#145 |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
#146 |
toyota
bump for update...
#147 |
MGragano, What is the code for the CEL? Have you adjusted the idle set screw yet?
#148 |
9 PAGES and i still see a CEL.......
EVERYBODY EVENTUALLY COMES BACK TO YARISWORLD...... |
#149 |
#150 |
That's why you get a CEL. You MUST adjust the idle to get rid of that CEL, as it's a result of the ECU having to over-adjust to hit a target idle RPM. Re-read thread #78, and you will more than likely get rid of the CEL for good. |
#151 |
SIPNDEW
no you dont. i didnt touch my idle screw, its still covered in the hard crap. all i did was the chip swap, nothing else.
#152 |
Rides canyon walls
Drives: 1988 RX7 FC 10th AE Join Date: Jun 2007
Cool thanks for the diy.
I got my 1zz tb from crxgames. I removed the rivets, swapped the chips, screwed them on, and added some rvt gasket maker. Plugged in the new 1zz tb with the 1nz chip and started her up. This was after I had disconnected the battery for an hour. So it started to oscilate from 2-3k like many others have mentioned. I waited for exactly 10 minutes and it ended up idling at around the same rpms as the stock tb. Drove around a bit and no cel. I didnt mess with the idle screw cause the idle was just fine. I had to run some errands and every time I started up my car no problems or cel. I have yet to start my car during a cold start up so I'll chime back in here with results. The ecu hasnt learned the changes completely yet, my auto keeps shifting too early still. I can tell theres gonna be a ton of power over 3k. I'm not sure thought, but i think i'm feeling a lot of increase in low end...@_@ Getting some headers worked on right now, should compliment the TB very well.
![]() OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header Last edited by eii; 05-02-2009 at 04:23 PM. |
#153 |
Mike, Mgargano's specific CEL is more than likely caused by the idle screw not being adjusted.
#154 | |
#155 | |
Rides canyon walls
1zz tb is 2.5"
![]() OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header |
#156 |
1NZ-FE
. ![]() DC Sports Header, Vibrant Hi-Flow Cat, Round Magnaflow Muffler, Vibrant Tip, Dunlop Direzza 195/50 Rims 15", Injen Technologies Cold Air Intake, NST CR-Lite crank, waterpump & alternator pulleys, Tanabe NF210 Springs, NST SSK 1 & 2, NST Shifter Cable & Cage Bushing Kit, Nitto Engine Torque Damper
#157 |
toyota
bumpin..
#158 |
Rides canyon walls
Pic of my 1nz tb now a paper weight on my desk <3
![]() OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header Last edited by eii; 05-04-2009 at 05:55 PM. |
#159 |
HELP!!!!!!!! PLEASE!!!!!!!! I am in the middle of installing this TB with the afe intake the issue I am having is the coupler for the intake is hitting the screws and wont go on all the way. I have tried with all my strength to push it on further with no luck. Also I am unable to wedge the hose clamp in between the coupler and the screws. Any Ideas? I was thinking about shaving out some of the inside of the coupler, but how would I go about doing it? here's a pic so you can see what I amj talking about.
#160 |
SIPNDEW
and you cannot get the clamp to clamp tight just before the studs?
#161 | |
#162 |
I tried to use a hose clamp when I did the install the first time. It stayed on for bit, but once the engine got hot, the clamp popped right off. The neck of the TB isn't long enough to clear the studs & fit a hose clamp.
| 1.8L Engine Swap, Possible? | Yaris T-Sport | Performance Modifications | 4 | 05-06-2007 06:57 PM |
| swap for 2zz-ge???? | yarisTOONR82 | Performance Modifications | 12 | 03-23-2007 07:15 PM |
