Old 09-18-2006, 10:26 AM   #55
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Drives: 09 Yaris LE, H/B, auto
I use Amsoil 2000 0w-30
It may not perform the VEY best in every single test but over all its apperently a better lubricant.
The early bird gets the worm, but the second mouse gets the cheese.
07WYarisRS is offline   Reply With Quote
Old 09-18-2006, 02:17 PM   #56
daq421
MPG is the new cool
daq421's Avatar
Drives: 07 Yaris sedan (silver) Auto
Send a message via AIM to daq421
I just wanted to say thank you to all the posters in this thread. This is a most informative and useful thread .. Based on what I've read here I'm going switch to synthetic at my 5k change.
-Peter
daq421 is offline   Reply With Quote
Old 09-22-2006, 11:49 PM   #57
dandj
Drives: 07 Yaris sedan auto
Ok now I plan on switching over to amsoil but will need to know how to reset the change oil light. Anyone? My saturn vue is as simple as turning the key switch to the on position and flooring the gas pedal for 5 seconds. (engine not running of course)
dandj is offline   Reply With Quote
Old 09-23-2006, 01:40 AM   #58
foober
Drives: two yaris liftbacks
thanks for all the input on oils. I've been using mobil 1 for 10 years but will now switch to amsoil oils. I just want the best for my babys.
foober is offline   Reply With Quote
Old 09-23-2006, 07:21 AM   #59
Billstein
Whew Who..
Billstein's Avatar
Drives: 2 Yaris Hatchs and Tacoma
[QUOTE=nsmitchell]Anyone plan to go Synthetic on their first oil change.
Yes. Mobil 1
Car feels and runs smoother.
"HERS"2007 Yaris Hatch BlazzingBlue Power everything Sirius Radio FullSyn Oil 50% tint windshild35% front 5% rear Keyless Entry Alum TRD Shift Knob
TRD Exh Tip 17" racing harts/Falkins TRD Cold Air Intake
"HIS"2007 Yaris Hatch MedSilverMetallicPower PQ Package 17" Wheels Spoiler TRD ExhTipStiletto100 Radio Armrest 50% tint windshild 35% front windows 5% rear Aluminum TRD Shift Knob Keyless Entry VIP Alarm TRD Cold Air Intake
Billstein is offline   Reply With Quote
Old 09-23-2006, 12:28 PM   #60
ketel0ne
ketel0ne's Avatar
Drives: 2007 Liftback Blazing Blue
Which Amsoil filter do I use, specifically the one for the yaris?
ketel0ne is offline   Reply With Quote
Old 09-25-2006, 10:03 AM   #61
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
I was just on the Amsoil site... You can use the Scion Xb or Xa oil filter which is EaO09/51394.
nsmitchell is offline   Reply With Quote
Old 09-25-2006, 10:30 AM   #62
nsmitchell
nsmitchell's Avatar
After switching to Amsoil Series 2000 0W-30 with an Amsoil Ea Oil filter a few months ago on my 2002 Odyssey with 60K miles I noticed my oil is looking dirtier than with Mobil-1. I had been using Mobil-1 0W-20 and Mobil-1 filters in the past. I did not use the Amsoil motor flush before switching from Mobil-1 to Amsoil. I wonder if the Amsoil is cleaning/suspending the small particles that the Mobil-1 wasn't catching. With my next Amsoil oil change, I will be using the Amsoil Motor Flush. Any comments or ideas would be helpful, because I'm baffled!
Old 09-25-2006, 06:39 PM   #63
foober
I just talked with toyota and they said get an oil filter thats compatible to an 05 echo. Then I phoned amsoil and they said if you want an amsoil oil filter that oil filter number is #EaO09. That the EaO09/51394 is an oil filter made by Wix. To get a true Amsoil oil filter the number is just EaO09.
Old 10-02-2006, 03:18 PM   #64
nsmitchell
nsmitchell's Avatar
Amsoil or Royal Purple? Any thoughts or knowledge we should know about?
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
Old 10-02-2006, 03:44 PM   #65
Racer X-8
Races Little Red Wagons
Racer X-8's Avatar
Drives: red '07 Yaris liftback auto.
Ok, Amsoil is supposed to be right up there and maybe it is the best, i dunno. But, here's a linky to the oil blog going on at the Mazda RX-8 club forum. I'll bet pretty much every car forum has something like this going on for that matter. Bon apetite...
http://www.rx8club.com/showthread.ph...5&page=1&pp=15
Oh yeah, one thing about this being the RX-8 forum - Mazda doesn't want the RX-8 to use synthetic oil. The reason is that a minute amount of engine oil is injected directly into the rotary chambers for lubrication of parts in there that have no other way of getting lubricated. It's a rotary thing. So, they're worried about the different kinds of residues left behind in there .vs. the known residues of conventional dino oil. It's basically taken as a CYA maneuver that Mazda is doing, since Mazda can't / won't thoroughly test every synthetic that is out there. Now that you know about that little issue, dive in!
Racer X-8 is offline   Reply With Quote
Old 10-02-2006, 04:17 PM   #66
nsmitchell
nsmitchell's Avatar
Since rotary engines use some oil while operating by design, and since synthetics dont burn up as easily (vaporize) as conventional oils do, they might start to build up over time in the rotary engine.
BTW - I was getting a laugh from a BobTheOilGuy.com member complaining about their oil getting black after switching from dino to synthetic. No one there mentioned that the synthetic was suspending all the crap that dino didn't clean in the oil, and that all he needed to do was use an engine flush before going to synthetic. Amsoil makes a flush just for that purpose, as do plenty of other companies. I think most of the engine flushes are just kerosene in a quart can.
Get YarAss in gear!
RIP - Casey Tatum
Old 10-02-2006, 05:50 PM   #67
07WYarisRS
HardlyDangerous
07WYarisRS's Avatar
Don't worry about the color of the oil.
Most color is caused by particles in the oil too fine for the regular style filters to trap. If you were to use an Amsoil by pass filter and the 2 micron oil filter set up you oil would still look good even after 100,000 miles.
Synthetic will tend to get dirty faster on enegine that were run on dino oils as they clean away deposits that have built up over time and prevent new deposit build ups.
That's why the sooner you can switch the better.
As for the royal purple VS amsoil question
Both are decent oils, However I have personally seen the lab results from a couple of royal purple tests and they showed serious issues with their quality control. In one case the oil grade on the bottle was higher then the actual oil in the bottle. I've also seen high levels of copper and water.
Amsoil and Redline IMO are two of the best lubricants out there.
Asfor the roatary engines, That does hold some truth
But I would not worry about running Amsoil in An RX7 or -8.
Poorly refined caster oils (bean oils) do form heavy gummy deposits when exposed to flame and severe heat and this will build up over time.
Amsoil or redline oils do not form any such depostis.
I have seen some of my engines with hundreds of hours on them and ZERO carbon, ZERO build up anywhere on the combustion chambers or pistons.
Old 10-03-2006, 02:17 PM   #68
w1ngzer0
w1ngzer0's Avatar
Drives: Subaru Impreza
Not sure this will help, but one of our admin's is a chemist. He analysed a lot of the oils. there is the link to the thread. Talks about reducing lifter noise and other things.
http://forums.nicoclub.com/zerothread/6610
w1ngzer0 is offline   Reply With Quote
Old 10-03-2006, 07:23 PM   #69
Yaris Dick
Drives: 07 Yaris LB, 06 VW GTI, 06 G6
02 data. 06 updated debate with no facts. Won't help.
Yaris Dick is offline   Reply With Quote
Old 10-03-2006, 07:56 PM   #70
w1ngzer0
w1ngzer0's Avatar
meh, oh well.
Old 10-03-2006, 08:57 PM   #71
dandj
I did the change to amsoil 5-30 this weekend. My auterra showed about a 8% increase in gas mileage but will have to fill up a couple of times before I'll know for sure. (getting just under 39 mpg now)
Old 10-03-2006, 10:03 PM   #72
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
I got 187,000 miles on my 1987 turbo RX-7 using Mobil One.
A related thread to "What's Next for the Yaris" (Ethanol) Goose General Yaris / Vitz Discussion 15 06-05-2007 05:15 PM
DIY Oil Change Bassmonkey DIY / Maintenance / Service 42 02-19-2007 09:37 PM
When to switch to synthetic oil? jay DIY / Maintenance / Service 65 02-15-2007 09:44 PM
oil companies profitting... hhcchen Off-topic / Other Cars / Everything else Discussions 22 08-08-2006 09:44 PM
oil changes on your Yaris asa805 DIY / Maintenance / Service 34 07-27-2006 12:41 AM
