Blazing Blue Yaris
fog lights
Are there any fog light kits available for a 2009 3dr liftback? Will the ones for 07-08 fit?
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
Yes, the 06-08's fit but you need to get the shrouds for the 09. TRDSparks has them: RH- 8148152330 & LH- 8148252260. I used the Micro Image 06-08 LB fogs with these shrouds and the fit is perfect.
Blazing Blue Yaris
Thank you for the info
If you search...there is a host of information.
![]() ![]() ![]() Drives: 09 Yaris 3 Dr White LB Join Date: Mar 2009
these are the wrong part numbers don't waste your money
Actually, the part numbers above are correct. Here is a picture of mine, when they were still in the package with the part numbers:
Fog Trim.jpg |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
I'm guessing no one sells a kit yet that comes w/ everything for the '09?...
#9 | |
The look exactly the same just different part number's
If you order those part numbers from Sparks you will get covers without holes for the lamps just like the ones you took off the Original. Just trying to avoid the problems I am going thu.
Then you received the wrong parts. The part #'s for the 09 covers without holes are RH- 81481-52110 & LH 81482-52100
The dealership that I ordered mine through took two tries. I gave them the correct part number, but the parts guy looked it up himself in the EPC and ordered the hole-less ones. The second time around they used the part number that I gave them and got the correct ones.
JDM yO!
Drives: '09 3dr. 5-spd Join Date: Oct 2008
The part numbers are correct. I ordered with those numbers and I received the correct parts..
Those part numbers show up as the following on their systems: 81481-52330 - COVER, FOG LAMP, RH - FRONT FOG & DRIVING LAMP-WITH 81482-52260 - COVER, FOG LAMP, LH - FRONT FOG & DRIVING LAMP-WITH The 09 shrouds without fog holes are 81481-52320 (RH) and 81482-52250 (LH).
![]() Drives: 2009 5 Door Carmine Red Join Date: Dec 2008
How about installing the fog lights in the '09? pretty much the same as the lesser years?
The Geologist is a-rockin' and a rollin'! |
~ ambient one ~
Drives: 2009 Bayou Yaris Liftback Join Date: Jan 2007
I gotta order mine today when I pick up the car. I took out the Toyota OEM lamps that I bought for my'07 because I didn't want to order them again.
I left the Ebay ones on the car instead. Funny thing is though that I had 2 sets and both had one crack. They cracked on the same side so I took the other one and installed it upside down. It's a little off, but did the trick.
AMBIENTLIFESTYLE
Tri-State Sport Compact EZine ambientlifestyle.com------------ambientlifestyle.ning.com ![]() Micro Image Store - Network - Online microimageonline.com------------microimage.ning.com |
No hidden tricks? Is there any other place to get these covers that are cheaper than 18 bucks each?
The Geologist is a-rockin' and a rollin'! Last edited by Geology; 06-30-2009 at 03:10 PM. |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| Fog lights and shift knobs | flip_yaris | Cosmetic Modifications (Exterior/Interior) | 4 | 09-26-2006 11:48 AM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 02:13 PM |
| Fog lights for S sedans (US version) | paeko73 | General Yaris / Vitz Discussion | 11 | 07-03-2006 12:38 AM |
