Old 04-30-2009, 12:15 PM   #19
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
el oh el, im glad my work truck had cruise on my way to ATL last weekend. well, i dont think the yaris would even move with a bunch of semi-truck brake drums in the back lol
Old 04-30-2009, 12:17 PM   #20
Pitt Yaris
Drives: Flint Mica Sedan
Extremely awesome diy. I'm gonna find a flashlight to see if I have cruise.
Old 04-30-2009, 12:59 PM   #21
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Great!
Old 04-30-2009, 01:55 PM   #22
YarisDude
Drives: Yaris Hatchback
Like it! Does anyone have a pic as to where exactly the wires are at on fuse block area for the 07 HB? Looks like a real nice weekend project.
YarisDude is offline   Reply With Quote
Old 04-30-2009, 02:43 PM   #23
To access the wire under the dash you would actually have to lift the top of the dash. The connector is above the fuse block. In this picture of the main cable harness going through the fire wall you can see the top of the back of the fuse block in the top left corner (the white plastic). The junction connector AD4 is above the connector with the wide black tape. Lying on the floor with my head on the brake pedal I can barely reach my hand up that far. PK198105 is planning on trying to get at it by raising the top of the dash this weekend.
The other place that the wire on 07-08's can be accessed is at the ECM (which is easier to get at). The key with tapping the wire there would be to use a waterproof tap or cold-shrink tape to ensure that moisture doesn't get at the connection.
This image shows the CCS terminal (pin 40) on the ECM connector A21.
Only one wire would need to be run to this connector (my red one in the DIY), as the other (the black wire) can grab any ground point.
Old 04-30-2009, 04:22 PM   #24
ka0sx
ka0sx's Avatar
Drives: bone f*ing stock
So only the wiring doesn't exist on the '08? =(
ka0sx is offline   Reply With Quote
Old 04-30-2009, 05:37 PM   #25
And, many 07-08's also don't have the indicator light on the combination meter.
Old 04-30-2009, 06:20 PM   #26
schleppy
I love momentum.
schleppy's Avatar
Drives: 2009 Yaris LB, Red
Scott, you are a true asset to this forum. Thanks so much for putting this together!
Old 05-01-2009, 07:20 AM   #27
CB900F2
Drives: 08 Sedan
So true!...
CB900F2 is offline   Reply With Quote
Old 05-01-2009, 10:30 PM   #28
uncleyaris
Fantastic!!!!!!!!!
Old 05-02-2009, 02:06 AM   #29
ka0sx
ka0sx's Avatar
Originally Posted by CB900F2 View Post
So true!...
an LED is a suitable replacment for a stupid logo.......
does the 08 ECU have the coding in all the ecu's for cruise? If so i might consider doing this the hard way.......
Old 05-02-2009, 08:02 AM   #30
The indicator on the combination meter is actually controlled by the CAN bus, so adding your own LED for cruise is not trivial.
Old 05-02-2009, 09:16 AM   #31
nickhjort
My R1 eats my Vitz!!
nickhjort's Avatar
Drives: '07 Vitz Lifty, Stick Shift
So even if my 07 lifty doesn't have those indicator lights, there's a chance I can still do this mod with the switches and some LEDs? And where did you get those little switches?
My Car Rules!
nickhjort is offline   Reply With Quote
Old 05-02-2009, 10:13 AM   #32
nickhjort
nickhjort's Avatar
Just reading all the other threads and posts on this topic and answered my own question :) I can't wait to start ripping $hit apart!!
My Car Rules!
Old 05-02-2009, 10:29 AM   #33
frownonfun
frownonfun's Avatar
subscribed
Old 05-02-2009, 10:48 AM   #34
TDB-1
Drives: 09 3-door 5speed
Just did this DIY on my 09 5 speed and it works great. I had to jump the clutch switch connector untill I get the switch, just dont step on the clutch while on cruise!!!
THANKS to all who helped figure this out
TDB-1 is offline   Reply With Quote
Old 05-02-2009, 10:58 AM   #35
nickhjort
nickhjort's Avatar
What will happen if you hit the clutch while in cruise (if you jump the clutch switch)?
My Car Rules!
Old 05-02-2009, 11:02 AM   #36
nickhjort
nickhjort's Avatar
I guess I should have read the other thread first :) You said it will over rev if you hit the clutch while jumping the switch in cruise control. Why would you need to use the clutch while in cruise anyway. If some $hit goes down you just have to hit the break to turn off the cruise then cluth after it turns off right? It's not gunna mess anything up mechanically just by jumping the clutch switch is what I'm getting at I guess.
My Car Rules!
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
How do you take off steering wheel mrrock Cosmetic Modifications (Exterior/Interior) 3 12-05-2006 10:16 AM
