Old 03-17-2009, 11:50 PM   #1
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Old 03-17-2009, 11:54 PM   #2
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
2.25" Ftw ! I had 2.5" on my 2.2 accord with every bolt-on back in the day and the low-end response was death ! On the 1.5 w/ the blitz S/c I think 2.25" stright through with a magnaflow on the end will be killer , and just the right amount of back-pressure for low-end tq .
Old 03-18-2009, 12:21 AM   #3
White Yaris
Broke Tuner
White Yaris's Avatar
Drives: White Yaris
2.25 all the way. My custom set up is 2.25 in/out resonator, 2.25 out/ 3in tip muffler from vibrant. Cat-back tho.
EVERYTHING YOU KNOW IS WRONG
White Yaris is offline   Reply With Quote
Old 03-18-2009, 02:46 AM   #4
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
2.25 like I told you last month.
Old 03-18-2009, 02:57 AM   #5
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I think RAD has plenty of 2.50" tubing in stock so they suggested that. lol.
2.25" ... that means soon you'll be sellin' that "old" one, huh?
Old 03-18-2009, 03:48 AM   #6
dallas
Drives: Yaris Hatch /Landrover D2
The secret to the most h.p and torque is to have no back pressure but to maintain your exhaust gas velocity. If you go too big in pipe diameter you will loose velocity, I would go no bigger than 2.25 Unless your turbo charged or supercharged then you can go bigger. On this engine with basic bolt on's even 2.25 will not work well until the higher rpm range.
dallas is offline   Reply With Quote
Old 03-18-2009, 03:55 AM   #7
red_rims
Black Yaris
red_rims's Avatar
Drives: Black Yaris
2.25 bro. hey does anyone know how much it will affect gas mileage doing all that?
red_rims is offline   Reply With Quote
Old 03-18-2009, 04:00 AM   #8
PETERPOOP
PETERPOOP's Avatar
I'm hoping not THAT much, because I've already lost a lot with the S/C. And I will probably lose more with the 1zz throttle body.
Old 03-18-2009, 04:16 AM   #9
djgab101
djgab101's Avatar
Drives: toyota yaris
I am supercharged; but this supercharger doesn't put down the kind of power that recquires 2.5" piping.
Ok then, 2.25" it is!
u said after exchaust ur going on dyno i wnat dyno sheets plz!!! plzzz
djgab101 is offline   Reply With Quote
Old 03-18-2009, 09:18 AM   #10
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
2.5, so later when you go turbo you don't have to re-do your exhaust..
Originally Posted by xnamerxx
you nailed it sir.
Old 03-18-2009, 09:45 AM   #11
ddongbap
I highly doubt the 1NZ can put down enough power to require 2.5 work done. In ANY form.
Old 03-18-2009, 10:01 AM   #12
Tamago
Tamago's Avatar
Drives: ZZW30
mine enjoys it
you nailed it sir.
Old 03-18-2009, 01:57 PM   #13
Really? I thought you knew about my car.
Old 03-18-2009, 03:48 PM   #14
Split
Drives: 2008 Yaris Sedan
i dont think 2.5 will hurt performance, but i highly doubt you'd gain anything from it. 2.25" should be a bit quieter as an added benefit if that's what you prefer.
Split is offline   Reply With Quote
Old 03-18-2009, 04:07 PM   #15
ddongbap
mine enjoys it
But does it require it?
Old 03-19-2009, 04:50 AM   #16
nisyota
with a supercharger... 2.25" pipes... isn't 2.5 normally used for 500hp or more? How much HP are you putting out?
2.25 should be best for low end torque, but the 2.5 will only play at the top end...
nisyota is offline   Reply With Quote
Old 03-19-2009, 05:28 AM   #17
ddongbap
Well, you don't count. You don't REALLY have a 1nz. haha.
Old 03-20-2009, 01:24 AM   #18
The Spectacle
The Spectacle's Avatar
Drives: 08 BSP LB
2.25 was a good call. Your muffler choice however, was not.
The Spectacle is offline   Reply With Quote
DIY: Installing Greddy TI-C Exhaust System redyaris DIY / Maintenance / Service 13 08-01-2009 05:05 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 15 06-09-2007 02:24 AM
ZPI to produce yaris turbo kit and exhaust turboyaris Forced Induction Forum 30 04-04-2007 03:10 PM
GReddy prototype = Free Exhaust! Chris_Lum California 30 02-27-2007 11:13 PM
Fujitsubo Exhaust!! MC-BPT Sponsors Classifieds Area 17 11-16-2006 11:36 AM
