Old 06-13-2009, 05:19 PM   #1
Prohibit
Verbieten Sie
Prohibit's Avatar
Drives: 2007 Liftback
Send a message via AIM to Prohibit Send a message via MSN to Prohibit Send a message via Yahoo to Prohibit
Help! Brake light issues!
Okay, so when I changed my oil I noticed that my brake light was out. I replaced the bulb, and the tail light is working.. but brake light still is doing nothing. This is the passenger side on an 07 liftback.
Thoughts? Think maybe I have a short or something?
Hatchback Purist? Be sure to drop in and register. New forum with a great clean design and potential.
Prohibit is offline   Reply With Quote
Old 06-13-2009, 05:20 PM   #2
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Not a short unless it's blowing fuses. More likely to be a loose ground wire somewhere.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 06-13-2009, 05:21 PM   #3
Prohibit
Verbieten Sie
Prohibit's Avatar
Any ideas where I should begin my search? Not very car literate so looking for as much info as possible, haha.
Old 06-13-2009, 07:29 PM   #4
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
The grounding is usually close by. Look for a wire out of the bulb socket that attaches to the chassis.
Old 06-13-2009, 07:38 PM   #5
silver_echo
ekodrvr
silver_echo's Avatar
just as a side note, i would be pretty sure that the ground is fine, as the tail light side is working... my suggestion is to check to see if there is a short in the wire from the bulb to the last splice in the brake light circuit, or to make absolutely sure on the light bulb being correct...
i like this smiley...
silver_echo is offline   Reply With Quote
Old 06-14-2009, 01:04 AM   #6
Brian
Brian's Avatar
Check the brake fuse located under the dash. Do you have and auto or manual?
Old 06-14-2009, 05:15 AM   #7
silver_echo
ekodrvr
cannot be fuse if it is only one bulb... only circuit that has individual fuses like you are thinking is the headlights so that you can limp home with one light to see by at night...
Old 06-14-2009, 08:28 AM   #8
Brian
Brian's Avatar
the brake lights have their own fuse and another one for the illumination. My brake lights didn't work but everything else did. I replaced the brake fuse and it fixed the problem. I also could not shift out of park until the fuse was replaced. I missed the part about just the passenger side
Old 06-14-2009, 01:19 PM   #9
IllusionX
Drives: 07 Yaris Sedan Aero
Is your bulb dual filament?
Old 06-16-2009, 02:24 PM   #10
silver_echo
ekodrvr
update?
Old 06-17-2009, 01:23 PM   #11
MUSKOKA800
MUSKOKA800's Avatar
Great safety feature. All too many morons on the roads with no brake lights. I guess they don't have $5 and 5 minutes install time to save themselves from a wipelash.
Old 06-17-2009, 02:43 PM   #12
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Happened to me only after a couple of weeks of buying my car. I was trippin out cause I thought it was something worse. The dealership said "they just changed a fuse", but didnt say which one and as to why I couldnt shift out of park. I figured it was probably a safety issue.
anyways...yeah, so check your fuses man @_@
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 09-22-2009, 02:46 PM   #13
Prohibit
Verbieten Sie
Prohibit's Avatar
Haha, well when I move around the wire connected to the tail light bulb it turns the light off and on. So I think it's something to do with the wires? The brake light and tail light use the same bulb, and the tail light works, but not the brake light. The other two brake lights work.
Old 09-22-2009, 06:13 PM   #14
silver_echo
ekodrvr
okay well, you found where the system is shorted, and that would be a relatively simply fix... however, take it to a shop of some sort because said shop will warranty their work, FTW
Old 11-25-2009, 11:33 PM   #15
AND189
Drives: 2
what number is the brake light fuse i just put in rs lights and all globes work but the brake lights dont
AND189 is offline   Reply With Quote
Old 11-25-2009, 11:47 PM   #16
It's the 10A fuse labeled STOP on the bottom of the under dash fuse panel.
Old 11-26-2009, 05:26 AM   #17
AND189
Drives: 2
thanks again mate
Old 05-23-2011, 07:33 PM   #18
weslowski
weslowski's Avatar
Drives: yaris
fuses
where is the illumination fuse?!?!?!?!
weslowski is offline   Reply With Quote
HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! mizhgolightly DIY / Maintenance / Service 45 05-03-2022 02:59 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
Help Needed - Brake Light Question *MAD DOG* Cosmetic Modifications (Exterior/Interior) 21 02-08-2009 05:32 AM
Removing third brake light lightyearsgirl DIY / Maintenance / Service 8 08-06-2006 11:26 AM
