Old 01-25-2009, 08:12 PM   #37
Black Yaris
der Zeck
Black Yaris's Avatar
I love this thread..... yellow tops are not made for everyday use.... they are meant as a back up battery, not to start a car on a daily basis
Old 01-25-2009, 09:46 PM   #38
The Architect
Give Me Resonance
The Architect's Avatar
Drives: 2007 Yaris HB
So far the new yellow top is drastically better on all fronts.
The old one was giving 12.1-12.4 volts with the car turned off whereas the new one is a solid 13 volts.
I got an alternator and battery tester and will be buying an agm charger soon to keep it at its tip top.
PG TLD22 8V Line Driver
Old 01-25-2009, 11:42 PM   #39
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
my blue top rested at 13.2-13.4 without using a trickle charger. Its all about having a good alternator... I was running a 160amp alt.
Old 01-25-2009, 11:45 PM   #40
The Architect
Give Me Resonance
if only a HO alt could be made, I thought we had a person on YW who got a 180amp made for like 500 bucks but i contacted one of the high profile custom alternator makers and he said that a HO alt isnt available for our cars yet because our alternators use a sort of square pin wiring inside or something like that as opposed to the traditional round wiring.
Old 01-26-2009, 12:25 AM   #41
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
go to an alternator shop, and see if you can talk to the guy who does alt re-builds... Try and see if he can build a new alt using the stock casing. Tell him you want a high output alt, NOT A REWOUND alt. Something that can do say 120amps or more at 2000rpms. yeah it'll cost ya... I paid $400 installed on mine for my mazda back in like 03.
Old 02-14-2009, 02:41 AM   #42
mo_feezy
Drives: 08 Yaris S Sedan AT Black
It might just be going bad. I had a yellow top for 5 years and when it was time to go, it was time to go. How old is it?
mo_feezy is offline   Reply With Quote
Old 03-04-2009, 08:45 AM   #43
goku87
goku87's Avatar
Drives: Black HB
so about these blue tops. i knot they are classified as "marine" but what does that really mean. what's the difference between a blue deep cycle and a yellow deep cycle. if it's cold temperature tolerance that would be wicked awesome. ak gets a tad cold every now and then.
goku87 is offline   Reply With Quote
Old 03-04-2009, 11:09 AM   #44
IllusionX
Drives: 07 Yaris Sedan Aero
get a red top to use with the car starter, deep cycle batteries are not made to start up..
Old 03-04-2009, 10:48 PM   #45
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
deep cycle is deep cycle. its meant to sit in active and hold a charge for a long period, then get hit with a powerfull alternator or charger and not blow up.
sorry, but most car owners with audio systems have over 1000 watts of amplifiers sucking the ever living life out of their battery and forcing the alternator to do as much as it can to keep the battery charged up. a car battery needs to be able to handle the draw of daily starts, and never have to be hooked to a battery charger, and still power the audio system.
a deep cycle battery may work for the job, but its not a good move to use one in a car, because the sucker will die long before it would in a boat or RV.
if you wanna use two batteries, with the deep cycle stashed in the trunk and wired to your normal battery and charging system for those days when you want to pound the crap out of your subs and not have to worry about frying your alternator, good for you.
if you wanna toss a yellowtop in a car with a stock charging system, stereo gear, HID headlamps, and a underdrive pully...well, expect the battery to fail.
simple as that. anything else beyond this is just hashing the same crap thats been said in the last 3 pages of this post.
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 03:12 PM
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 03:57 PM
PIAA H11 Yellow Halogen Bulbs for Fog Lights Benggolf2 Cosmetic Modifications (Exterior/Interior) 6 10-02-2009 10:01 PM
Want to build Yaris to a top 10 auto-x car anonymous user Tracking, Racing, Auto-X Forum 50 01-29-2009 02:02 AM
Has anyone purchased a new 09 YELLOW Yaris HB? Carrot Top General Yaris / Vitz Discussion 6 10-29-2008 09:37 AM
