Old 01-23-2009, 10:22 PM   #19
kimona
kimona's Avatar
Drives: 2014 White VITZ
I love the Mini's lights. Let's get a photoshop of that configuration on a Vitz.
I don't think that application would be too difficult on the Vitz.
Old 01-24-2009, 12:17 AM   #20
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
I want someone to photo-chop an interceptor police light bar on the little Yaris.
Old 01-24-2009, 12:25 AM   #21
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
Rally Yaris would be so cool.
Old 01-24-2009, 12:50 PM   #22
Split
Drives: 2008 Yaris Sedan
i dont understand why anyone would want this.. i personally think it looks really bad. why not just put hids in your headlights and fog lights?
Split is offline   Reply With Quote
Old 01-24-2009, 01:43 PM   #23
SailDesign
Drives: .
Luckily, not everyone like the same things. It's what makes the world fun.
I personally find underbumper "fog lights" to be a useless PITA, since any ilttle bump means they don't shine very far. I would much rather have the extra light at the same height as the heads.
You say "tomayto", and I say "tomahto".
Old 01-24-2009, 03:03 PM   #24
andruboz
boohachimono
Drives: 07 hb
Send a message via AIM to andruboz
these would be easier to stuff in the grill hella ff75
andruboz is offline   Reply With Quote
Old 01-24-2009, 03:24 PM   #25
Snyprwlf47
The Martian
Snyprwlf47's Avatar
Drives: 07 Yaris 3dr
Send a message via AIM to Snyprwlf47 Send a message via Yahoo to Snyprwlf47
I have a sketch I just did but I cant the scanner to work. I should have it soon though>.< My general idea is 4 round lights on the bumper itself right below the grille and then 4-5 Baja style lights on a low profile bar im fabricating that would fit on the roof. I will probably have to invest in a beefier alternator and an optima battery^-^
"The lead car is absolutely unique, except for the one behind it which is identical." – F1 commentator Murray Walker.
Snyprwlf47 is offline   Reply With Quote
Old 01-25-2009, 10:22 PM   #26
jonismyname
Drives: 08 liftback 5spd
i picked up a set of truck driving lights from NAPA, trucklite brand, but small profile rectangular (3x5 i believe). drilled holes vertically in lower grille, mounted lights hanging down. i left everything loose so i could manually adjust, and once tightened everything's holding up well enough. over bumps you can see it flex a bit when the lights jump, but they're light enough i don't expect any damage or trouble.
larger lights could be supported via the "bumper" or bumper mounts behind the plastic bumper cover....
ill post pics once i get around to taking them, i also installed an air horn at the same time that pulls around 10 amps and fits behind the grille...
jonismyname is offline   Reply With Quote
Old 01-26-2009, 12:02 AM   #27
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
C-ONE makes a rally light bar for other models of the yaris that you may want to look at.
Ever blown out an R-200 diff god know's I have
ztrack157 is offline   Reply With Quote
Old 01-26-2009, 12:04 AM   #28
ztrack157
ztrack157's Avatar
http://www.rhdjapan.com/jdm-low/C-ON...Pod-Vitz-52234
EXPENSIVE AS HELL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!11
lights offroad
