Old 07-09-2009, 09:56 PM   #55
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
^I wouldnt be happy either, lol.
If mikey can post the part number he used, Id probably look for one too, that would be so sweet.
Old 07-09-2009, 11:41 PM   #56
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i will when it comes in. i dont remember what it was. i ordered it from the dealer so i know its gotta be right.
mikenacarato is offline   Reply With Quote
Old 07-09-2009, 11:50 PM   #57
kustom play
pink wheels are cool
kustom play's Avatar
Drives: 07 liftback
how much did the part end up costing? I want to get one as well! Do you have the part number?
im excited that somebody will be able to check this out!
http://www.4055design.com
Old 07-10-2009, 07:47 PM   #58
ellenbetty
ellenbetty
ellenbetty's Avatar
Drives: 2 2007 Yaris 3 door liftback
I remember reading warnings about loss of odometer reading can occurs when the car's battery is disconnected. Warnings to involve the dealer when disconnecting the car's battery. The dealer can handle reprogramming the odometer when the battery is reconnected. So my guess is if you replace the gages and the new odometer reading is wrong, take the vehicle to the dealer and have the odometer reprogrammed with the correct odometer mileage.
ellenbetty is offline   Reply With Quote
Old 07-10-2009, 08:00 PM   #59
90tsi
90tsi's Avatar
Drives: 09 yaris
^ if this was the case all the guys that have changed there leds would have experienced this issue and after do them in mine the odometer memory remains.
90tsi is offline   Reply With Quote
Old 07-15-2009, 08:17 PM   #60
mikenacarato
SIPNDEW
Drives: 15 STI
i have the new S cluster in my car ready to be installed tonight.
Old 07-15-2009, 08:34 PM   #61
mikenacarato
SIPNDEW
Drives: 15 STI
here is the final verdict!
everything swapped over fine and plugged right up. it WILL need to be programmed though as the miles will NOT carry over. not sure about 08s but thats the case on my 09.
Old 07-15-2009, 09:54 PM   #62
Did you get an 08 or 09 combination meter? Also, what is the part number on the one you received?
Old 07-15-2009, 10:09 PM   #63
Sodium Duck
╚══════════RN
Sodium Duck's Avatar
Drives: 2008 Liftback
Very cool. Please keep us updated when you get it reprogrammed -- any obstacles that kind of stuff.
Old 07-15-2009, 10:10 PM   #64
Sodium Duck
╚══════════RN
And pics!
Old 07-15-2009, 10:21 PM   #65
n2oinferno
Drives: 96 Bonneville SSE/08 Yaris LB
Absolutely fantastic news.
n2oinferno is offline   Reply With Quote
Old 07-15-2009, 10:34 PM   #66
mikenacarato
SIPNDEW
Drives: 15 STI
i got an 09 cluster. there were no problems installing it at all, it was very easy and took about 10 mins or less and you only need a phillips head screwdriver.. ill take a pic later tonight for you guys and post a pic of the box with the P/N.
Old 07-15-2009, 10:49 PM   #67
Interesting. The 09 service manual doesn't mention anything about reprogramming. In the replacement procedure it does mention disconnecting the battery (but then again it does for replacing anything electrical).
You may want to try for the heck of it disconnecting the negative battery cable for a couple of minutes to see if perhaps on a cold boot the ECM and the combination meter do some type of a sync.
Old 07-15-2009, 10:53 PM   #68
mikenacarato
SIPNDEW
Drives: 15 STI
ill go do that right now and let you guys know here in a few mins. im at work so i cant upload pics or anything because of the blocks.
Old 07-15-2009, 11:01 PM   #69
mikenacarato
SIPNDEW
Drives: 15 STI
well the negative terminal cant be taken off because of the strut bar being almost on top of it. ill have to tinker with it when i get home and dont have to be away from my desk for a long time. ill let you guys know later.
Old 07-15-2009, 11:05 PM   #70
You can try just popping the two ECM connectors.
Old 07-15-2009, 11:44 PM   #71
auxmike
auxmike's Avatar
8380052P10 =$385.60
Instrument panel - Cluster and switches - Cluster assy - W/o abs
W/s model - Hatchback 2008
Old 07-15-2009, 11:46 PM   #72
mikenacarato
SIPNDEW
Drives: 15 STI
for a 2009 the hatches auto and manual share the same part #. and they all have ABS so the 1 part number i post for 2009 will fit all 09 hatches
DIY Oil Pressure Gauge Install LtNoogie DIY / Maintenance / Service 13 11-20-2009 05:13 PM
A-pillar gauge pod Tonavi Cosmetic Modifications (Exterior/Interior) 26 02-26-2009 08:35 AM
Yaris safety pack - where is it located? signs General Yaris / Vitz Discussion 5 02-22-2009 07:43 AM
A-Pillar gauge pods that can fit tweeters? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 9 11-23-2008 03:25 PM
Gauge Pod for Liftback? eight_heads General Yaris / Vitz Discussion 2 06-07-2007 11:41 AM
