Old 05-12-2009, 11:00 PM   #217
jkuchta
Drives: 2007 Yaris hatch (red)
What code is the CEL associated with?
Also, for the people that are still having problems with the swap:
Are you guys using the stock Yaris gasket (the black O-ring with the "tail" and the partial mesh screen) with the 1ZZ TB?
If not...you should use at least the "tail" portion. The slot that the "tail" fits in on the intake manifold offers a totally open channel through which air will get in and cause idle speed "hunting" and CEL's. The channel is large enough to suck in any partially set gasket maker and give you problems such as rough idle and CEL's.
When I did the install I cut off the "tail" from the gasket and installed it in the channel in the intake manifold with gasket maker. Once set, the "tail" creates a nice solid plug for that channel, and I haven't had a single CEL since I made the chip swap....not ONE!
jkuchta is offline   Reply With Quote
Old 05-13-2009, 12:55 PM   #218
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
wow no oscillation and no cel ...
Old 05-13-2009, 10:15 PM   #219
RagnaCaT
HacKers WanTed!
RagnaCaT's Avatar
Drives: Yaris S HB & Yaris S SD
After 12 pages I feel I should do this....
R-CaT
Project Yar 2ZR
RagnaCaT is offline   Reply With Quote
Old 05-14-2009, 02:34 AM   #220
jkuchta
Yep...read post #78 in this thread!
Old 05-16-2009, 06:03 PM   #221
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Well the CEL finally disappeared and it ran great for about a mile. and then this
Fuck this throttle body. Put the stocker back on and it is running great.
Old 05-16-2009, 07:20 PM   #222
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Whaaaaaaaaaaaaaaaaaaat? Please explain what happened. I'm scared, I'm scared for my life now.
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 05-16-2009, 07:35 PM   #223
jkuchta
So what went wrong? Do you know what the CEL code was?
Please tell me step-by-step how you installed the 1zz TB so we can figure out what went wrong. I've been running mine without fault for a few months now...there's got to be something simple that can be fixed and will clear up the whole problem.
And eii, if you want to go for a ride in a yaris with the 1zz tb install that was done correctly, PM me.
Old 05-16-2009, 07:56 PM   #224
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
yea thats crazy my CEL went off and its been running great!
http://www.4055design.com
Old 05-18-2009, 02:29 AM   #225
PHXDEMON
PHXDEMON's Avatar
CEL was gone. Car completely died and wouldn't even idle. Start it up and it woul ddie instantly. I used the original gasket plus gasket maker, I did the coolant bypass, I did the chip swap. I did everything it just didn't work out for me
Old 05-18-2009, 02:35 AM   #226
Yaris T-Sport.
Yaris T-Sport.'s Avatar
Drives: .
That could be pretty much the 1ZZ T/B itself being the problem, try another different 1ZZ T/B or try the 2AZ-FE 2.4L T/B.
remember! failing is the beginning of success, it wasn't easy for me either
Yaris T-Sport. is offline   Reply With Quote
Old 05-18-2009, 02:35 AM   #227
jkuchta
Bummer...
Do you know what the code for the CEL you were getting was? It may provide some clues as to what caused your problem.
Old 05-20-2009, 09:35 PM   #228
bieniman
bieniman's Avatar
Drives: vitz rs 1500 2001
Guys,
I've been following this mod for a while now,
If I'm correct the newer yaris models have electronically controlled TB. Well, I looked under my hood and see sort of like a cable running from the pedal to the TB, I can rev my engine by turning this swivel.
bieniman is offline   Reply With Quote
Old 05-20-2009, 09:38 PM   #229
bieniman
bieniman's Avatar
O yeah forgot to ask.
Can I do this mod also to my , Vitz Rs 2001?????
Old 05-20-2009, 10:00 PM   #230
enviri
enviri's Avatar
Drives: 2010 Yaris
dude! i was about to put it on! now im gonna have second thoughts or get garm's! jeez...i think there HAS to be something we're missing...a hidden variable thats affecting some of us...
Old 05-20-2009, 10:12 PM   #231
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Originally Posted by bieniman View Post
Guys,
Yes, this mod only applies to the Drive by wire system that is in the ( i believe) '05 and newer
Old 05-20-2009, 10:13 PM   #232
AlexNet0
AlexNet0's Avatar
doesnt sound like the TB unless a wire snapped somewhere.
Old 05-20-2009, 10:31 PM   #233
PHXDEMON
PHXDEMON's Avatar
Stocker works flawless though so it isn't a wiring issue.
Old 05-20-2009, 10:33 PM   #234
PHXDEMON
PHXDEMON's Avatar
Guys,
I'm not 100% positive on this but the scion xa/xb owners have done a swap with an older 1zz throttle body which is drive by cable like yours. check the forums @ scionlife.com you should be able to dig up more info.
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 07:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
