Old 01-23-2009, 05:54 AM   #1
navygm
Drives: Vitz Rs
yaris fog lamps
Hi,
anyone knows from where I can get a set of fog lamps for a Yaris year 2000??
except from the toyota themselves which they sell them expensive!
thanks
navygm is offline   Reply With Quote
Old 01-24-2009, 07:16 AM   #2
Chaubii
Chaubii's Avatar
Drives: '07 Silver YRS
Yo,
I got fogs for my 2007 yaris from Jimcat for pretty cheap. I've had them for about 6 months now couldn't be happier. So yeah hit up Jimcat and I'm sure he can set you up.
Chaubii is offline   Reply With Quote
Old 01-24-2009, 09:42 AM   #3
navygm
Drives: Vitz Rs
Jimcat? is there any website where I can find it?
I dont know about this, any help would be appreciated
Originally Posted by Chaubii View Post
Yo,
Old 01-24-2009, 07:18 PM   #4
Chaubii
Chaubii's Avatar
oh my bad,
Jimcat is a memeber on this forum just search for him and send him a PM
Old 01-26-2009, 01:18 PM   #5
daf62757
Nothing beats a Toyota!
daf62757's Avatar
Drives: 2013 Yaris 5 dr liftback
Where did you put the on off switch for fog lights?
Yo,
I was thinking about adding them to my Yaris. Do they automatically turn on with the headlights or is there a separate switch that turns them on???
Thanks!
daf62757 is offline   Reply With Quote
Old 01-26-2009, 07:44 PM   #6
Meteorite_Marty
Thanks!
If you buy the turn signal stalk with integrated fog light control to replace your existing one, then the fog lights work when the headlights come on. You can also switch them off when the headlights are on, and they automatically go off once the highbeams are on and when the car is off.
Old 01-29-2009, 12:11 PM   #7
YarisMarine
Drives: 2008 Toyota Yaris Hatchback Sp
How much does this one you're talking about cost Marty? and how hard/expensive to install?
YarisMarine is offline   Reply With Quote
Old 01-29-2009, 01:39 PM   #8
In stock for both LB and sedan $99 shipped. Clear, smoke or yellow - your choice.
Includes wiring harness and switch (which goes in the panel down by your e-brake)
Old 01-29-2009, 01:51 PM   #9
YarisMarine
How expensive would you guess installation would be? I may be contacting you next paycheck. Thank you for that quick response.
Old 01-29-2009, 01:53 PM   #10
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
garm i'm on it. the smoked ones for the LB. I sent you a PM. holla back!
Old 01-29-2009, 11:59 PM   #11
Meteorite_Marty
I ordered my fogs from Jimcat. I also got much advice from 1NZYaris1. I recommend 1NZYaris1 to modify your wiring to make it 100% plug and play. Contact him, as he was a true help to me, and gave me the idea to do the headlight stalk (which is genuine Toyota method if you got the fogs from factory), instead of the push button (non-Toyota) switch near the parking brake.
You would need the headlight stalk and relay.
I paid $76 for the stalk.
http://www.trademotion.com/partlocat...07&catalogid=2
Then, to get the fog light indicator to light up on the instrument cluster and close off the circuit in the fuse box, the relay is needed and its $20.
Using the stalk is the simplest way, and factory plug and play method to install the fog lights. You don't have to go through your firewall, and no dismantling of your interior is needed. You will have to remove the steering wheel, which is quite an easy task, and also remove your front bumper which is also quite easy.
You also do not have to splice any wires at all. You basically run the wires to each bulb housing, then that same harness branches off to a battery grounding, and to 2 connectors in the engine fuse box. Really easy, and far better than the DIY parking brake button switch method. Best of all, the stalk contains the switch for the fogs right where you switch on your headlights and turn signals.
Once setup, the fogs turn on when the headlights are on (not the daylight running lights), switch off when highbeams are used, and turn off when the car is turned off. You can also choose to switch them off at anytime.
I can also send you a Toyota PDF manual/schematic on how to install the fog lights, as per factory recommendations.
Old 01-30-2009, 12:47 AM   #12
^ that is cool stuff!!
Old 01-30-2009, 02:20 AM   #13
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
Originally Posted by navygm View Post
Hi,
thanks
Are you after fog lights for a 2000 model
You can use the same lights as the 2006-2009 yaris ,but you will need to buy the correct face plates from toyota ($42.00NZ) + you need to make up a bracket to hold them in place, i used the above to do an install 3 months ago on a 2002 hatch back .
but unfortunitly i did not take any photos of what i did, sorry
i still have the factory pdf for the instal though, if interested
Old 04-10-2009, 12:37 PM   #14
xen555
xen555's Avatar
Drives: 3 DOORS LB
please i need those instructions cand you send it to me?
xen555 is offline   Reply With Quote
Old 04-10-2009, 01:05 PM   #15
regal
Drives: 09 Yaris 3 Dr White LB
Someone please post these instructions, this is a much better way. Using the extra switch the old way it is easy to forget and leave them on draining your battery (ie no idiot buzzer.)
regal is offline   Reply With Quote
Old 04-10-2009, 06:59 PM   #16
1NZYaris1
1NZYaris1's Avatar
Drives: Yaris
PM me your email address , i will send them to you .
The file is to large for Yarisworld by .5 MB
Old 09-03-2009, 06:57 PM   #17
white_rice
white_rice's Avatar
Drives: 2008 Toyota Yaris LE
Send a message via MSN to white_rice
Can you also please email me these instructions to white_rice@rogers.com
Thanks!
white_rice is offline   Reply With Quote
2008 Yaris Fog install ReMiX Cosmetic Modifications (Exterior/Interior) 8 12-19-2008 01:30 PM
Yaris 04 HB Fog lights (1st Generation) Rudysin507 Central and South America 3 12-17-2008 11:43 AM
I test drove a Yaris, Versa and FIT CanadaCraig New YARIS Purchase Forum 41 11-29-2008 10:18 PM
