Old 05-11-2009, 12:56 AM   #199
Gideon
★weeaboo★
Gideon's Avatar
Drives: 2008 Bayou LB
Yeah it was pretty jerky initially.
It still is really jerky if the engine is cold, but once it warms up it ceases.
Old 05-11-2009, 02:29 AM   #200
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Mine keeps getting worse and worse. Jerky as fuck even when the sngine is warm and the oscillation is progressively getting worse.
Old 05-11-2009, 04:53 PM   #201
PHXDEMON
PHXDEMON's Avatar
okay so the idle screw was all the way in and I backed it up as far as I could. Let the car idle for about 10 minutes and slowly the idle smoothed out completely While driving I am still getting some jerkyness and moderate oscillation (1-2k) at stop lights but nowhere near as bad as it was. It seems the ECU is actually trying to learn the new throttle body now instead of just being a whore about it. Hopefully it will smoothe itself out some more as I drive it more.
Old 05-11-2009, 05:59 PM   #202
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
hope that fixes ur issue..
Old 05-11-2009, 06:06 PM   #203
PHXDEMON
PHXDEMON's Avatar
Oh believe me so do I Hell I can even live with how it is now it's just that pegging from 1-4k nasty oscillation was horrible. The car was almost undrivable
Old 05-11-2009, 07:49 PM   #204
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Originally Posted by PHXDEMON View Post
Correct others have plugged them I just left them as is. Just go down to a lowes/home depot/etc and get a coupler barb for 3/8 inch ID vinyl tubing and you are food to roll. Stock clamps work and everything just need the barb.
FYI, I'm always food to roll..always.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 05-11-2009, 08:01 PM   #205
PHXDEMON
PHXDEMON's Avatar
Did you do the bypass?
Old 05-12-2009, 12:36 AM   #206
PHXDEMON
PHXDEMON's Avatar
Yay my motor is finally running half decent and I got a CEL
Old 05-12-2009, 07:06 AM   #207
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
that must mean its working!
Old 05-12-2009, 11:17 AM   #208
marcus
toyota
marcus's Avatar
nice.. so ur saying it idles the same as stock and no oscillations.. what about start up how high does it warm up to..
no wwe jsut need to kill the cel ..
Old 05-12-2009, 10:00 PM   #209
jkuchta
Drives: 2007 Yaris hatch (red)
What code is the CEL associated with?
Also, for the people that are still having problems with the swap:
Are you guys using the stock Yaris gasket (the black O-ring with the "tail" and the partial mesh screen) with the 1ZZ TB?
If not...you should use at least the "tail" portion. The slot that the "tail" fits in on the intake manifold offers a totally open channel through which air will get in and cause idle speed "hunting" and CEL's. The channel is large enough to suck in any partially set gasket maker and give you problems such as rough idle and CEL's.
When I did the install I cut off the "tail" from the gasket and installed it in the channel in the intake manifold with gasket maker. Once set, the "tail" creates a nice solid plug for that channel, and I haven't had a single CEL since I made the chip swap....not ONE!
jkuchta is offline   Reply With Quote
Old 05-13-2009, 11:55 AM   #210
marcus
toyota
marcus's Avatar
wow no oscillation and no cel ...
Old 05-13-2009, 09:15 PM   #211
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
After 12 pages I feel I should do this....
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 05-14-2009, 01:34 AM   #212
jkuchta
Yep...read post #78 in this thread!
Old 05-16-2009, 05:03 PM   #213
PHXDEMON
PHXDEMON's Avatar
Well the CEL finally disappeared and it ran great for about a mile. and then this
Fuck this throttle body. Put the stocker back on and it is running great.
Old 05-16-2009, 06:20 PM   #214
eii
Rides canyon walls
eii's Avatar
Whaaaaaaaaaaaaaaaaaaat? Please explain what happened. I'm scared, I'm scared for my life now.
Old 05-16-2009, 06:35 PM   #215
jkuchta
So what went wrong? Do you know what the CEL code was?
Please tell me step-by-step how you installed the 1zz TB so we can figure out what went wrong. I've been running mine without fault for a few months now...there's got to be something simple that can be fixed and will clear up the whole problem.
And eii, if you want to go for a ride in a yaris with the 1zz tb install that was done correctly, PM me.
Old 05-18-2009, 01:29 AM   #216
PHXDEMON
PHXDEMON's Avatar
CEL was gone. Car completely died and wouldn't even idle. Start it up and it woul ddie instantly. I used the original gasket plus gasket maker, I did the coolant bypass, I did the chip swap. I did everything it just didn't work out for me
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
