Old 03-25-2009, 11:17 AM   #91
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
i dont think anything makes epoxy soluble, the only way to do it is either burn it off, or pick it out
Old 03-25-2009, 06:24 PM   #92
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Freeze Spray or pick it out.
Blah, Blah, Blah, Blah
Saggio is offline   Reply With Quote
Old 03-27-2009, 10:06 PM   #93
jkuchta
Drives: 2007 Yaris hatch (red)
The only experiance I have is with the Corolla TB, so that's the only one that I can say for sure fits.
Dallas,
The TB can't ice up, as there is no fuel passing through the TB. To get normal intake air to ice up you'd need to run it through a really small venturi to get the pressure low enough.
Hatchbackkid, do you know what the DTC associated with the CEL is? Sounds like you have an air leak. Don't forget that the silicone sealent has to sit for a few hours to harden enough to resist the vacuum at idle.
jkuchta is offline   Reply With Quote
Old 03-28-2009, 02:00 AM   #94
dallas
Drives: Yaris Hatch /Landrover D2
I thought that is the only reason why they run hot coolant lines into the TB, in our cold climate if you bypass it you will have issues around zero, with rought running etc everyone around here calls it icing, do you know whats actually happening! I agree for ulimate performance you don't want it hot as a cooler air is more dense,
Dallas,
dallas is offline   Reply With Quote
Old 03-28-2009, 02:21 AM   #95
jkuchta
As far as I can tell, the TB is heated to give better fuel economy. Why a cold charge would cause those problems is beyond me.
I've flown injected piston aircraft is sub-zero conditions and they just seem to run stronger!
Old 03-28-2009, 02:24 AM   #96
jkuchta
Hey Nexus the TB has been on for 260 miles, and no problems, and the improvement is still there!
Old 03-28-2009, 04:21 PM   #97
Saggio
Top Notch!
Saggio's Avatar
Drives: 2008
Is your TB still heated?
Old 03-28-2009, 04:40 PM   #98
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
it would make sense around here because it gets very cold (0 or lower) consistantly in the winter, and on the off day it will be cool and very damp. so cool and damp, temp drops, condenses on butterfly flange, engine cools down, butterfly freezes. makes sense to me for this area at least
Old 03-28-2009, 09:59 PM   #99
jkuchta
Saggio, my TB is not heated.
Alex, it would have to be REALLY cold and VERY humid for ice to form in the TB. When a carb freezes up it is caused by the fact that fuel requires energy to vaporize...thus when fuel vaporizes it super cools the air it's in, thus causing the water vapor in the air to turn to ice. Because there is no fuel passing through the TB on our cars, there is no way the air can become supercooled enough to form ice.
The cold weather problems people are running into with unheated TB's may be caused by there being too little heat in a less-than-fully-warmed-up engine to fully vaporize the fuel in the intake port of the cylinder head, causing rough running (caused maybe by the resultant lean condition, or an over-rich ECU compensation).
This is just a theory of mine, and may not be totally correct, but I think its at least a pretty good guess
Old 03-28-2009, 11:43 PM   #100
AlexNet0
AlexNet0's Avatar
yours makes sense, it was just what seemed logical to me
..Because there is no fuel passing through the TB on our cars, there is no way the air can become supercooled enough to form ice.
welllll, maybe I should not bypass anyway, lol, because a future mod planned WILL supercool the intake air
Old 04-09-2009, 01:43 AM   #101
MGargano
Drives: 2009 Yaris Hatchback
Will this: http://cgi.ebay.com/ebaymotors/TOYOT...Q5fAccessories work with the '09 3-door HB? I'm planning to do the DIY listed in this thread, but I want to make sure this is the correct TB first.
Old 04-09-2009, 01:55 AM   #102
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Yup, that's the one. Great seller too, bought mine from them.
Old 04-09-2009, 10:42 AM   #103
MGargano
Thanks, Gideon. So, if I'm reading this thread correctly, all I need is the 1ZZ-FE TB and the chip from my stock TB? Anything else needed to get everything working? I'm not looking to do the coolant bypass or anything.
Old 04-21-2009, 05:22 PM   #104
MGargano
For those of you who did the coolant bypass, did you plug the tubes on the TB or just leave them open?
Old 04-21-2009, 05:28 PM   #105
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i actually pulled the tubes out with some pliers for a cleaner look and polished it up. so yes they are open.
Old 04-21-2009, 06:38 PM   #106
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
WOULD THIS WORK FOR CANADIAN TB 1.5,...well im assuming it will.i may try this out...
Old 04-21-2009, 06:41 PM   #107
AlexNet0
AlexNet0's Avatar
as long as the stock is a 1nz-fe engine
Old 04-21-2009, 06:47 PM   #108
marcus
toyota
marcus's Avatar
aight..i guess i got a new project to do...
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
