Old 03-04-2009, 11:57 AM   #19
hatchbackkid82
Drives: .
Hey PK. I did switch from regular gear oil that was in there to synthetic
what is "toyota" oil? hatchback did you switch the oil from OEM?
Old 03-04-2009, 11:59 AM   #20
hatchbackkid82
Drives: .
I think Tamago meant that the stealer-ship was going to reccommend i buy their gear oil
Old 03-04-2009, 12:00 PM   #21
hatchbackkid82
Drives: .
Yeah just don't want to give them a leg to stand on. They see the intake and then some how they blame the tranny problem on that. you know they come up with any old thing to make money
Originally Posted by MUSKOKA800 View Post
Powertrain warranty should cover transmission problems.
Old 03-04-2009, 12:06 PM   #22
hatchbackkid82
Drives: .
Oh i know.... So i guess this is a common problem on the yaris. I'm not the only that's had some issue with the synchros
Old 03-04-2009, 12:10 PM   #23
BLAZINBLUEVITZ
BLAZINBLUEVITZ's Avatar
Drives: 2007 YARIS 3DOOR
it is the correct weight
but mobil1 is synchro death.
id listen to the man......
Old 03-04-2009, 12:16 PM   #24
hatchbackkid82
Drives: .
alright i'll get it outta there. thanks guys. I'll still take it in to the dealership. Just want to be on the safe side. I'll let you guys know how it turns out.
Old 03-04-2009, 12:46 PM   #25
Tamago
Tamago's Avatar
Drives: ZZW30
i'd recommend flushing the mobil1 out.
buy 3quarts of the new oil
drain out the mobil1
add 1qt of new oil
drive for 15 miles or so, nothing highway speeds
drain out 1qt of mixed oil
add 2qt of new oil
Old 03-04-2009, 01:24 PM   #26
hatchbackkid82
Drives: .
let me ask you guys this. when i put the mobile 1 in there i just drained what was in the tranny and filled it back up with mobil 1. What makes a drain and flush a drain flush. When i change my oil i always run the engine flush through there for 5 mins then drain everything and replace with new oil. Anything flush like that for mt?
Old 03-04-2009, 01:26 PM   #27
Tamago
Tamago's Avatar
Drives: ZZW30
never heard of engine flushing.. hmm
Old 03-04-2009, 01:39 PM   #28
06silveryaris
Drives: 2006 yaris
i have used GM synchromesh gear oil on Hondas ( B ad K series)when they would have a similar grind and have had very good results. In PR people also use it for E90 M3's since the rear end whinds like crazy and I also quites it up. As far as weight I do not remember what I used.
06silveryaris is offline   Reply With Quote
Old 03-04-2009, 01:44 PM   #29
Tamago
Tamago's Avatar
Drives: ZZW30
in colder climates, stick to lighter weights
i run 80/90 in mine
Old 03-04-2009, 01:46 PM   #30
hatchbackkid82
Drives: .
yeah this is what is use before i change my oil, you add it to the crankcase, turn the car on, let it circulate through the engine for 5 mins, and then just do a normal oil change. Is there anything like this for MT, or is it really just a drain and fill
Old 03-04-2009, 02:58 PM   #31
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
amsoil it ..worked for my celica..itll take a month for the oil to settle though so if you go synthetic give it time. it will still grind right after but give it 1 to 1.5 months thats how long it took for my celica gears to shift smoothly and it was grindless even after i traded it 2 years after..
Old 03-04-2009, 03:52 PM   #32
White Yaris
Broke Tuner
White Yaris's Avatar
Drives: White Yaris
Mobil 1 gear oil works fine on my car? but, right now its redline MT90. Not much difference?
However, i still recommend Redline MT90 or Toyota (OEM) i dunno what theirs called. I void warranty all the time.
EVERYTHING YOU KNOW IS WRONG
White Yaris is offline   Reply With Quote
Old 03-06-2009, 12:28 AM   #33
ImportRacer88
ImportRacer88's Avatar
Drives: 4dr Sedan s
Send a message via AIM to ImportRacer88 Send a message via Yahoo to ImportRacer88
I have a hole shit load of stuff done by myself and i didnt void the warrenty and i had that same problem shifting into third would grind they told me it was bent gears this was around 9000 miles they fixed the problem for me took the a week they gave me a rental and every thing didnt have to pay a cent
ImportRacer88 is offline   Reply With Quote
Old 03-06-2009, 12:56 AM   #34
cleong
Parallel Parking Pro
cleong's Avatar
Drives: Yaris 1.5 Manual
I had that dreaded gear grind last year. Leading up to that time I had the TRD quick shift installed, and Redline MTL gear oil which replaced the stock oil.
At first it would only grind shifting from 6000+rpm in second going into third. Then the grind got worse, coming down to 4000+ rpm. At such point it was so repeatable I took it back to the dealer. It probably was a syncro problem, they didn't say. They apparently knew what was wrong with it without taking apart the gearbox to see, because they said they'd order the parts required to fit it, which took about three months. The car was then laid up for about three days.
Since then I'm on the stock factory oil or whatever they decided to fill it with, and the TRD quickshift is no longer on my car. No further grinds, although I'm told this gearbox is rather weak anyway.
Leong's NCP91 Toyota Yaris E
TRD Blue brake pads
DC Sports header
Old 03-06-2009, 01:05 AM   #35
Morgan
Morgan's Avatar
Drives: 07 MM LB
I had the same 2nd-3rd grind and its very noticeable in my car for some reason. I changed out the factory oil with some new regular 75w90 and it seems to be better. gl
Old 03-06-2009, 01:21 AM   #36
JBIZZ
Drives: 2007 Liftback white
I put Royal Purple 75w-90 in. Now I have a grind at very low speeds downshifting into 1st, after the car has been driven for awhile. I am going to change it to Redline MT-90 this weekend.
JBIZZ is offline   Reply With Quote
Yaris 2007- How to Restart Multimode gear? ronen DIY / Maintenance / Service 1 02-21-2009 06:09 PM
Auto 'extra' gear? drecian General Yaris / Vitz Discussion 2 08-25-2007 09:01 AM
High RPM's in 3rd. Need some opinions falkor_99 General Yaris / Vitz Discussion 3 05-16-2007 09:23 PM
2nd to 3rd gear shift (manual tranny) tekmoe General Yaris / Vitz Discussion 13 12-11-2006 07:27 PM
clicking into first gear tekmoe General Yaris / Vitz Discussion 9 11-01-2006 03:44 AM
