Old 05-19-2009, 11:53 PM   #19
eric81
eric81's Avatar
Drives: Toyota Salesman
It is most likely the motor mounts. If you look at how they are made and put together, they move front to back AND up and down. It doesn't take much to jiggle the engine up and down. I am betting that your mounts aren't on quite right, or they are bad from the factory. It's the only thing I can think of. That and the battery, but that would be obvious... just grab the battery, and push really hard towards the back, then yank on it to bring it foreward. If it moves, tighten down the 10mm nut on it.
eric81 is offline   Reply With Quote
Old 05-20-2009, 12:09 AM   #20
GeneW
Drives: 2008 Yaris
Originally Posted by Swallow View Post
HI everybody,
I have just joined this wonderful forum, happy to be between you!
I have bought a Sedan Yaris 3 months ago ( brand new ).
When I pass over some speed bump or something like that, I feel something jumps up in the engine compartment, as if something is loose ...
Has anybody have a similar experience?
Open up the hood and look. My guess is that the catalytic perverter has a heat shield - many do - and it might have come loose. I've had this problem with a Honda in the past, and it "rattled" when I would hit bumps in the road.
Gene
Old 05-20-2009, 02:28 PM   #21
vitzzz
Drives: VITZ
yes i have that noise also not sure what it is, sometimes i hear it from engine bay and sometimes from underneath. also there are noises from the fuel tank when i tap with my hand on the tank , i hear some type of noises which can be what we hear on bumps
vitzzz is offline   Reply With Quote
Old 05-20-2009, 10:29 PM   #22
GeneW
Drives: 2008 Yaris
You are aware that the Yaris has FAR less sound proofing than most cars made today or in the past?
I've heard braking noises, gear train noises, exhaust rumblings and when I drive over road salt and gravel sounds like someone is pouring pea gravel onto a soda can.
I wonder if what you're experiencing is just the normal "sounds" of a Yaris?
Gene
Old 05-20-2009, 11:38 PM   #23
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
Ive gotten used to all of the random sounds and road noise/things sound like they are bouncing, now I just pay attention enough to know when something is rubbing/creaking, etc.
If you have doubts, have it checked though
Old 05-21-2009, 02:15 AM   #24
Swallow
Swallow's Avatar
Drives: Yaris Sedan YRS
I investigated it deeper. I THINK I made a mistake... The sound seems to come from the steering box?! ( It's route is vague )
And one other sound! I hear a rattling sound when I reverse the car, especially when the engine is cold ( in the mornings ) !!! But as soon as I change the shift to D ( going forward ), the rattling sound disappears!
ONLY YARIS !
Swallow is offline   Reply With Quote
Old 05-21-2009, 04:02 AM   #25
MGargano
Drives: 2009 Yaris Hatchback
Sounds dumb, but check the hood prop rod to make sure it's latched on top of the battery where it's supposed to be. The geniuses who did my oil change forgot to do this and I had a banging sound coming from the engine compartment when I went over bumps. I checked under the hood when I got home and VOILA... there was the hood prop rod, just laying on top of the battery, not latched in.
Old 05-21-2009, 08:31 AM   #26
AlexNet0
AlexNet0's Avatar
the rattling is normal, mine has done it since day 1, and I dont even have an auto
Old 05-22-2009, 08:07 AM   #27
Swallow
Swallow's Avatar
Thank you all,
I am very confused, maybe the sound is normal but this is not my first car. Even the used cars I owned haven't had such a sound when I pass over a sharp pavement bulge.
ONLY YARIS !
Old 05-22-2009, 08:31 AM   #28
Bob Dog
DARK PHASE OF THE MOON
Bob Dog's Avatar
Drives: 07 liftback
Hood prop improperly secured?
Bob Dog is offline   Reply With Quote
Old 05-24-2009, 02:25 AM   #29
Swallow
Swallow's Avatar
That is secured
ONLY YARIS !
Old 05-24-2009, 12:41 PM   #30
cfiimei
Drives: Sedan
Battery?
cfiimei is offline   Reply With Quote
Old 05-25-2009, 05:12 PM   #31
eric81
eric81's Avatar
I said battery earlier, but no one ever listens to me...
Old 05-25-2009, 05:46 PM   #32
enobmort42
First time DIYer
enobmort42's Avatar
Drives: '07 LB Polar White
Send a message via AIM to enobmort42
i've found a rattling noise recently, but have figured out how to stop it. i first noticed it when i would close my doors, i'd hear it in the engine bay. so i opened it and started tapping on the top of the bumper to recreate the noise and sure enough.. to keep it from rattling, i would press hard on the metal that the bumper is fastened to and tap the bumper. no noise. almost sounds like a nut or bolt jiggling around in some hidden metal compartment... =\
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs
enobmort42 is offline   Reply With Quote
Old 05-25-2009, 10:12 PM   #33
Swallow
Swallow's Avatar
Sorry dear, I checked the battery , unfortunately the source was not that
ONLY YARIS !
Old 05-25-2009, 10:20 PM   #34
Swallow
Swallow's Avatar
Have you bought it brand new?
ONLY YARIS !
Old 05-25-2009, 10:29 PM   #35
AlexNet0
AlexNet0's Avatar
I bought it with 20 miles on the odometer. 2007 3dr 5spd LB
Old 05-26-2009, 12:48 AM   #36
Jeemee
XBL: Jeemee Ghost
Jeemee's Avatar
Drives: 2008 Yaris LB
Mine too has a strange noise coming from engine bay. It's random and sounds like a really bad CV Joint. Like a pop sort of. Never figured out what it was. Is yours similar sounding?
_________________________________________________
Nitto Axle-Back--Tanabe DF210s--UR 23mm Rear Sway Bar--Penguin Garage 10mm Hub Spacers
Jeemee is offline   Reply With Quote
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
The last gas question Tonavi DIY / Maintenance / Service 56 04-27-2009 09:40 PM
engine swap update Adriaan Canada 5 03-03-2009 07:21 PM
The Advantages of Nitrous on an Engine KCALB SIRAY Performance Modifications 7 01-02-2009 11:53 AM
