Old 03-01-2009, 03:29 AM   #19
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Has anyone ever run a completely stock Yaris on the Dynapack for a baseline comparison?
I've offered to pay 1/2 the cost to dyno a bone stock AT Yaris but no takers yet.
Old 03-01-2009, 03:43 AM   #20
ztrack157
Vroom Vroom Beep Beep
ztrack157's Avatar
Drives: Powered Roller Skate
Send a message via AIM to ztrack157 Send a message via MSN to ztrack157 Send a message via Yahoo to ztrack157
Noogie if your willing to switch out my nst pulley for the stock one I have and back. I will let you play with my yaris next time I'm in socal.
Ever blown out an R-200 diff god know's I have
ztrack157 is offline   Reply With Quote
Old 03-01-2009, 03:44 AM   #21
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
More importantly Peter, how come you wore your t-shirt inside out?
aha. good eye. My friend wore the same exact shirt as me, just different color. I didn't want us looking like a couple, so I decided to turn my shirt inside out.
Old 03-01-2009, 03:44 AM   #22
ztrack157
ztrack157's Avatar
The other idea isto go test drive I new yaris. take it around the corner and dyno it.
Old 03-01-2009, 03:53 AM   #23
LtNoogie
LtNoogie's Avatar
Peter, didn't he measure your air/fuel ratio? I thought I saw a sniffer in the tailpipe.
Old 03-01-2009, 03:56 AM   #24
PETERPOOP
PETERPOOP's Avatar
He did have one there. He was showing me stuff on the computer about that, saying how the stock piping is restricting some power. However, his dyno sheet he gave me doesn't really show anything! I look at your guys dynojet sheets and it shows temp, mod lists, and all of that jazz. I don't know if he was lazy or what?
When I go back for the 2nd dyno run (once everything else is on), i'll be sure to have it done right this time. Since they are open until 7pm, i'll show up there around 6pm, when it's a little cooler here.
Old 03-01-2009, 03:59 AM   #25
LtNoogie
LtNoogie's Avatar
He may still have the a/f readings stored in the computer. Ask him if he can give you a printout. That's how I knew that I went from a normal a/f ratio to lean AFTER the S/C.
Old 03-01-2009, 04:00 AM   #26
PETERPOOP
PETERPOOP's Avatar
Yah, I will be sure to call him tomorrow about that. thanks for reminding me.
Old 03-01-2009, 05:19 AM   #27
fuji
fuji's Avatar
Drives: Polar White Yaris HB
Hmmm, I am also in Honolulu with a bone stock Yaris AT. Just ordered some Tanabe Springs from Munkeywerks, maybe I should get my Yaris dyno'ed for comparison!
fuji is offline   Reply With Quote
Old 03-01-2009, 09:49 AM   #28
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
so you were running rich at first? did you have a wideband a/f gauge to determine this during your pulls, or could you tell with the dyno?
the Dyno has a tailpipe sniffer that helped me know where to pull out fuel. i only took 5 pulls, i met my goal, didn't try to make any more power.. 1NZ won't take it anyway
So Tamago's real name is Jenni
i guess so, eh?
Originally Posted by xnamerxx
you nailed it sir.
Old 03-01-2009, 11:09 AM   #29
ddongbap
I think the most accurate dyno would be a SINGLE STANDARD to rate power. Its only more 'accurate' than another if there are so many standards to go by. So dumb.
Not to say I'm bagging on the Dyno you did. I just think its lame everyone has a diff way to rate power.
Me? I use my iTouch's Dynolicious. MOST ACURATE DYNO EVAR!!!!!!!!!!!!!!! If I have someone hold the iTouch on the rear seat, and launch it foreward, as I accelerate, its like my quarter mile breaks 10 seconds. FASTEST YARIS EVERRRRRRRRRRRRRRRRRRRRR Garm, eat your heart out. =]
And If I swing my arm in a circle, I can get a zero-60 in less than 3 seconds.
Old 03-01-2009, 11:52 AM   #30
Tamago
Tamago's Avatar
Drives: ZZW30
Originally Posted by camelll View Post
Your number is not 867-5309 is it?
call it, find out!
the owner of the shop i dyno'd at is named Jenni
but hey guess garm thought it would be cute to point that out?
you nailed it sir.
Old 03-01-2009, 11:56 AM   #31
Tamago
Tamago's Avatar
Drives: ZZW30
well, considering the SAE got together and decided to change how to measure horsepower, what, last year? i'd say it's just one of those things.
a dyno is a tool more than it is a tell-all. just make sure to either use a properly calibrated dyno or at least the same dyno every time you want to discover your newfound horsepower.
you nailed it sir.
Old 03-01-2009, 01:19 PM   #32
Mouse
Drives: 2007 MX5
Wouldn't you get a more accurate and true hp numbers if you id the dyno on a Dynojet?
The problem with the dynapak is that you're doing the dyno with no wheels. So you gotta factor in the weight of the wheels also. Granted you're running SSR's and they probably weigh anywhere form 8 to 10 pounds for the wheels alone. Wheels and tires you're probably around 30 to 34 pounds each.
Mouse is offline   Reply With Quote
Old 03-01-2009, 01:30 PM   #33
Tamago
Tamago's Avatar
Drives: ZZW30
Originally Posted by Mouse View Post
Wouldn't you get a more accurate and true hp numbers if you did the dyno on a Dynojet?
is dynojet the best or what? lol
you nailed it sir.
Old 03-01-2009, 01:33 PM   #34
PETERPOOP
PETERPOOP's Avatar
Actually if you research, dynapack is more accurate. The dynonet is more generous with numbers. Sometimes a 10% increase oppossed to the dynapack.
This is a quote from cali yaris: "You will get more accurate numbers with the DynaPak (chassis dyno) than with a DynoJet."
So there you go, if garm says it's more accurate, everyone else is wrong. Thank you
I don't have an automatic.
Old 03-01-2009, 03:54 PM   #35
gwasabi
Drives: 07 Blazing Blue LB
YES MUNKYWURKS = AWESOME!!!!
Sorry.....friends garage lol
gwasabi is offline   Reply With Quote
Old 03-01-2009, 04:08 PM   #36
ddongbap
Well thats for stock. I'm talking about aftermarket dynos.
And anyways, who cares if there is a 10% flux? As long as its a standard, it wouldn't really matter.
TS/Xd Long Tube Header & Intake dyno results richardholdener Yaris TS Talk 21 01-06-2009 06:28 AM
NST Pulley Dyno Results richardholdener Performance Modifications 51 12-18-2008 10:11 PM
Long Tube Header Dyno results & Photo richardholdener Performance Modifications 59 11-26-2008 06:27 PM
dyno results are in!!!! turboyaris Performance Modifications 105 04-01-2007 07:03 PM
WR INTAKE SYSTEM : YOU GET $100 FOR DYNO RESULTS ! WRLEO Sponsors Classifieds Area 0 02-22-2007 11:14 AM
