Old 02-28-2009, 04:54 PM   #361
NonStopTuning
Anyone else?
MIKE @ NST
www.NonStopTuning.com
Old 03-02-2009, 06:31 PM   #362
xen555
xen555's Avatar
Drives: 3 DOORS LB
i got the pulley arrive today its look thanks for everithing!!! i hope in a few month buy the other two!!! thanks NST
xen555 is offline   Reply With Quote
Old 03-07-2009, 02:17 PM   #363
NonStopTuning
Glad you received your package! Good luck and have fun with your new toy
MIKE @ NST
Old 03-16-2009, 09:05 PM   #364
xen555
xen555's Avatar
Drives: 3 DOORS LB
first thank you for such good product the yaris runs very very good, the motor is so smooth and rev up much faster, dont have to step on the accel to much i love it... everyone must have one of this!!!
thank you
Old 03-17-2009, 11:48 PM   #365
MGargano
Drives: 2009 Yaris Hatchback
I'm looking to get the full set of NST pulleys, but I'm worried about the install since I don't see a DIY on anything but the Crank Pulley... The DIYs for the Alternator and Water Pump Pulley are both blank... any ideas?
Old 03-18-2009, 03:03 PM   #366
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
when will the cr-lite crank pully be back in stock? i see its sold out on your site.
now im depressed...
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Old 03-18-2009, 03:42 PM   #367
NonStopTuning
now im depressed...
Last I checked, Garm at MicroImageOnline had the NST CR-Lite in stock and ready for immediate shipping. I would suggest checking with him.
We do not build the CR-Lite very often anymore because the majority of our customers prefer the Underdrive Crank Pulley. Compatible with the OEM belt and better performance for n/a or turbo applications.
MIKE @ NST
Old 03-18-2009, 05:10 PM   #368
drifto
drifto's Avatar
i c thank you for your response. ill look into it.
07 Yaris LB 5spd
Old 03-26-2009, 11:22 AM   #369
DogTony
Drives: Yaris 1NZ-FE
Enquiry
I do understand how the crank pulley works but still can't fully comprehend the applications of alternator/water pump pulleys. what do they do?
i'm living in bangkok thailand so the temperature is very hot. the life of the air con and its function are very crucial to me also. if i replace the alternator/water pump pulleys, will this affect the air con??
thanks for your reply in advance.
DogTony is offline   Reply With Quote
Old 03-26-2009, 03:29 PM   #370
NonStopTuning
The ALT & WP Kit includes two pulleys that are the same size as the OEM pulleys they replace. The NST versions are roughly 70% lighter than the OEM pulleys and this weight reduction leads to better throttle response, quicker acceleration, and better MPG.
No one using NST pulleys should be worried about the performance of the a/c, the alternator, the water pump, or any other accessory. We take the performance of all accessories very seriously when doing our research and development. We build products that will provide you with excellent performance gains, while keeping ALL your accessories functionality in tact.
Go with NST and go happy
MIKE @ NST
Old 03-31-2009, 11:49 PM   #371
NonStopTuning
Anyone else?!
Old 04-01-2009, 01:17 AM   #372
Astroman
Modded Moderator
Astroman's Avatar
I've put over 50k miles on my crank pulley, and at least 40k miles on the WP and ALT pulleys and they are still making me smile
Old 04-01-2009, 01:53 PM   #373
NonStopTuning
Thank you Astroman
Old 04-01-2009, 02:43 PM   #374
hatchbackkid82
Drives: .
Has anyone who has the crank pulley installed had any problems? You know the whole damper vs no damper debate. Debating whether i should should get the crank pulley or not.
Old 04-01-2009, 11:40 PM   #375
NonStopTuning
20 pages of firsthand reviews and reports in this thread alone. Many other threads of similar content all over YW. Hundreds of reviews, 100% of which have been positive.
The following forums also have THOUSANDS of user reviews from people who have owned and used NST pulleys on their cars over the past several years. Zero reported cases of engine failure due to NST pulleys...
www.YarisWorld.com
www.ScionLife.com
www.8thCivic.com
www.XR-Underground.com
www.MicroImageOnline.com
www.86garage.com
www.club4AG.com
www.tsxClub.com
etc etc etc.
Old 04-02-2009, 08:11 AM   #376
hatchbackkid82
Drives: .
Don't get me wrong i wasn't questioning the quality of the product. I'm pretty sure the pulleys are great. Just thought i would ask. Thanks for the info though, looks like i'll be purchasing these in a few weeks. Just had a honda tech tell me a few years ago that crank pulleys blow oil pumps.
www.YarisWorld.com
www.ScionLife.com
www.8thCivic.com
www.86garage.com
www.club4AG.com
www.tsxClub.com
etc etc etc.
Old 04-02-2009, 01:28 PM   #377
NonStopTuning
Thousands of pulley users on http://www.8thCivic.com over the past few years... Zero cases of bottom end failure or oil pump failure when NST pulleys have been used.
MIKE @ NST
Old 04-03-2009, 01:46 AM   #378
wsladaritz
Y4R1Z
wsladaritz's Avatar
Drives: Yaris LB
So I was looking on the NST site and there are three different kits for the yaris. Two of them are sold out though. Which kit should I be looking at? Which would be most beneficial for a daily driver just looking to add a little more pep?
wsladaritz is offline   Reply With Quote
