Old 02-09-2009, 03:26 PM   #1
Tamago
Tamago's Avatar
Drives: ZZW30
one of my custom driveshaft builds: (pix)
found an old set of pictures on one of the first "custom" shafts i did at work. this is for an F22 powered AE86 corolla. the original design (not by me) failed and almost punctured through the floor of the car. the second try is what we see below
we start with the CV end from an S2000.. it's made from what we call "propellor" style shafting, small on the ends, larger in the middle. we cannot use this tube because it's metric, and all our tubing is inch. because of the very high RPM requirements, i must step the tube diameter up to 3" .083 wall tube for strength and integrity..
here's how the shaft started out.
i remove the CV end:
and cut the stub off the metric tubing, leaving a little tubing to work with.
then begin welding: (keep in mind, all im' doing is weld on top of weld, slag and crap is not a concern at this point as it gets burned off in the process)
next, chuck the stub up in the lathe
and begin turning.. my target diameter is around 2.85 since i want a press fit into an .083 wall tube
annnd all done cutting:
then i take the stub over to the press, and use good ol hydraulics to force the stub into a piece of 3" tubing:
then cut the tube to length and press on the "other" end. bolt up to the balancer and start welding
all welded, balanced and painted flat black per customer request:
car is making around 500whp and have had no issues to this day. (original work was about a year ago)
C/C welcome
Old 02-09-2009, 08:05 PM   #2
Morgan
Morgan's Avatar
Drives: 07 MM LB
welding without gloves is a no-no! ;)
looks awesome, I bet that car flys!
Old 02-09-2009, 11:05 PM   #3
Tamago
Tamago's Avatar
Drives: ZZW30
found another pic. this one doesn't have a build log, but it may be more appreciated cuz i have pix of the actual car lol
it's a toyota Supra (2JZGTE) engine, Tremec 6spd (stock twinturbo manual transmission for a supra) mated to a ford 8.8 thirdmember rear end:
and here's the beauty it went in. took 3 separate trophies at HIN miami for this season
one of the cleanest and sickest builds by far that i've ever seen. i have huge respect for RAW (rich auto works) who built this car.
Old 02-09-2009, 11:14 PM   #4
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
very sweet! how much do you charge for that kinda stuff. im going to need a custom drive shaft and 4 axles soon.
mikenacarato is offline   Reply With Quote
Old 02-09-2009, 11:38 PM   #5
Tamago
Tamago's Avatar
Drives: ZZW30
all depends. actual fab work if it's a "standard" driveshaft (no machining, etc) i charge $65 for a complete assemble/straighten/weld/balance.
what transmission and rear end?
Old 02-09-2009, 11:45 PM   #6
Tamago
Tamago's Avatar
Drives: ZZW30
very nice work Tamago. i have the utmost respect for people who create things from scratch and with their hands. so you are saying its strong enough?
do you only do drive shafts? or anything that deals with fabrication.?
i try to fabricate everything i can for my car and others cars. working with metals is one of my passions.
i've only been building driveshafts for a couple years now. aside from my ghetto turbo setup, lately fab work has been pretty slow because of the economy. :(
Old 02-09-2009, 11:48 PM   #7
mikenacarato
SIPNDEW
Drives: 15 STI
its an evo engine and transmission going into a volvo s40. im not sure if i will have to have them shortened, but i think i will. also they will have to be beefed up for sure. the driveshaft and all 4 axle shafts
Old 02-09-2009, 11:55 PM   #8
Tamago
Tamago's Avatar
Drives: ZZW30
can you make a laptop mount like this:
http://cgi.ebay.ca/ws/eBayISAPI.dll?...m=120356014194
how does it attach to the laptop? i'd probably buy an inexpensive camera tripod and build off it.
could be done, but probably not as inexpensive as an ebay product
Old 02-10-2009, 12:13 AM   #9
Tamago
Tamago's Avatar
Drives: ZZW30
there is a strap that keeps it to the plate. but i guess yours would be more expensive
mass production usually leads to products that are pennies on the dollar for custom built stuff.. at my $30/hr i charge you'd have yourself a pretty spendy piece.
Old 02-10-2009, 12:23 AM   #10
Tamago
Tamago's Avatar
Drives: ZZW30
yup but you pay for quality dont ya
this is true :)
Old 02-10-2009, 12:31 AM   #11
ka0sx
ka0sx's Avatar
Drives: bone f*ing stock
Tamago are you in a machine shop or an autoshop, or both?
if you guys do machining how much do you think a rough cost of something like this would be, to be machined from moderate steel. The size is about 16"x16"
ka0sx is offline   Reply With Quote
Old 02-10-2009, 12:41 AM   #12
Tamago
Tamago's Avatar
Drives: ZZW30
unfortunately, my machining capabilities are very limited. i only have two lathes (management sold my vertical milling machine and the welder i used for aluminum, as well as my drill press) so i'd not be able to build the above piece.
Old 02-10-2009, 12:44 AM   #13
ka0sx
ka0sx's Avatar
thats unfortunate, I am limited to using bandsaws, welders and lathes at home and without a proper mill i cant do it myself and im not about to invest more money that i don't have >,<
thanks.
Old 02-10-2009, 02:52 PM   #14
Tamago
Tamago's Avatar
Drives: ZZW30
i missed this post. i'd HAVE to see what flange yoke was on the rear end of the Volvo. typically this would be a 3pc shaft if you utilized an evo stock drivetrain (what rear end are you using?) and why can't you use stock axles? the evo axles hold well over 700whp.
anyway, with a core, (basically front two pieces of an evo shaft) i can build you a 2pc conversion (rear half from aluminum, 15.5lbs lighter than stock) for around $700..
Old 02-10-2009, 05:43 PM   #15
cool beans, Tamago!
I'm coming down there -- you can build me a roll cage.
Old 02-10-2009, 08:06 PM   #16
Tamago
Tamago's Avatar
Drives: ZZW30
cool beans, Tamago!
nah, best go to a certified rollcage shop :)
Old 02-11-2009, 01:23 AM   #17
firemachine69
School'er of hard knocks
Drives: Silver Yaris 4dr. HB
Guilty here!
Good job! Any reason to not just go a commercial route?
firemachine69 is offline   Reply With Quote
Old 02-11-2009, 08:50 AM   #18
Tamago
Tamago's Avatar
Drives: ZZW30
what do you mean a commercial route?
trunk sub pix! drell42 In Car Entertainment + Electronics (audio / video / alarm) 21 07-26-2009 10:25 PM
1000watt Custom built fosgate Sub box id3379 Items for Sale by private party 0 11-30-2008 05:29 PM
How much has your custom exhaust cost you? whooppee777 Performance Modifications 7 07-21-2007 12:20 PM
