Old 04-22-2009, 09:30 AM   #19
DerFlosser
DerFlosser's Avatar
Drives: Yaris
I will be getting some 08' sedan foglight covers from Garm but once I am done setting up the foglight wiring, I don't want to have to put my bumper back on without the correct shrouds. Can/Do the shrouds get popped on after the bumper is installed? Or, can you pop on the shrouds after the bumper is installed? This way....I can do all the work and if the 08' sedan shrouds don't fit, I can get the correct 09' shrouds and just pop them on. Anybody?
DerFlosser is offline   Reply With Quote
Old 04-22-2009, 10:00 AM   #20
DerFlosser
DerFlosser's Avatar
Drives: Yaris
SHROUD LH: 81482-52260
SHROUD RH: 81481-52330
Also,
Are you positive that these are the 09' shroud p/n's? Thanks in advance!
Old 04-22-2009, 11:23 AM   #21
MGargano
Drives: 2009 Yaris Hatchback
I have an '09 LB. If I buy this kit from Garm: http://shop.microimageonline.com/pro...&productId=111 all I would need is the LH & RH shrouds and the OEM stalk from Toyota to make it work?
Old 04-22-2009, 12:54 PM   #22
Originally Posted by DerFlosser View Post
Also,
He's correct - I just got my set from my dealer:
Old 04-22-2009, 01:13 PM   #23
MGargano
Which fog kit are you using for your '09?
Old 04-22-2009, 01:15 PM   #24
The Microimage one.
Old 04-22-2009, 01:28 PM   #25
MGargano
The Microimage one.
That's what I figured. Is it this one? http://shop.microimageonline.com/pro...&productId=111
Will this kit work with the '09 3 door LB if I get the shrouds from Toyota?
Old 04-22-2009, 01:56 PM   #26
Your link is to the sedan version - I grabbed the liftback one.
The OEM trim pieces are the only thing needed to make it work on an 09.
Old 04-22-2009, 02:06 PM   #27
MGargano
Thanks, that's what I was curious about. I wasn't sure if it was the sedan or liftback version that worked on the 09 so thanks for clearing it up. Any idea where I can find the OEM cruise stalk on the cheap? The dealer wants $115.18.
Old 04-22-2009, 02:14 PM   #28
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Scott,
I plan on using the integrated fog light switch on the headlight stalk for total plug and play. Do you happen to know if the 08 sedan covers will fit the 09 LB? If you know for sure....I may as well go ahead and order the right ones now.
Old 04-22-2009, 02:16 PM   #29
Actually, I would be that the only difference between the two is the trim, as I believe the fog wiring is identical on both.
For the cruise stalk, check this ebay auction:
http://cgi.ebay.com/ebaymotors/NEW-O...Q5fAccessories
Old 04-22-2009, 02:33 PM   #30
Scott,
Initially, I thought that might be a possibility as well, but no the sedan covers are different than the 09 liftback ones.
Old 04-22-2009, 03:00 PM   #31
DerFlosser
DerFlosser's Avatar
Drives: Yaris
cool...thanks for the help Scott!
Old 04-22-2009, 03:16 PM   #32
MGargano
I'm retarded... I meant OEM fog light stalk, not cruise control stalk. Any ideas?
Old 04-22-2009, 04:05 PM   #33
I believe that you can use either the 06-08 (84140-52150) or 09 (84140-52151) versions. TRDsparks sells the 06-08 one for $77. The difference may just be in labeling like the wiper stalk I put on mine. I bought the older version of the Prius wiper stalk and it has text on it, whereas the newer version just has the symbols.
The other place to try is the junkyard that I bought my wiper stalk from (for $50 vs ~$100). http://autoworksinc.com/
Old 04-22-2009, 04:30 PM   #34
MGargano
They also have the 09 version (84140-52151) for $92.14. Price difference is $15.20. You're the electrical genius... which switch would you use? The TRDsparks item description for the 52150 says 'combo switch w/ fog lamps' but the 52151 description only says 'SWITCH ASSY HEADLAM' so I'm worried it might not be the right one.
Old 04-22-2009, 04:51 PM   #35
I would go with the cheaper one (but I am cheap). The EPC shows 84140-52141 as the no-fog stalk, so you are OK with the 84140-52151.
Old 04-22-2009, 05:32 PM   #36
MGargano
Thanks for all your help. Now I just need to order the shrouds. Is there a DIY for installing the fogs with the OEM stalk? All I found were DIYs for using the aftermarket switch.
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 goku87 DIY / Maintenance / Service 127 02-19-2023 08:01 PM
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
Fog light install 07yaris_fe Cosmetic Modifications (Exterior/Interior) 10 07-20-2010 02:18 PM
Looking for the Toyota Fog Light install RocknRollRon DIY / Maintenance / Service 33 06-13-2010 07:46 PM
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 03:04 AM
