#91 |
the chances someone drumming on this steering wheel, the air bag deploying while someone is filming is VERY slim...
#92 |
'07 to '12:2 wipers to 1?
Drives: '12 5-door LE & '14 5-door LE Join Date: Apr 2007
the tags for the video as well as the other videos recommended lead me to believe it's from a car insurance company....
MicroImageonline forums - Shroomster Xda Forums - Shroomster Androidforums - Shroomster I'm noticing a pattern...... |
#93 | |
Here is a quote from the 09 service manual: "The microcomputer which controls the cruise control system is built into the ECM, and uses the throttle position sensor and motor as the actuator." The stalk basically just has 4 switches and 3 resistors. The quick and dirty test (without removing the airbag) would be to short the ECM CCS pin to ground. If the cruise light illuminates on the combination meter, you are good to go.
#94 |
#95 |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
I just checked - my car ('08 5-door) doesn't have the wiring from the spiral cable to the ECM - nothing coming from that plug except the thin black horn wire. If the wiring for cruise were present, there would be two more wires.
So, installing cruise is probably still possible, but unfortunately it's not just a matter of adding a switch. Last edited by Sir A.Y. Atoyot; 07-27-2010 at 05:01 PM. |
#96 |
![]() ![]() ![]() Drives: bone f*ing stock Join Date: Dec 2008
guys, those of you who are saying few minutes, be careful, some car systems can take over an hour to discharge the sustaining capacitors, also ground yourself to prevent static discharge.
#97 | |
My '09 has a blue wire in pin 1 and a brown in pin 3. When I look at the models that the stalk part number is applicable to I see 06-09 sedans, but only 09 liftbacks. |
#98 |
The stalk connects to the spiral cable on the steering wheel hub end, but the connector he pictured is the output of the spiral cable, heading towards the ECM. In his picture, the CCS wire (blue on my 09) is missing.
#99 |
I've done some research with the documentation that members have provided, and I can assure you that you need two wires coming out of that plug, in addition to the horn wire. One of them is blue and goes to the ECU. The other is a yellow ground wire.
#100 |
#101 |
Here's a comparison of SodiumDuck's 08 (left) and my 09 (right) (from when we installed our remote starters). Mine has the blue and brown, and his just has the black horn wire.
![]() On the EWD, the spiral cable is just the block between 3B and 1A, as well as the block between 1C and 8A on the horn diagram on page 145. The spiral cable simply brings the signals off of the movable steering wheel. (If we had the European steering wheel controls, they would most likely connect through the last unused pin). |
#102 |
First time DIYer
i'm beginning to get lost in all the technical talk. i should probably take a look at mine up in there.. unless someone can tell me if i have what it takes to do this by telling them that i have an '07 lb hatch?
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs |
#103 |
I was thinking that I was having deja-vu on this topic and found this topic from a while back:
http://www.yarisworld.com/forums/sho...=cruise&page=3 Out of curiosity, have you checked to see if your combination meter has the two cruise lights. |
#104 |
No cruise light on my dash panel. It has a fog light icon, though (no actual fog lights in the car).
Canadian 2008 5-door hatch. |
#105 |
SIPNDEW
ah so since the cruise connects to the inside of the oem steerig wheel looks like i cant add it since i have an aftermarket wheel :(
#106 |
You could install one of the aftermarket Rostra brand units, which doesn't attach to the steering wheel. Be prepared to pay lots, though.
#107 | |
Or you could add four momentary switches (On/Off, Set, Up, Down) to the dash like I am going to do to save on buying the stalk and on having to pull the airbag. |
#108 |
Good luck with that - those functions on the stock switch work through resistors and involve the extremely expensive central engine computer (ECM). The resistors are the squiggly lines in the diagram. It's important to know the exact values to make it work right. A familiarity with Ohm's Law would help, too.
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
