![]() ![]() Drives: Flint Mica AT Sedan Join Date: Nov 2006
Accelerator Problem
Started the Yaris today. It turned over but when I press the gas pedal no response from the engine. Any help, please? Possible fuses? Is my computer fried?
TIA. :-) |
Parallel Parking Pro
In between the last time that you started the car successfully, and now, did you do anything to the car?
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
Make sure there is nothing stuck under the gas pedal like the floor mat or a small puppy.
Or a hickman.
He said the engine turned over but it wouldn't start. If the car was in a gear other than P the starter motor wouldn't even work.
The Martian
Wait so did it start and the pedal was unresponsive or it didnt start?
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker. |
#9 | |
![]() ![]() ![]() Drives: 08 LB BLACK Join Date: Oct 2008
Sounds like he means, car started but when he pushed the gas pedal, no rev from the engine. Atleast it sounds like he means that. |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
if anything the pedal needs to be checked...as the actual pedal internals may have failed.....(drive by wire)
![]() Drives: 2007 Yaris Sedan Join Date: Sep 2007
Sounds like a TPS-Throttle Position Sensor. Pretty common on drive by wire accelerators these days. If you had a scangauge, you could verify by seeing if your TPS reading changed when you step on it.
Generally its a whole pedal assemble replacement, not positive on the Yaris though. |
I think tinkerbell got stuck in the throttle body.
In most AT cars, it can only be started when the transmission is disengaged, ie the car won't start surging forward the moment you start the engine. As I never owned an AT Yaris I'm not in the best position to say if N would start the car, perhaps it would because the transmission is still disengaged.
When an MT Yaris requires the clutch to be depressed to the floor to engage the starter motor, I would be surprised that you could start an AT Yaris in gear, or even neutral for that matter.
How did this turn into a thread about starting when its really about the Accelerator?
#17 | |
You're probably right and I don't doubt you on that, I'm just saying that I'd be surprised.
