Old 03-25-2009, 11:28 PM   #1
cyberfrogg
cyberfrogg's Avatar
Drives: Yaris Sedan S
Power Lock button??
Ok, so I got my car used. And it was advertised to have the power package. Power locks, windows... But when I saw it, it didnt. So we had the power windows installed with the switches and later on we got power locks.
But they only lock and unlock with this:
Now, I saw that I have these two in the middle:
One's going to be for the fogs and I was wondering if there was ANY way I could add a lock/unlock switch in there. Its very annoying to have to look through my keys to unlock the door for someone from the inside... Any help would be much appreciated! thanks.
cyberfrogg is offline   Reply With Quote
Old 03-25-2009, 11:30 PM   #2
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
I installed my aftermarket power locks and wired them to my Python alarm. They only power lock/unlock with the remote, too. I'm wondering the same thing: if it's as simple as throwing an inline switch in there somewhere?
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs
enobmort42 is offline   Reply With Quote
Old 03-25-2009, 11:50 PM   #3
Look at the installation manual for your remote entry manual. Look for the lock and unlock outputs. You will either need to ground the output through a switch, or pull it high (the manual will show if the outputs are positive or negative.)
I was going to point you to the keyless entry lock/unlock wires in the driver's kick panel, but then realized that your cars started with manual locks, so those wires are probably not used.
Old 03-26-2009, 12:11 AM   #4
b_hickman11
Drives: 08 Sedan
Your door actuators are probably only 2-wire when they should be 5-wire so that all doors will Lock/Unlock when you flip any lock on any door.
Old 03-26-2009, 12:57 AM   #5
enobmort42
First time DIYer
enobmort42's Avatar
i didn't know about that feature! lol
Old 03-26-2009, 01:45 AM   #6
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
those two dead spots...one of them is actually where the o.e.m switch goes....
Xda Forums - Shroomster
Androidforums - Shroomster
I'm noticing a pattern......
Old 03-26-2009, 08:24 AM   #7
b_hickman11
Drives: 08 Sedan
No its not.....I have a Sedan with the power package and the OEM switches are on the doors.
Old 03-26-2009, 08:28 AM   #8
b_hickman11
Drives: 08 Sedan
This is a 2-wire Actuator:
http://a1electric.com/Merchant2/merc...duct_Code=W15C
This is a 5-wire Actuator:
http://a1electric.com/Merchant2/merc...duct_Code=W16F
The 2-wire is only to able to Lock/Unlock itself while the 5-wire is able to Lock/Unlock all doors including itself.
Old 03-26-2009, 08:48 AM   #9
The liftbacks with the power package have a switch there (part number 84930-52050). It's a two way lock/unlock toggle and it's about $60 from Toyota).
Old 03-26-2009, 01:22 PM   #10
b_hickman11
Drives: 08 Sedan
This is true....but he has a Sedan
Old 03-26-2009, 01:32 PM   #11
Correct, but he's looking for an easy solution to add a lock/unlock switch to a non-oem system. It seems to me that using the liftback switch in the center console would be easier / less expensive than adding the OEM sedan door switch module.
Old 03-26-2009, 01:39 PM   #12
cyberfrogg
cyberfrogg's Avatar
yeah. I don't want to add the whole door switch, I'd rather just use the one in the middle.. Would it have been easier with the 5 wire actuator? =/
Old 03-26-2009, 01:47 PM   #13
With the 5 wire actuators, you wouldn't have needed to add a switch, as unlocking the manual door lock on the driver's door would have unlocked all of the other doors as well.
Do you know what brand/model your keyless system is?
Old 03-26-2009, 01:57 PM   #14
cyberfrogg
cyberfrogg's Avatar
xD duh thats true... lol oops. Ah well my mom took the car. I'll check what it is later.. I remember it was K-9 or something like that. I'll check it out when she gets home..
Old 03-26-2009, 02:50 PM   #15
Yeah, K-9 Mundial SS (I should have recognized that from the remote).
In the image below, look at the three pin connector with the Green (-Lock), Red, and Blue (-Unlock) wires.
Tap onto the green and blue wires as they leave the module. Run a wire from green to one side of your lock switch and ground the other side. Do the same for blue with your unlock switch.
Old 03-26-2009, 03:52 PM   #16
cyberfrogg
cyberfrogg's Avatar
woah seriously? Is that all I need to do? I guess now all I need is a lock/unlock switch that will fit in that hole in the middle... Do you know where I can get something like that? thank you thank you thank you! lol
Old 03-26-2009, 04:07 PM   #17
Yeah, that's it.
For switches, the slickest one would be the liftback one I mentioned above, as it would fit perfectly in one of the slots and would even have the lock/unlock labeling to it.
If you want to save cash, you could just use two momentary normally open switches from Radioshack (for under $4 each). You could find two that will fit together in one of the knockouts.
Old 03-26-2009, 04:57 PM   #18
cyberfrogg
cyberfrogg's Avatar
sweet. =] Are you sure radioshack has em though? anddd I was wondering if I could get the liftback switch at a dealership or something.. And if I could, do you know what the part number would be? thanks so much for all your help!
Power door lock keyless entry and remote start rizaydog In Car Entertainment + Electronics (audio / video / alarm) 10 07-20-2009 05:14 PM
More power, with a push of a button?? leasaunce Performance Modifications 36 08-20-2007 02:59 AM
Power hatch lock? paultyler_82 DIY / Maintenance / Service 5 09-08-2006 02:15 AM
using regular power lock kits with cable style twixt DIY / Maintenance / Service 4 08-12-2006 02:18 PM
