Old 01-31-2009, 07:12 PM   #73
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
Originally Posted by Russelt3hPirate View Post
are you going to add some camber to try and get it all to "fit"?
ur jealous aren't u!!!! j/k
but to the OP, i can let you know the easy way to get rear camber.. if u so desire
Originally Posted by xnamerxx
you nailed it sir.
Old 01-31-2009, 07:18 PM   #74
kimona
kimona's Avatar
Drives: 2014 White VITZ
Originally Posted by Saggio View Post
Here are a few pics of the "poke" (Car is hella dirty)
Man, that's certainly more than just a poke!
Looks like a tractor.
Old 01-31-2009, 07:20 PM   #75
Tamago
Tamago's Avatar
Drives: ZZW30
now i gotta go find pix of the hoosiers on a yaris :D
you nailed it sir.
Old 02-02-2009, 09:45 PM   #76
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
How do I get rear camber?
These wheels are off the car already. I have other wheels coming in on Thursday... they should be pretty sick too.
Saggio is offline   Reply With Quote
Old 02-02-2009, 09:48 PM   #77
Tamago
Tamago's Avatar
Drives: ZZW30
.058" stainless washers under the lower bolts between axle and hub. you'll have to grind them flat one side to clear the pilot hole. RusselTehPirate has them as well as the 10mm hub spacers i had fabbed awhile back
you nailed it sir.
Old 02-04-2009, 12:49 PM   #78
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
New wheels came in early! Ill be starting another thread for these.
Old 02-04-2009, 12:56 PM   #79
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
whats the spec on those.. is is 16's or 17's.. tire specs ??? model?? width?? i have so many questions?????????????????
Old 02-04-2009, 12:58 PM   #80
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
XXR 513's 16x7 +15
195/45/16 Yokohama S-Drives
New thread started.
Old 02-04-2009, 01:01 PM   #81
marcus
toyota
marcus's Avatar
wow +15..
Old 02-04-2009, 05:38 PM   #82
Nagoya_TRD.
Drives: None.
Looks good, it would look nicer lower for sure.
I digged the BBS RSs a bit more though.
Nagoya_TRD. is offline   Reply With Quote
Old 02-04-2009, 06:14 PM   #83
mr_choung
Drives: 08' Yaris RED
is that a subaru badge in front?
ChinG
mr_choung is offline   Reply With Quote
Old 02-04-2009, 06:17 PM   #84
marcus
toyota
marcus's Avatar
uhmm i think hes got lowering springs already he just kinna use a thinner tire setup.. ur right lower it more will be better..
Old 02-04-2009, 09:10 PM   #85
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
I also think it would look better lowered more. And I did like the RS's, but I didnt want to spend $2000+ on wheels. (Yet)
Old 02-04-2009, 09:24 PM   #86
Nagoya_TRD.
Drives: None.
Hrmm, i know RBwheels.com has some 16 in BBS RSs for cheaper than 2000. Ton of nice used wheels on that site.
Old 02-04-2009, 11:18 PM   #87
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Hmm thanks! I'll be looking at that for sure then.
Old 02-15-2009, 12:49 PM   #88
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
195/50/15 Updated first post.
how do you find acceleration compaired to a 17inch wheel? should be better?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 02-15-2009, 01:32 PM   #89
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Id say a little better.
Rim Weights bosbik Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 11-14-2009 07:42 PM
MESH wheels under licence by BBS kimona Wheels, Tires and Suspension Forum sponsored by The Tire Rack 8 09-10-2007 03:48 AM
