#19 |
I think the bars aren't all the same because the gas tank is not a perfect cube. For me:
First bar: 70-90 Second bar: 117-135 Third bar: 170-200 Fourth bar: 210-250 I generally fill up at half tank, but I've reached a "quarter" tank left at 335. *numbers are what is shown on the trip meter, not of individual miles per bar. If you want that, do the math. LOL. |
#20 |
Joey
Drives: '14 Scion xD 5-speed Join Date: Oct 2008
I'm getting about 60 miles first bar because I top-off to the next dollar or gallon, whichever comes first. Next bar I get 50, and then 40 til the next fill-up. 350 per tank on average, not too bad
![]() Other times my tank sometimes gets between 375 and 400 under same conditions and speed, not sure why
Formerly owned Met-Met. '07 Yaris LB 5-speed. A forum post should be like a skirt: Long enough to cover the subject but short enough to keep things interesting. "I don't have an anger problem. I have an idiot problem." -Hank Hill |
#21 |
![]() ![]() Drives: 09 Yaris hatch, Meteor Metal Join Date: Dec 2008
up here in the snow and the cold my new yaris (1300mi on it) gets about 40 on the first bar, 215 miles total to the tank. its 100% city though.
#22 |
#23 |
Heart Up! Vitz
reaching down to the 8th bar, when it starts blinking, like its on crack I've managed to get 407 miles. Just just basic math to calculate it. Mileage at start of fill up, subtract final mileage w/ start mileage, and divide by 8 i think.~
First bar, or equally each bar, gives me about 45-50 miles, but that does not correlate w/ the above i mentioned. I'm doing about 70-78 on Hwy 101/280 up to Daly City, so not so high for me i guess...stupid school~ Kaotic, i dont know how you're getting 70 on the first bar, damn yo! |
#24 | |
![]() ![]() ![]() Drives: 2008 Yaris 3-door Meteorite Join Date: Oct 2008
Really; say it ain't so, Kao!!! I still get about 60 on the first bar; not so spectacular. Okay, that's YET ANOTHER reason to prefer my old Suzuki Swift; that gas gauge wasn't "fancy," but it was dead-on... |
#25 | |
#26 |
Vroom Vroom Beep Beep
As with all gas tanks the fuel gauges gets more acurate the lower the fuel level. Typically you should get 50 miles per bar with the first bar being anywhere from 60-85 maybe even higher depending on fuel level and driving style and about 220 at half way. I have gotten 143 out of the first bar and on that tank I had 479 miles with probably 30 to spare before fill up. Standard driving with out any real lead foot should get close to or just over 400 miles with filling up to the first click. My experience is that the tank can actually hold over 13 gallons of gas. Our car can go over 500 on a tank if you know how to do it properly. As for me I'm thinking about doing a custom tank that holds 20 gallons.
Ever blown out an R-200 diff god know's I have
#27 | |
#28 |
I get 75-80 miles on the 1st bar for practically every tank. The most I have ever got on the 1st bar was 120 miles, when I was on a long road trip. I got the 120 in the middle of the summer (about 100 degrees outside) and with the AC running the whole time.
#29 | |
![]() Drives: 08 Sedan Join Date: Feb 2009
Ok, time to dumb it down a bit... the CEL comes on for more than just the gas cap being off... or loose. When the ECM goes into self-check it will run the evap system... if the pressures/volts do not fall within a specified range then the CEL will trip. The gas cap not being installed or being loose has nothing to do with the evap canister... which can become soaked with fuel when topping off. This also has the potential to trip the CEL. Odds? Probably 1 in a million (est) cars will end up having to prematurely replace the canister due to overfilling. Lesson? Read the entire post before commenting... and don't top off your tank... that extra squirt or 2 is not worth the cost of a new evap canister. |
#30 | ||||||
Fuel filler pipe and vent has nothing to do with the cansiter, vent and purge solenoids, or EVAP hoses and lines. When you're filling the tank the filler tube and vent go straight into the tank, they don't spill over to other components. Most filler pipes/hoses now have the vent hose built within the filler hose itself, older designs had the vent hose opening up near the top of the filler pipe, but the vent hose still dumped into the fuel tank, about 2-3 inches from the filler hose inlet at the tank. Quote:
If overfilling ruined the EVAP system then I guess there would be warnings about never parking a vehicle on a slope. Quote:
Canisters get damaged while the car is running, running improperly and a faulty EVAP system, has nothing to do with topping off a fuel tank. |
#31 |
^Good write-up - It's like an episode of Mythbusters.
The one thing that I find a bit annoying with the whole inaccurate fuel bar issue is that the bars are driven by the microcontroller that runs the instrument cluster. It receives the direct input from the fuel level sender and turns on the appropriate number of bars based on that data. So, it would have been incredibly easy for the SW Engineer to add a fudge factor so that the bars behave in a more linear fashion. |
#32 | |||
MIL (Malfunction Indicator Light) = CEL (Check Engine Light) I know it's hard to believe... but it's true. Why do I call it a CEL? Because that's what the domestic industry calls it... that's what I'm used to... oh well, get over it.
Take a charcoal canister and soak it in fuel... it will get.... soaked... Why can the canister get soaked? Ok... I'm going to go a little bit into the system: For the evap system self-test: Using the engine's vacuum, via the intake, the tank will be brought to a vacuum. If it is unable to pull a vacuum a code will set off the CEL. (Either small or large leak, depending on if the tank can pull a vacuum but not hold it, or not pull a vacuum at all... this can happen by the purge/vacuum valve sticking open/closed (checked by either forcing PIDs and/or plugging the vent per pinpoint tests), the gas cap o-ring not sealing the fill pipe(checking the condition of the cap or doing an actual pressure test on it), or an actual hole in the system(smoke testing... my favorite)) If it is able to pull a vacuum and hold it for a specified period of time it will release the vacuum into the charcoal canisters by sending a 12V signal (or completing the ground, depending on how the system is designed) to the purge valve solenoid which will open the tank to atmosphere. This line is typically vented to the fuel fill area. Now here comes the physics lesson... Pull a vacuum and then let it go... what happens? 14.7# air will push it's way into the tank. Ever blow onto a liquid? What happens? It moves, doesn't it? Now put your face closer to the liquid and do the same thing (simulating putting more fuel into the tank)... get it close enough and your face will get a little wet... Now do this over the course of 8 years or 80,000 miles (epa mandated emissions warranty). My guess is that your face will be wetter then if you pulled your face away a little bit. Your charcoal canister is getting the same thing... They are not designed to last forever... they do have a operational life since they are supposed to see a minimal, and engineered, amount of fuel vapor. If you put more liquid into the canister it will shorten it's life... by how much? Unknown to me, but if you're keeping your car don't you not want to spend about $300 for a canister until you really have to? Although it seems that some people don't think that an eye dropper can fill a bucket one drop at a time... Quote:
Unfortunately I actually dumbed it down so that I didn't have to actually go into the operation of the system and just plainly say that overfilling the tank can cause problems... but since you found it necessary to try and "dumb it down" further by being technical I find it necessary to correct you. Again, read the full post. Quote:
Waiting for your reply... |
#33 | |||||||||
"Odds? Probably 1 in a million (est)" --LOL!!
Toyota and every other manufacturer would be covering about 23,000 (est) warranties everyday...even millions of GM pickups that have their canisters at m/cyl level, located next to the radiator, yes?Quote:
If you're worried about the vapors, don't. Maybe you forgot that fuel vapor from the gas tank is managed by the vehicle's PCM and Canister Purge Valve...I guess if those were defective, then vapors might be a concern... Quote:
![]() 1997 Lincoln Town Car - SOLD 2008 Scion xD (w/ automatic) - SOLD 2008 Yaris HB - SOLD Last edited by 1stToyota; 02-13-2009 at 05:05 PM. |
#34 |
![]() ![]() Drives: '09 Meteorite Metallic 3 dr MT Join Date: Jan 2009
I've had the exact same thought! (and I'm a SW Engineer) Why couldn't they have compensated for the tanks shape? At least get closer! I notice that my first bar lasts around 84 miles and then the last bars disappear before I even notice that it's that low!
#35 |
Clean and (dis)Functional
Drives: Yaris 2dr--Black Betty Join Date: Mar 2007
I've always assumed it was manufacturer practice to dumbdown for the typical consumer.......can't count how many times I've heard "...my car gets great mileage, my 1st quarter tank went xxx miles!"
____________ Old School Cobble Jockey
#36 |
![]() ![]() ![]() Drives: 2008 Yaris Liftback Join Date: Oct 2008
Who pushes the envelope? When I get down to the blinking second bar, I panic and fill up. The book says 1.6 gal. left at slow blink and 1.1 at fast. Who has waited that long or beyond and what happened?
| 2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. | trini_per4mance | General Yaris / Vitz Discussion | 100 | 06-08-2022 09:54 PM |
| DIY: Strut Tower Brace Bar | redyaris | DIY / Maintenance / Service | 18 | 03-16-2014 06:52 PM |
| solid torsion bar bushings... the best rear anti roll upgrade | turboyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 28 | 12-05-2008 11:37 PM |
| Synthetic Oil | Kaotic Lazagna | DIY / Maintenance / Service | 122 | 09-20-2007 03:40 PM |
| c one motorsport performance bars | badhabitz | Performance Modifications | 17 | 08-23-2006 10:31 PM |
