![]() ![]() ![]() Drives: 08 sedan at Join Date: Dec 2008
Who here has done oil change without a jack???
i mean, the drain plug is so conveniently located near the front bumper, i can just sttick my head in and turn it with my ractchet
![]() ![]() Drives: 07 BB Yaris Join Date: Aug 2007
I have never use jacks/ramps to do an oil and filter change on the Yaris.
Compulsive Washer
wtf
My yaris has stock suspension and I can't even start to get under there. But hey, if you fit, go for it. I know I would. |
#4 | |
No dealing with jacks/ramps and it is safer. |
![]() Drives: 2008 Yaris RS 5-dr HB Black Join Date: Nov 2008
I avoid the jack all together and just use my horn. I tap it gently and the dealership opens the bay door.
Yes... ...even as I write this I KNOW I'm being a winky stick but...I...just...can't...help myself. Seriously though, kudos to all you DIYs who save a buck and gain a sense of pride. Cheers. Last edited by Chrsto4; 12-29-2008 at 10:08 PM. Reason: Tweaking |
My car is lowerd so cant really fit under there. But i park it on my driveway so its already slightly angled. THen put the jack under the lift point on the passanger side front. Brings the front end enough to fit under there easily.
![]() ![]() ![]() ![]() Drives: '08 Yaris sedan , '08 Liftback Join Date: Oct 2008
use homemade wooden ramps . 2" (h) x 12"(w) x 36" long with one end cut at an angle ( to drive up ) and a 2 pieces ( stopper ) of 2"x2"x12" , which 1 is nailed / screwed to each end of ramp to stop car from going over the edge . Make sure it's not split or too many knots for strength . Would think pressure treated be best to endure weight .
![]() Drives: 2007 Yaris Sedan Join Date: Sep 2007
I've done an oil change w/o ramps or a jack a couple times and did a filter swap topside with the hood raised. THE reason I bought this car was long term cost of ownership. The ease of working on it is a huge benefit, too.
TRD suspension = I need me some jack stands!
I jack up the driver's side and then go to town.....
Drives: 2008 Yaris Join Date: Oct 2008
Trivial - you get an oil pan no higher than about seven or eight centimeters. You buy a wrench for the bolt (I think it's a 17mm but am not certain) and an oil filter socket.
I routinely do my oil in the street without a lift. One of the reasons I bought this car was for this reason. Gene |
WFO
Drives: 2008 hb Join Date: Oct 2008
i use ramps, makes life a lot easier, i ain't no "youngster" so i have learned the easier the better
![]() Drives: 08 Yaris HB manual Join Date: Oct 2008
I dont use jacks or ramps.. I am 6 foot 200lb and i can get it done.
i can almost do it on my knees and just reach under with a socket wrench.. when the bolt is loose take the wrench out slide the pan under and take the bolt out with your fingers. |
Parallel Parking Pro
A Fumoto oil sump drain valve makes it a lot simpler.
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
What brand / types of pan to drain the oil into fit under the yaris w/o jacks ramps?
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
You have the valve? Did you need to put anything around the threads? Waiting for my next oil change to put it on.
#17 | |
homemade ramp ...
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
I do
Making a decision without following it with an action is still a fantasy. |
| DIY: CHANGE MANUAL TRANNY OIL | ttufrosty | DIY / Maintenance / Service | 157 | 09-07-2018 01:43 PM |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 09:22 PM |
| Oil change time... yay! | YarisFan007 | DIY / Maintenance / Service | 10 | 09-19-2007 05:40 AM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-07-2006 11:21 PM |
