#19 |
Beast
Tokico +1
![]() One you've taken a yaris for a spin, there's no turning back. Its a Chao!!! Last edited by TheRealEnth; 12-18-2008 at 02:33 AM. |
#20 |
Your mom goes to college
Drives: 08 Vitz Join Date: Oct 2008
Gr-2 's are only a good "upgrade" if you blow your stock struts/shocks out . Imo stock shocks are better . If you need to go with gr-2 don't pair them up with any spring lower than like tanabe nf210's or they'll blow-out in about 2 months . Bare mininum go with a set of blue's or save a get some megan or basic tein coilovers , only about 250 more than the 500 a set of blue's/tein s tech's or tanabe springs will cost you .
#21 |
![]() ![]() ![]() Drives: 08 toyota yaris LB Join Date: Oct 2008
tokico ftw!
#22 | |
![]() Drives: YARIS Join Date: Dec 2008
Thanks for reply. Well, what about Tokiko shocks? It's can be match with lower spring, right? Thank you |
#23 |
Yeah Tokico blues are the best for the price . I 've ran blues on 3 differnt car's i've owned all with at least -2 lowerd springs and never blew a strut out . Good performance strut and pretty "firm" feeling over stock.
#24 | |
Well, Tokico will a bit/much stiffen than original shock? Thank you |
#25 |
Here is my car.
#26 |
more
#27 | |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
If you want a ride similar to stock damping go with GR-2. The TRD shocks will rattle your fillings loose in comparison. Much firmer with resultant incredable handling when teamed with TRD springs and swaybar.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
#28 | |
Thank for reply Well, blacksandiegovitz said that GR-2 will blow out if I put it with lower spring. GR-2 can use with lower spring? Thank you |
#29 |
Ok, in plain english:
I have stock shock(dead) TRD Sportivo Springs. I do NOT want a harsh ride anymore. So Im assuming that by going with anything other then a stock shock will make things MUCH worse then they were when I first started this setup. If thats the case, does anyone recommend getting NF210's and a firmer shock? Or is it a bad thing to combine softer springs with firmer shocks? Someone please enlighten me because I do not want to lose the drop the TRD springs gave me, but the ride is just getting on my nerves. Or maybe new firmer shocks will improve the ride then what it is now? (My tires bouce on the road at times, I feel it, and it slides even with dry pavement over little bumps, its bad!!!) I guess its time for new shocks, but I dont know what to do!!!!!!!! I live in NYC and I drive a lot, and every block has some tie of bump within a 20mile radius. lol |
#30 |
Well, I think i will go with Tokico Hp Series. It's suitable for lower spring, isn't it?
Thank a lot for all recommends. |
#31 | |
#32 |
Break'em off some.
Drives: 07 Yaris LB, 04 Cobra Join Date: Jan 2007
Yes. The car will be a little firmer, but a lot more stable. It will ride fine, but stiffer than the stock shocks.
#33 |
Break'em off some.
Ok there is a lot of misinformation here.
Tokico HP (blues) and the TRD KYBs are NOT the same. Tokico does NOT make the Sportivo TRD dampers. I have rode in cars with both setups, and they ride similarly. Both are designed to be used with stiffer springs, which is why they are valved stiffer. I would not call either setup "harsh" or "too stiff". The damping will be a good match to the spring rates of quality lowering springs. The car will feel more sure footed through turns, more stable in the wind, and over bumps, and will rub tires less over bumps. You will feel more bumps in the road. It is just the price you pay for increased handling. If this means anything, my girlfriend could not really tell the difference in ride from the stock dampers to the Tokico Blues. If you guys have ridden in EVOs, STIs, 350Zs etc, the car will ride BETTER than those types of cars with TRDs or Tokico HP (blues) and lowering springs. If you think that the TRDs rattle your fillings out or are unliveably stiff you should probably should trade you Yaris in on an Avalon. Unless you are on dirt roads in a 3rd world country, it just isn't that bad. If you want to save some money, get the Tokico Blues. They are over $100 cheaper than the TRD pieces and do the exact same thing. KYB GR2s are good stock replacements. They are usually just very slightly stiffer than the stock dampning. You probably won't even notice the difference. These DO NOT blow out in 2 months, they are just as good as what came on the car. If you want factory replacements and a decent price, GR2s are what you want to get. |
#34 |
Well, what's about compare between Tokico Hp series and Trd Sportivo, which one is more better, stiff, stable, and smooth.
As I need, I need stable and not much stiff. I don't like when the car sway after run over the brige. My friend told me that Trd Sportiva is smooth and stable (but price is too high for me). Then, which one would you recommend me? and sorry that asking you guy a lot because I have on idea about which shock is the one i want. Thank a lot |
#35 |
der Zeck
Drives: '05 Audi A4 1.8t quattro Join Date: Sep 2006
coilovers........ done
#36 | |
Break'em off some.
| Fire Extinguisher Recommendation? | stran | General Yaris / Vitz Discussion | 7 | 12-10-2008 11:12 PM |
