View Poll Results: are you interested?
yes i'm interested in 13mm spacers 13 48.15%
yes i'm interested in 10mm spacers 14 51.85%
Voters: 27. You may not vote on this poll
Old 04-30-2009, 12:22 PM   #19
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
most likely a 7" wheel.
Personally the 10mm would probably be best for you since you're running the wider tire.
Russelt3hPirate is offline   Reply With Quote
Old 04-30-2009, 12:26 PM   #20
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
agreed.
so here's how it should go:
+40mm or lower (+38 for example), purchase 10mm spacers (if your tire is 215 or wider)
+40mm or lower (+38 for example) purchase 13mm spacers if your tire is 205 or skinnier)
on a 7" wide wheel. anyone running 6.5" wheels, no matter what offset should be able to run the +13 spacers without ANY issues.
and FYI the bolts are long enough to handle two sets of 10MM if one so desired. (that'll make your rear track 40mm wider!)
Originally Posted by xnamerxx
you nailed it sir.
Tamago is online now   Reply With Quote
Old 04-30-2009, 12:26 PM   #21
kngrsll
Apexing Egg!!
kngrsll's Avatar
very difficult to do that, as i don't know the specific drop your car has. as the suspension compresses, negative camber turns into toe-in.
i could, however, provide two stainless washers to be installed under the lower front bolt. this is how i achieved my current setup (toe out, and a little extra camber)
i have the SPC shims on it right now, and i put them on when the car was stock. the full alignment really changed the car in a good way so i dont want to lose that. but i could get another set of them, put the spacers on, get another alignment, and redo the shims. i like a tiny bit of toe-in the rear, stock it has massive toe in the rear.
or i could just leave the shims as is and add the spacers :rofl:
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 04-30-2009, 12:27 PM   #22
Russelt3hPirate
l33t3st Asshole
damn 20mm spacer would be pretty crazy.
Old 04-30-2009, 12:28 PM   #23
Tamago
Tamago's Avatar
Drives: ZZW30
are they the plastic shims?
you nailed it sir.
Old 04-30-2009, 12:33 PM   #24
Russelt3hPirate
l33t3st Asshole
I would suggest a realignment, you never know which setting can change once you take apart a suspension. :( (don't ask why I know...haha).
Old 04-30-2009, 02:04 PM   #25
yeah, pretty sure he got them from me
Old 04-30-2009, 02:06 PM   #26
Russelt3hPirate
l33t3st Asshole
the plastic ones scare me.
Old 04-30-2009, 02:44 PM   #27
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Definitely interested in the 13mm, although my wheels are +45 with 195 tires, sooooo should I do two 10mm or what?
I was just about to buy some wheel spacers because the sucked in look in the rear is starting to piss me off.
Old 04-30-2009, 02:49 PM   #28
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
price for shipping to hawaii? :)
Old 04-30-2009, 02:55 PM   #29
About time Tamago.
Anyone noticing how NICE Tamago is in this thread?
Old 04-30-2009, 03:01 PM   #30
kngrsll
Apexing Egg!!
kngrsll's Avatar
yeah, the red ones
yah i know i should... im probably going to do shocks soon too, so i may just do it all together. why do the plastic ones bother you?
yeah, i think i did... cant wait to get my rear bar and cable bushings!
Old 04-30-2009, 03:08 PM   #31
Russelt3hPirate
l33t3st Asshole
for your setup a +13mm would be a good idea to get the most out of it.
yeah, the red ones
They are a pain to work with and not worth the price when you can get some washers that will do the same thing with a little math. :)
Old 04-30-2009, 03:11 PM   #32
33OH
Drives: '08 Yaris
I noticed.
Must be because he's asking for money. Just kidding.
Old 04-30-2009, 03:19 PM   #33
ChinoCharles
Drives: LB
Tamago is a sweetheart. He enjoys poetry, long walks in the park and hellaflush approved wheel setups.
Old 04-30-2009, 03:21 PM   #34
and wet puppy noses
Old 04-30-2009, 04:56 PM   #35
kngrsll
Apexing Egg!!
kngrsll's Avatar
LOL math :(
Old 04-30-2009, 05:41 PM   #36
Russelt3hPirate
l33t3st Asshole
LOL math :(
it isn't too hard, maybe tamago can include a calculator :lol:
WANTED - Stock 15" 2007 Yaris HUB CAPS! Chris07LB Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 06-29-2006 08:09 PM
Toyota Yaris to Sponsor FOX's "Prison Break" YarisBueller General Yaris / Vitz Discussion 0 04-30-2006 09:01 PM
