Old 05-13-2009, 06:07 PM   #163
IsLNdbOi
IsLNdbOi's Avatar
Thanks Scott. Keep me on the list. I'll try taking pics. later. I just find it a PITA to remove the trim pieces and panels to take the HU out.
IsLNdbOi is offline
Old 05-13-2009, 06:19 PM   #164
Grab the vertical trim pieces low, on the outside (by the storage pockets) and pull outward. They come off much easier from bottom to top.
CTScott is offline
Old 05-13-2009, 07:03 PM   #165
enviri
enviri's Avatar
Drives: 2010 Yaris
scott add me to the list too, its time for me to start getting a system.
enviri is offline
Old 05-13-2009, 07:13 PM   #166
It has arrived in Canada!
Will try to install tomorrow night. HU will be JVC.
WeeYari is offline
Old 05-14-2009, 05:25 AM   #167
IsLNdbOi
IsLNdbOi's Avatar
I tried trimming all around the back of the trim piece. Trimmed all the way to the line on the surface where you can see where the plastic was "joined" together.
Still no go. This is the best pic. I could take of it.
It's like this on both sides:
I do plan on getting the new version of the P8000BT later this year. They've released new versions of most of their 2008 models already. Hopefully, they don't add the stupid faceplate on the new model.
I do still want another of these DD trim pieces Scott so keep me on the list.
IsLNdbOi is offline
Old 05-14-2009, 11:42 AM   #168
If I understand correctly, you're trimming the lip of the trim piece to make it less deep? If that is the case, how close is it depth-wise from the trim piece being able to snap on? Also, if you were able to move the HU in deeper (by re-drilling the bracket mounting holes), would that help?
CTScott is offline
Old 05-14-2009, 12:23 PM   #169
Danish Yaris
Drives: Toyota Yaris 1,8 TS 5dr. 2007
Originally Posted by pariahdecss View Post
Yes my HU is a Kenwood DNX7120 and I had to trim the new trim piece (not the headunit) about 10mm on the back lip to make it fit - for those that are really picky the color of the new piece for my '09 LB is not a 100% match against the center AC/Air center gauge cluster trim but I am fine with that. The new trim piece is lighter than the slightly darker/smokier USDM center gauge panel.
. . . but it still looks hella better than the Metra® gap filler crap kit
Hi
That´s because the radiopanel is made for the non faceliftet model which is a lighter silver in color.
Regards Steven.
Danish Yaris is offline
Old 05-14-2009, 05:53 PM   #170
IsLNdbOi
IsLNdbOi's Avatar
Yes, I thought that's what everyone was telling me to try in the previous posts in this thread. It doesn't look very nice though. You can see in the picture that the trimmed lip can be seen.
Not sure how close it is to being able to snap on. Didn't take that measurement. I don't think moving the HU in deeper would help. The problem is the attached ring / faceplate on the front of the HU.
IsLNdbOi is offline
Old 05-14-2009, 07:48 PM   #171
SHIT!!
It's not going to work without some jigging. Going to have to shave about a quarter of an inch off of the sides of the HU opening in the trim panel.
WeeYari is offline
Old 05-14-2009, 08:47 PM   #172
SHIT!!
What HU do you have?
CTScott is offline
Old 05-14-2009, 08:52 PM   #173
JVC
WeeYari is offline
Old 05-14-2009, 09:06 PM   #174
JVC
Looking at an unmounted picture of your KW-XG700, it has a similar lip to IsLNdbOi's Pioneer. Does the narrower part beyond that lip fit through the opening, or is that the area that needs to be trimmed for?
CTScott is offline
Old 05-15-2009, 01:31 AM   #175
IsLNdbOi
IsLNdbOi's Avatar
The manual for the P8000BT shows this for the dimensions:
Dimensions (W × H × D):
D
Chassis ..................... 178 mm × 100 mm × 160 mm
(7 in.× 3-7/8 in.× 6-1/4 in.)
Nose ........................... 170 mm × 94 mm × 8 mm
(6-3/4 in.× 3-3/4 in.× 3/8 in.)
I couldn't get the P8000BT in even through the front of the new trim piece.
IsLNdbOi is offline
Old 05-15-2009, 07:17 PM   #176
...and it's in...
Ground off the positioning pins on the HU mounting brackets. Was then able to position HU further back.
WeeYari is offline
Old 05-17-2009, 08:02 AM   #177
IsLNdbOi
IsLNdbOi's Avatar
So after grinding the pins off and mounting the HU further back, does any part of the HU even touch the new 180mm DD trim piece?
IsLNdbOi is offline
Old 05-17-2009, 08:41 AM   #178
The face frame of the HU measured 178mm, with an extended nose at 170mm.
By repositioning the HU, the trim now 'rests' on the 178mm portion of the face frame. There is no contract being made on the inside of the trim piece opening.
WeeYari is offline
Old 05-17-2009, 04:51 PM   #179
I still haven't gotten a reply from PMs to: ozmdd, yrsdrgn, hwnstyle21, or Syroyizhka.
Please let me know ASAP if you are still interested. I would like the get the last of these shipped this week. If I don't hear from you by mid-week, I'm going to go ahead and move them to the next people on the waiting list.
CTScott is offline
Old 05-17-2009, 04:58 PM   #180
IsLNdbOi
IsLNdbOi's Avatar
How many people do you have on the waiting list? Are there enough on the list for the next group buy?
IsLNdbOi is offline
Dash destroyed in electrical fire. purpleminx General Yaris / Vitz Discussion 79 06-12-2009 04:53 PM
[Recovered] Group Buy for Australia #1 (Badges) harveyjai Australia 9 12-13-2008 04:59 PM
