Old 07-08-2009, 10:01 PM   #127
EasyDriver
Drives: 2008 Yaris Meteorite LB
How you ever managed to get zip ties in the area near the alternator (picture 2) is beyond me! I tried and tried to do that, but couldn't get it done. Or, maybe my patience just ran out!
EasyDriver is offline   Reply With Quote
Old 07-08-2009, 11:01 PM   #128
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
Originally Posted by n00b View Post
There are no long-term effects other than a better working a/c.
evap core freezing up......
Old 07-08-2009, 11:52 PM   #129
n00b
Drives: Car
wikipedia told you this?
Thanks, I'm done with this forum. I'll let you believe 2+2=5.
n00b is offline   Reply With Quote
Old 07-09-2009, 12:03 AM   #130
Lafiro
Drives: 06 Yaris Sedan
Now im trying to figure out if the cold line we are feeling on the top of the exhaust/left of the motor is actually going into the cabin, or coming out?
The pictures above show it coming out, meaning what is the point to keep something cool thats not going to the cabin to make us cool!?
Someone has to explain this better, or maybe there is another place to insulate this?
Also has anyone looked under the steering wheel, right side of the floor, and also seen how close the two pipes come to each other? Seems like that needs insulation as well!
Old 07-09-2009, 12:32 AM   #131
Lafiro
Yes, that explination worked out great. Thanks.
I will try doing this tomorrow, couldn't today because I was in the process of installing fog lights.
Old 07-09-2009, 12:41 AM   #132
mikenacarato
SIPNDEW
Drives: 15 STI
that would be the case if we insulate the HIGH PRESSURE line.
the compressor might not have to work so hard, neither your fan so i would say that long term effects would be beneficial.
ah, well then ill take your work on it. i have some heat shielding tape im going to use i just wanted to make sure the core wouldnt freeze.
Old 07-09-2009, 08:47 AM   #133
EasyDriver
evap core....
If anyone is concerned about the core freezing up....simply don't cover the entire line. It won't be as cold in the cabin, but you don't have to worry about it. If you covered the entire line, like I did, all you have to do is remove some of the insulation and the problem is solved.
Old 07-09-2009, 10:30 AM   #134
texkid
The one with cheese on it
Drives: '10 Corolla S
Patience and a needle nose pliers to use as my second fingers. But mainly patience.
DIY: A/C Insulation
texkid is offline   Reply With Quote
Old 07-09-2009, 03:06 PM   #135
b_hickman11
Drives: 08 Sedan
How many years have you had this mod?
Old 07-09-2009, 03:09 PM   #136
b_hickman11
Drives: 08 Sedan
What does the dryer do?
Old 07-09-2009, 03:43 PM   #137
The dryer removes moisture that may have entered the system to protect the compressor.
Old 07-09-2009, 06:06 PM   #138
b_hickman11
Drives: 08 Sedan
So....I would assume that the dryer has some type of rating on it, meaning the amount of moisture it can remove out of the air in a given amount of time. With this new mod, more moisture will be present in the line. How do we know that the dryer will do it's job with the extra moisture. It might work for now, but a year from now, or 2, or 3, will it still be able to work correctly or will it break prematurely due to having to work harder?? Anyone have any longterm data?
Old 07-09-2009, 07:23 PM   #139
toast
Drives: 2007 LB
So....I would assume that the dryer has some type of rating on it, meaning the amount of moisture it can remove out of the air in a given amount of time. With this new mod, more moisture will be present in the line. ?
The drier will trap moisture and debris that entered the system when it was assembled and charged. As the a/c system is a sealed system you will not be getting any new moisture in the lines until a leak develops and then you have a whole new problem... no cooling. If you replace a compressor you change the drier too.
toast is offline   Reply With Quote
Old 07-09-2009, 07:36 PM   #140
b_hickman11
Drives: 08 Sedan
So whats the point of a dryer?? The way you describe it is that once it dries the initial moisture in the air when the AC is used for the very first time, then dryer is useless?
Old 07-09-2009, 07:47 PM   #141
It has the ability to absorb a significant amount of moisture - more than should be in the system from initial manufacturing. Once the system leaks enough to reach atmospheric pressure the dryer will most likely become saturated. Replacing the dryer, when replacing the compressor is important, since you can't easily tell the condition of the dryer and it is cheap in comparison to the compressor.
Old 07-09-2009, 09:45 PM   #142
b_hickman11
Drives: 08 Sedan
So why wouldn't they come up with a machine that dry's out the system at the factory and not install a dryer since the dryer is useless after becoming saturated from the moisture in the lines during installation. Wouldn't that be more green for the economy??
Old 07-09-2009, 09:53 PM   #143
When you charge an AC system, you first draw a vacuum on it to pull out as much moisture and particulate as possible. It's impossible to get every bit, so that's where the dryer comes into play.
Old 07-09-2009, 11:44 PM   #144
b_hickman11
Drives: 08 Sedan
Thats why they need to have a removable dryer. Has a shut off valve before and after the dryer. After the dryer has done it's job, shut the valves off and remove the dryer. Clean the dryer out and reuse it on the next car coming down the belt.
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
