Old 06-06-2009, 02:23 AM   #289
MGargano
Drives: 2009 Yaris Hatchback
Originally Posted by jkuchta View Post
turn the screw clockwise a half turn with the engine off. That should make it better. Also, if a half turn isnt enough, keep turning in half turn increments (with the engine off).
I gave up on the 1ZZ for the 2nd time. No matter how many turns I gave the idle screw, after a while the engine would settle back down to around 500 RPM, shake/shudder, rev up to 1,000 RPM, and then repeat the process until I either started moving or turned the car off in frustration. I hate all the problems I'm having since the performance of the the 1ZZ really is noticeably better than OEM, but I can't take the way it idles. I was also getting the heavy jerking whenever I took my foot off the gas.
Old 06-06-2009, 01:54 PM   #290
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
you might have gotten a bad throttle body. maybe you should order the one through cali yaris.
Old 06-06-2009, 02:39 PM   #291
MGargano
I don't think it's that, since the TB was working perfectly until I disconnected the battery. I wasn't getting any oscillation, jerking, weird idling, or CEL... then I pulled the battery cable and all these problems came out of the woodwork. I might try the swap again down the road sometime. Where can I get the Micro Image one? I don't see it listed on his website. Is it new or used/refurbished?
Old 06-07-2009, 02:17 PM   #292
jkuchta
Drives: 2007 Yaris hatch (red)
It's a 1zz TB, with the Yaris chip module already swapped on...also, we remove all of the epoxy on the idle set screw and make a preliminary adjustment to get you in the ballpark.
jkuchta is offline   Reply With Quote
Old 07-05-2009, 02:37 PM   #293
PETERPOOP
PETERPOOP's Avatar
finally installed my 1zz tb after months of it sitting in my room. no CELS. warm idle at 2500rpms, then within seconds drops to 2k rpms, and then idles smoothly at a warm idle of 585 rpms. Didn't adjust the idle screw, and I didn't switch the chips; I think i've lucked out....
Drove the car after and ran it hard and conservatively, no problems! niceee
edit: Still running good. I don't really notice an increase in power? I remember looking at Yoda's dyno sheet that he did after he added the 1zz TB, and he got a gain of 3 whp. Unless I got less of a gain, I can't really feel 3 whp added to the existing. However, if the car keeps running with no problems for a couple of weeks, I plan on taking it to get dyno'd. Now that I have my 1zz injectors, I will be able to successfully do three pulls and hopefully hit 140whp now with the 1zz TB! :)
Old 07-17-2009, 10:16 PM   #294
blacksandiegovitz
Your mom goes to college
blacksandiegovitz's Avatar
Drives: 08 Vitz
Originally Posted by echo_hrs View Post
I got my TB yesterday & cleaned and polished it...I need to go get a coupler for the intake to TB, is it a 2.25" - 2.5" I need?
Anything else I need for the swap?
I'm thinking I'll just do the straight swap like PETERPOOP and see what I get before swapping chips...
Cheers
I just did this swap today and Its feels a lot stronger. I was able to make my aem coupler strech over the corolla tb .
you'll also need either 6 rivets and a rivet gun or 6 x small bolt and nuts for the "chip swap "
Old 07-19-2009, 06:25 PM   #295
jkuchta
I used 6-32 allen head cap screws and jet nuts on mine. Makes for a realy clean job and the jet nuts are self-locking, so no worries about the screws coming loose.
Old 07-20-2009, 09:56 PM   #296
whooppee777
I used to have 1700 posts
whooppee777's Avatar
Drives: 2008 Yaris Hatch
where the hell did the diy go?
Old 07-20-2009, 10:26 PM   #297
PETERPOOP
PETERPOOP's Avatar
t-sport is at it again; deleting everything he posts. i wouldn't think he'd delete this!
Old 07-20-2009, 10:27 PM   #298
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
why did he do that?
Old 07-21-2009, 12:54 AM   #299
whooppee777
ditto
Old 07-21-2009, 03:44 PM   #300
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
Originally Posted by mikenacarato View Post
why did he do that?
Wants to be the only one w/ the setup/s...or it backfired on him...or something else?
Old 07-21-2009, 03:55 PM   #301
jkuchta
I've got close to 10,000 miles on my chipped 1ZZ TB, so I don't think it went bad on him.
Old 07-21-2009, 04:13 PM   #302
PatrickJohnson
Drives: 2008 Yaris LB
I'm hoping he just removed it because so many are having issues and not because he is being a pissant...
PatrickJohnson is offline   Reply With Quote
Old 07-21-2009, 08:21 PM   #303
whooppee777
i just did a swap last night from the stock throttle position sensor to a scion tc throttle body. i havent put the throttle body on yet to see it worked though. my corolla throttle body didnt set any cels when i installed it as is
Old 07-21-2009, 10:28 PM   #304
PETERPOOP
PETERPOOP's Avatar
my 1zz throttle body that i put on without switching the chip or adjusting the idle screw and was running perfectly for the last two weeks has just turned gay on me. It started oscilating the other day, and i unplugged the battery, replugged it and it was fine. However, again it is now back to oscilating and i can't disturb it by tapping the gas to interupt it. my only hope now is to do a chip swap; but i don't think i want to.
Old 07-21-2009, 10:48 PM   #305
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Na, he always does this. We're not sure why he does though.
Why wouldnt you? I didnt even bother trying it with the stock 1zz chip since I heard almost everyone's problems being fixed by a swap. Swap it!
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 07-21-2009, 11:00 PM   #306
blacksandiegovitz
Drives: 08 Vitz
Just do the damn swap already Peter
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 07:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 08:15 PM
