Old 05-20-2009, 12:59 PM   #19
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
Originally Posted by CASTREX View Post
Forced induction it is then...!
I will need to start saving now..... again.
Turbotoyotas is working on a sidewind manifold for the 2ZR-FE engine and is looking some what promissing.
they've been working on that for over a year, right?
Originally Posted by xnamerxx
you nailed it sir.
Old 05-20-2009, 12:59 PM   #20
mrbond
mrbond's Avatar
cdydjded, did you document your progress? You know, for other Yaris owners in the future that plan to boost their car?
- A Toyota Yaris
- A whut Yaris?
Old 05-20-2009, 01:28 PM   #21
cdydjded
Drives: Yaris LB Turbo
an FIC in an N/A application cannot make any power over stock, because you cannot ADVANCE timing with said unit. therefore you cannot take advantage of higher octane gas.
Tamago is correct, the FIC only removes timing, only thing you could do it add fuel in a N/A application, the way to know if adding fuel makes more power with I/H/E is to dyno it, I have access to a dyno but Im only running an intake
cdydjded is offline   Reply With Quote
Old 05-20-2009, 01:29 PM   #22
cdydjded
Yes I did, updates soon
Old 05-20-2009, 01:32 PM   #23
mrbond
mrbond's Avatar
^ Excellent. I saw the HKS turbo kit Tamago showed in a few threads and everything in it is really appealing - minus the management. This is like the last piece of the puzzle.
- A Toyota Yaris
- A whut Yaris?
Old 05-20-2009, 01:34 PM   #24
Tamago
Tamago's Avatar
Drives: ZZW30
why minus the management?
what's wrong with the HKS Fcon?
you nailed it sir.
Old 05-20-2009, 01:48 PM   #25
mrbond
mrbond's Avatar
Well, I don't know that it'll be 100% compatible with the USDM Yaris ECU, plus I want a management system that I have control over, not one that is pre-tuned and non-tunable (I'm assuming the HKS Fcon isn't tunable). If it IS tunable, however, then we've got no issue.
- A Toyota Yaris
- A whut Yaris?
Old 05-20-2009, 01:53 PM   #26
Tamago
Tamago's Avatar
Drives: ZZW30
why wouldn't it be compatible? an ECU is just a computer that accepts inputs and processes them, then sends appropriate outputs....
you nailed it sir.
Old 05-20-2009, 01:53 PM   #27
Tamago
Tamago's Avatar
Drives: ZZW30
done hijacking this thread lol
you nailed it sir.
Old 05-20-2009, 02:00 PM   #28
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
(begins to consider putting s/c up for sale)
Old 05-20-2009, 02:21 PM   #29
Penguin Garage
Penguin Garage's Avatar
Drives: Yaris
is the FIC capable of doing speed density or MAP instead of MAF?
probably have to go standalone for that one.
Penguin Garage is offline   Reply With Quote
Old 05-20-2009, 02:22 PM   #30
Tamago
Tamago's Avatar
Drives: ZZW30
the FIC has a Map sensor built in, and can ignore MAF completely. this is what MAF clamping is for.
you nailed it sir.
Old 05-20-2009, 02:25 PM   #31
Penguin Garage
Drives: Yaris
ahh, I was hoping to remove it entirely.
Looking forward to more Engine Management progress.
Keep it up guys.
Old 05-20-2009, 02:33 PM   #32
Tamago
Tamago's Avatar
Drives: ZZW30
Keep it up guys.
that's what the AEM EMS is for
you nailed it sir.
Old 05-20-2009, 07:15 PM   #33
whooppee777
u made this sound like an easy fix, if so how come cali yaris and his tuner couldnt figure it out?
Old 05-20-2009, 07:20 PM   #34
Tamago
Tamago's Avatar
Drives: ZZW30
shhhhhhhhhhhhhhh don't repeat what i've been saying this whole time!
you nailed it sir.
Old 05-20-2009, 09:07 PM   #35
cdydjded
I know for sure what was Cali's issue, he had TC injectors & was using a larger diameter pipe for the MAF. So his car already had an issue when he installed the FIC. I dont why Richard could not figure it out, & Im not sure who was the other person.
Old 05-20-2009, 09:10 PM   #36
Tamago
Tamago's Avatar
Drives: ZZW30
Originally Posted by cdydjded View Post
I know for sure what was Cali's issue, he had TC injectors & was using a larger diameter pipe for the MAF. ]
me too :)
you nailed it sir.
AEM cold air intake vs Afe intake... djgab101 Performance Modifications 69 04-28-2013 03:03 PM
AEM FIC works in Yaris......Sort of cdydjded Performance Modifications 32 12-06-2009 02:58 AM
Works bell/Nardi quick release steering wheel setup blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 35 09-02-2009 06:52 PM
AEM UEGO Wideband ONLY $220! 365Motorwerks Sponsors Classifieds Area 0 11-22-2008 12:02 PM
2007 Toyota Yaris Hatchback AEM Intake KenAEM Performance Modifications 6 03-24-2007 12:47 PM
