with vvt-i
![]() ![]() ![]() ![]() Drives: 07 metmet LB Join Date: Oct 2008
hey garm i'll save you the trouble......
Buy it, try it, give us a DIY !!
F5 CAI, MR axleback, MR Header, NST SSK. Full Exhaust wrap, AT3 Custom SSK Konig Heliums 15x6.5 Black Tanabe Df210's |
Break'em off some.
Sorry, was not clear enough.. It does not allow you to adjust ignition timing. Adjusting the VVTi cam timing is nearly useless. This is the same technology that the Honda guys ran 10 years ago.... This does not excite me.
| Another post hack pic | Ryu | Photo-Video-Media Gallery | 25 | 07-19-2011 09:26 AM |
| HOW WAS THE LAST HACK??? | willytompkins | General Yaris / Vitz Discussion | 12 | 11-12-2008 10:36 PM |
| Performance Chip | njyaris | General Yaris / Vitz Discussion | 5 | 07-04-2007 01:19 PM |
| Performance Chip *to funny* | Imagine | Off-topic / Other Cars / Everything else Discussions | 11 | 05-04-2007 02:22 PM |
| Umm, is this a rock chip? | fantabulousbaby | General Yaris / Vitz Discussion | 7 | 01-26-2007 10:22 PM |
